PIC18F4455 RPM Interrupt
ICeZer0
PostPosted: Thu Apr 14, 2016 2:17 pm     Reply with quote
Hi all,
I have looked through the forums and I think my issue is unique enough. I am using the PIC18 to implement a PID controller to match the desired voltage of a battery. The PID requires constant monitoring of the ADC set at 100ms on timer3. Now I have implemented a RPM method on timer1 but since the RPM method needs to count it interferes with my program and causes the PID not to work. I had the RPM method on a 50ms interrupt, I think this is happening because of the do while loop not sure how to fix it. How can I make the timers not mess with each other?
Thanks!
void HallEffect()
   start_Measurement();
   do
   }while(!meas_done);
   disable_interrupts(INT_TIMER1);
   disable_interrupts(INT_EXT);
   theRPM = sensor_pulses * 60;
   sensor_pulses = 0;
   printf(lcd_putc,"rpm = %ld\n", theRPM);
   theRPM = 0;
void start_Measurement()
   meas_done = false;
   loops = 20; //50ms * 20 = 1000ms
   set_timer1(0);
   enable_interrupts(INT_EXT); //interrupt every pulse from senor
PostPosted: Thu Apr 14, 2016 3:14 pm     Reply with quote
Ok, I'm lost ..
just WHERE or HOW do you get a rotational measurement from a battery ?
Really you need to properly explain what you're trying to accomplish , inputs, outputs,rates,frequecny, tc.
At first I thought you were building a battery charger but RPM has mescratching my head.
I do like a challenge though !
Jay
ICeZer0
PostPosted: Thu Apr 14, 2016 3:23 pm     Reply with quote
haha sorry I guess that is really confusing!
So we have an alternator connected to a stationary bicycle trainer then we are turning the alternator to produce a voltage to charge the battery. The system also has the capability to provide a resistive ride for the user. The PIC is sending a PWM signal to the generator; the duty cycle depends on the error from the PID controller. The error is calculated by sensing the ADC difference from the generator and the battery level. Everything is working on the project but I wanted to display on our GUI the distanced pedaled by calculating the RPM. The only free timer I have left is timer1. Hope that clears things up
PostPosted: Thu Apr 14, 2016 3:35 pm     Reply with quote
Post your interrupt routines. Post the frequency of the incoming signal
on the External interrupt pin.
ICeZer0
PostPosted: Thu Apr 14, 2016 7:14 pm     Reply with quote
Shocked.
PostPosted: Thu Apr 14, 2016 10:22 pm     Reply with quote
Your complaint is that you have to sit in this loop:
do
}while(!meas_done);
The thread you referenced suggests two methods. Why not use the CCP
method ? You don't have to wait in a loop with that method.
ICeZer0
PostPosted: Fri Apr 15, 2016 5:45 am     Reply with quote
Doesn't the receive buffer for the RS-232 use Timer0? I didnt use CCP2 because of that. Can you explain a little more how I would set this up with CCP2? I know it can capture input, but measuring time in PIC C I am not clear on how it works. What method to use, how to start the time, how to end the timer.
PostPosted: Fri Apr 15, 2016 7:40 am     Reply with quote
Try searching the forum for 'tachometer' or 'rpm', several code examples here. Quite a common 'theme'.
Jay
PostPosted: Fri Apr 15, 2016 12:42 pm     Reply with quote
Here are some threads on frequency measurement for 16F and 18F PICs:
http://www.ccsinfo.com/forum/viewtopic.php?t=29963
http://www.ccsinfo.com/forum/viewtopic.php?t=41172
http://www.ccsinfo.com/forum/viewtopic.php?t=33153
