New compiler Warning
E_Blue
PostPosted: Thu Apr 07, 2016 9:43 am     Reply with quote
I was using compiler 5.025 ok now I updated to 5.056 and new warnings appears.
Pointer types do not match
long long FlagsRules1;
long long FlagsRules2;
long long FlagsRules3;
char FlagsRules4;
#define EE_R99   3999
#define FlagsRules1_EE EE_R99 + 1
void WriteBufferEE(long StartAddress, char *DataBuffer, char ByteCount)
   //....code here
void UpdateRuleX(char Num, short Enable)
        if(Num<32)
            if(enable)
                bit_set(FlagsRules1,Num);
                bit_clear(FlagsRules1,Num);
         WriteBufferEE(FlagsRules1_EE,&FlagsRules1,4);//<--- Warning HERE
      else if(Num<64)
         //More code here..
Can somebody tell me what I'm doing wrong?
Electric Blue
PostPosted: Thu Apr 07, 2016 10:14 am     Reply with quote
Well. look at that line. You told the compiler that the function accepts
the address of a char pointer. Then you give it a parameter (the middle
one), that is the address of a 'long long'. How does the compiler know
that your 'long long' is a char buffer ? It doesn't. If you want to do that,
you have to tell the compiler what you're doing. This is done with a cast:
WriteBufferEE(FlagsRules1_EE, &(char *)FlagsRules1, 4);
PostPosted: Thu Apr 07, 2016 11:09 am     Reply with quote
and, checking for this type of problem, has been successively tightened on the last few compiler versions, so 'more warnings' will occur on older code.
E_Blue
PostPosted: Thu Apr 07, 2016 1:07 pm     Reply with quote
Ok, now I changed the code to
WriteBufferEE(FlagsRules1_EE,&(char)(FlagsRules1),4);
But generates the same amount of instructions
Do I still wrong?
Does it worth to explicitly make a cast? Because seem like the compiler was already casting to char.
Electric Blue
PostPosted: Thu Apr 07, 2016 2:13 pm     Reply with quote
First, it is a warning. These tell you something _may_ be wrong, not that it is.
Then, why should the number of instructions change?.
The key point about 'types' with pointers, is that these tell the compiler how _big_ something is. If you have a char pointer, and increment it, it moves forwards by one 'char' sized lump. If you increment a pointer to a 'long', it instead moves forward by a 'long' sized lump.
Now, your buffer 'write' code, may well internally always treat the pointers as 'char' sized, but if you hand to this a pointer to something of a different size, then you should be made aware that the sizes used in the function, _may not_ be the sizes you expect. The cast says to the compiler "I understand that I am actually going to deal with this in bytes, so don't warn me".
There are many occasions where warnings can be ignored. However, In a few months time, you might be dealing with a function, where you actually _want_ to handle the variable in larger pieces, and then the warning would say 'look out' the size being used in this function, is _not_ the one you expect....
E_Blue
PostPosted: Thu Apr 07, 2016 3:07 pm     Reply with quote
Ok, so, Whats about this?
#define APN1 Vector5 + 53//
char APN_Offset,APN_Len;
WriteBufferEE(APN1,APN_Offset,APN_Len);
Both, APN_Offset and APN_Len are char type, so Why is warning me?
Electric Blue
gaugeguy
PostPosted: Thu Apr 07, 2016 3:24 pm     Reply with quote
Because you are giving it a char when it expects a pointer to a char
jeremiah
PostPosted: Thu Apr 07, 2016 5:04 pm     Reply with quote
And in that case as it would lead to a horrible bug ( passing in a char when a pointer is expected ). You would be accessing memory that is not intended to be accessed.
