SOLVED - dsPIC33fj64GS610 - PWM generation
joseph20480
PostPosted: Sun Mar 20, 2016 9:08 am     Reply with quote
I'm trying to generate a pwm signal but nothing...
I use for that an Explorer 16 dev. board + dsPIC33fj64gs610.
I give you my code:
setup_timer3(TMR_INTERNAL|TMR_DIV_BY_1|TMR_CONTINUE_IDLE);
setup_capture(1, capture_off);
setup_compare(1,COMPARE_PWM_FAULT|COMPARE_TIMER3);
set_pwm_duty(1,1000); ;
If you see a big mistake, tell me please !
PostPosted: Sun Mar 20, 2016 10:02 am     Reply with quote
You are not giving the timer a 'time'. Second value for the setup, is the count at which it is to reset. So assuming (say) a 50% duty cycle:
setup_timer3(TMR_INTERNAL|TMR_DIV_BY_1, 2000);
Without this it'll default to 65535, so the actual pulse would be tiny.
I'm ignoring idle at the moment.
Then you have fault enabled. With this, the PWM will go off, unless the fault pin is in the clear state. Is it?. (OCFA).
joseph20480
PostPosted: Mon Mar 21, 2016 2:05 am     Reply with quote
sure.....
thanks !
