30f2010 dead time problem
torlaktr
PostPosted: Fri Mar 18, 2016 1:42 am     Reply with quote
Hello gentlemen
My problem
It gives error
Expression must evaluate to a constant :: DT too high
Why ?
#include <30f2010.h>
#device ADC=10
#fuses XT_PLL16
#fuses NOWDT
#fuses NOPROTECT
#fuses NOBROWNOUT
#fuses NOPUT
#fuses NOWRT
#fuses NODEBUG
#fuses PWMPIN
#fuses MCLR
#fuses ICSP1
#use   delay(clock=4000000)
int8 x=0;
int16 dutya = 160;//154
void main(output_drive)
setup_motor_pwm(1,MPWM_FREE_RUN  ,1,1,900);
set_motor_unit(1,2,MPWM_ENABLE ,50,50);
set_motor_pwm_duty(1,1,900);
basla:
delay_ms(5);
goto basla;
PostPosted: Fri Mar 18, 2016 3:32 am     Reply with quote
XT_PLL16 and 'clock=4000000', don't really go together. Would imply a crystal at 250KHz.
'main' cannot have a variable received 'by' it. It is always a void function both on it's receipts and returns.
Then a goto loop. Take -50 points. Goto can sometimes be used for very specific programming reasons, but generally a label, and goto, are 'near capital' offences....
Then you have one more closing bracket than opening bracket in the code posted.
The only faults are basic syntax errors:
#device ADC=10
#fuses XT_PLL16
#fuses NOWDT
#fuses NOPROTECT
#fuses NOBROWNOUT
#fuses NOPUT
#fuses NOWRT
#fuses NODEBUG
#fuses PWMPIN
#fuses MCLR
#fuses ICSP1
#use   delay(clock=64MHz) //assuming 4MHz crystal
   int8 x=0;
   while (TRUE)
      delay_ms(5);
torlaktr
Thank you
PostPosted: Fri Mar 18, 2016 4:40 am     Reply with quote
Dear Ttelmah thank you
But
set_motor_unit(1,2,MPWM_ENABLE ,50,50); very good
Im chance dead time
set_motor_unit(1,2,MPWM_ENABLE ,65,65);
Compiler error : Expression must evaluate to a constant :: DT too high
and then
Im chance dead time
set_motor_unit(1,2,MPWM_ENABLE ,66,66 ); very good
Why not accept 65 ?
and then again Im chance dead time
int8 x = 10;
set_motor_unit(1,2,MPWM_ENABLE ,x,x ); Compiler error : Expression must evaluate to a constant :: DT too high
Why ?
PostPosted: Fri Mar 18, 2016 12:16 pm     Reply with quote
The dsPIC30F2010 data sheet says:
14.7.1 DEAD-TIME GENERATORS
Each complementary output pair for the PWM module
has a 6-bit down counter that is used to produce the
dead-time insertion. As shown in Figure 14-4, the
dead-time unit has a rising and falling edge detector
connected to the duty cycle comparison output.
14.7.2 DEAD-TIME RANGES
The amount of dead time provided by the dead-time
unit is selected by specifying the input clock prescaler
value and a 6-bit unsigned value.
With 6 bits, you can only get values from 0 to 63. So you could never
get a dead-time of 66 anyway.
PostPosted: Fri Mar 18, 2016 12:54 pm     Reply with quote
Also be aware that the deadtime, is a configuration value, not something that can be changed on the fly.
This is because the PWM has to be stopped before you can update the deadtime. From the data sheet:
"Note: The user should not modify the DTCON1
values while the PWM module is operating
(PTEN = 1). Unexpected results may
occur."
torlaktr
Thank you
PostPosted: Sat Mar 19, 2016 11:47 am     Reply with quote
I drive h bridge mosfets ...
but I have to replace dead time
How can I do it ?
PostPosted: Sat Mar 19, 2016 3:04 pm     Reply with quote
You set it up once at the start. Since it is a feature of your hardware (how long is needed to ensure that one set of FETs turns off, before trying to turn the others on, it should never have to change.
If you must change it (perhaps two different hardware configurations), then you must stop the PWM (PWM_OFF), and program it to the second value. However as two distinct fixed setup commands.
