robertom
| Bootloader Pic18f2550 r232 with ccs c compiler and tera term |
Posted: Tue Mar 15, 2016 2:27 pm |
Hello everyone,
I have been trying to use the bootloader for r232 with a 18f2550, i'm using the example provided by CCS (ex_bootloader and ex_bootload) but something seems to be missing.
This is what i have tried.
ex_bootloader.c
i know that you have to load the ex_bootloader to the pic so it can receive the new program and run it as a main if not it will cycle in application function.
i use generic the fuses provided by the ccs
| Code: | #FUSES NOBROWNOUT //No brownout reset
also i use the internal oscillator
| Code: | #use delay(internal=8MHz)
i modified this in the ex_bootloader and ex_bootload file
| Code: | #elif defined(__PCH__)
#include <18F2550.h>
#fuses NOWDT,INTRC,NOLVP,NOXINST,NOVREGEN
#use delay(internal=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_B0,rcv=PIN_B1,bits=8,stream=PORT1)
#define PUSH_BUTTON PIN_A1
#endif |
ex_bootload.c
i modified it to put the same fuses
also modified this to match the other file
#endif |
the last thing i tried was defining the start of the memory to program the new code using this
| Code: | //_____________________________________________________________________________
/* map reset vector and interrupt vector */
/* 0x000-0x2FF (PLUS I ADDED 100) is used by the bootloader. The bootloader maps the original */
/* reset vector (0x000) to 0x400 and the interrupt vector (0x008) to 0x408. */
#build (reset=0x400, interrupt=0x408)
/* reserve boot block area NEED TO RESERVE EVERYTHING UNDER400 (NOT just 'til 2FF) */
/* This memory range is used by the bootloader, so the application must not */
/* use this area. */
#org 0, 0x3FF {}
//_____________________________________________________________________________ |
and the main function just print some numbers
| Code: | void main(void)
int8 i;
printf("\r\nApplication Version 1.0\r\n");
printf("%3u ",++i);
i compile it and load ex_bootloader.hex. i made the circuit to send a reset and the trigger in PIN_A1 to start the bootloader
https://www.dropbox.com/s/3ga29w1nkuddb6y/teraterm1.PNG?dl=0
i configure the tera term serial port with Xon/Xoff as flow control
https://www.dropbox.com/s/ndrky328uglvp5w/teraterm2.PNG?dl=0
i select the ex_bootload.hex file and send it to the pic,it transmit the file but the code remains the same.
Does anyone have a suggestion that i can try to get the example work?
thanks in advance for your time |
Joined: 01 Jul 2010 Posts: 9651 Location: Greensville,Ontario
Posted: Tue Mar 15, 2016 2:53 pm |
I haven't played with bootloaders but..... have you confirmed that the PB on A1 does function ?
Perhaps add code after PB is pressed to say 'PB pressed...now downloading', or something to that effect.
Also I've never been a fan of 'if else code' as usually you're onlu running ONE compiler version for that PIC so maybe you've modified it incorrectly? I'd delete the 'not my compiler' portions of the if elses....
elcrcp
Joined: 11 Mar 2016 Posts: 62 Location: izmir / Turkey
Posted: Tue Mar 15, 2016 3:17 pm |
I didn't use bootloader before but I had a work with 18f2550 and these are my config settings, you can use as referance if you suspect on your config.
(I used USB functions so I use both internal and external clocks, also it was done with another compiler =) )
| Code: | __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC4_PLL6_1L & _USBDIV_2_1L
__CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
__CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _BORV_3_2L & _VREGEN_ON_2L
__CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
__CONFIG _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
__CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L |
_________________ There is nothing you can't do if you try |
robertom
Posted: Tue Mar 15, 2016 4:14 pm |
| temtronic wrote: | I haven't played with bootloaders but..... have you confirmed that the PB on A1 does function ?
yes i have that confirmation like this
void main(void) {
if(!input(PUSH_BUTTON))
printf("\r\nBootloader Version 1.0 149\r\n");
// Let the user know it is ready to accept a download
printf("\r\nWaiting for download...");
load_program();
application();
also in the loader.c wich is included in ex_bootloader i have this
void load_program(void)
output_high(LED2);
output_low(LED2);
real_load_program();
to turn on a led for a moment, the real_load_program its where the reception of the hex are made. |
robertom
Posted: Tue Mar 15, 2016 4:16 pm |
| elcrcp wrote: | I didn't use bootloader before but I had a work with 18f2550 and these are my config settings, you can use as referance if you suspect on your config.
i could check that, i think there is something wrong with the clock because i see the data go from the pc to the pic with an osciloscope but the ack or any bit for autentification doesnt show up |
Posted: Tue Mar 15, 2016 4:44 pm |
OK... time to go back a few steps
Have you been able to compile/load and execute a simple '1Hz LED' program? All it needs to do is 'toggle' an LED on an I/O pin ?
robertom
Posted: Tue Mar 15, 2016 6:00 pm |
| temtronic wrote: | OK... time to go back a few steps
done i compile one with toggle
| Quote: | output_high(Led1);
output_low(Led2);
while(1){
delay_ms(timer1);
output_toggle(Led1);
output_toggle(Led2);
use a timer of 500 ms
and with the internal clock of 8MHZ
| Code: | #include <18F2550.h>
#device ADC=10
#use FIXED_IO( C_outputs=PIN_C1,PIN_C0 )
#define Led1 PIN_C0
#define Led2 PIN_C1 |
these are the pins im ussing for debugging the example |
robertom
Posted: Tue Mar 15, 2016 6:42 pm |
https://www.dropbox.com/s/mlv8zym0yf6g73i/2016-03-15_183355582.mp4?dl=0
here“s a video so you can see what i see,
the blue line its the data from the pic to pc and de yellow one its from the pc to the pic.
i notice now that the pic its responding with the ack and with the flags when te buffer its full and request more information but the pic doesnt show the program that i load its a basic one, just a counter this is the program without the fuses i program it on the pic to see if it was working and i recieve the data all its okay
#if defined(__PCM__)
#include <16F887.h>
#fuses NOWDT
#use delay(crystal=20MHz)
#endif
//#define BOOTLOADER_MODE2X
#org 0, 0x3FF {}
//#include <bootloader.h>
int8 i;
printf("%3u ",++i);
Posted: Tue Mar 15, 2016 7:27 pm |
hmm..
any time you use serial you need to add 'errors' to the use rs232(....options...)
I'm surprised the ccs example doesn't have it...
though as I said before, I haven't used their bootloaders yet.
robertom
Posted: Tue Mar 15, 2016 7:48 pm |
| temtronic wrote: | hmm..
so i have to modify something about the r232? seems to work fine with the data transfer and the osciloscope |
gpsmikey
Posted: Tue Mar 15, 2016 8:15 pm |
If you don't add the "errors" to the RS232 config, one missed char etc. will cause the uart to lock up. According to my manual, it says "Used to cause the compiler to keep receive errors in the variable RS232_ERRORS and to reset errors when they occur". The last part is the key which prevents the lock-up. See the #USE RS232 directive in the compiler manual (my version 4 manual is pg 139). This has bitten many people (including me). One would think it would be on by default and you would have to disable it
mikey _________________ mikey
spilz
Posted: Wed Mar 16, 2016 1:58 am |
I never use uart bootloader, only usb bootloader, but what I think :
- don't have error in rs232 bootloader part, if there is an error during transfers, it need to stop/freeze. In a "normal" program, you need to add error because you want it still run.
- Add a delay in your main loop.
- maybe try just to load a blink led example with bootloader, it helped me to debug oscillator issue or change after load, the frequency of blink will show you better than a printf.
- don't forget that the fuse setup is the bootloader one, not the load program one.
- did you check the address where the program is load ?
- did you read the program memory after loading ? To check if it's well written |
SeeCwriter
Posted: Wed Mar 16, 2016 11:31 am |
Do the following bootloader and application work?
Bootloader:
#if !defined(__PCH__)
#error Compiler Not Supported!
#endif
#device ADC=10
#define _bootloader
#fuses PUT, HSH, NOWDT, NOXINST, NOVREGEN
// NOTE - User must include bootloader.h in application program
#include <loader.c>
#use delay(clock=8000000,internal=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,ERRORS)
#INT_GLOBAL
void isr(void){
jump_to_isr(LOADER_END+9);
#org LOADER_END+2, LOADER_END+4
void application(void) {
while(TRUE);
// Enter Bootloader if PUSH_BUTTON Pin is low after a RESET.
if( !input(PUSH_BUTTON) )
printf("\r\nBootloader v1.0\r\n");
printf("Waiting for download...");
load_program();
application();
Application:
#device ADC=10
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PORT1)
int8 i;
while( TRUE ) {
printf( "%3u ", ++i );
spilz
Posted: Mon Mar 21, 2016 4:27 pm |
I'm not able to compile your code,
here are code that works :
bootloader : | Code: | #include <18F2550.h>
#fuses NOWDT
// #use delay(crystal=20MHz)
#define PUSH_BUTTON PIN_C0
#define _bootloader
#include <loader.c>
#org LOADER_END+2,LOADER_END+4
while(TRUE);
void main(void) {
printf("\r\nTest 1.0\r\n");
delay_ms(2000);
printf("\r\nBootloader Version 1.0\r\n");
load_program();
application();
#int_global
void isr(void) {
jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
Application : | Code: | #include <18F2550.h>
#fuses NOWDT
#define LED_PIN PIN_B7
void main(void) {
int i = 0;
while(true){
printf("Test %u\r\n",i++);
output_toggle(LED_PIN);
be careful how you load your application code,
did you check that you send data at 9600 baud ?
what do you use to load it ? |
robertom
Posted: Tue Mar 29, 2016 10:58 pm |
| spilz wrote: | Hi,
#fuses NOWDT
#define _bootloader
#include <loader.c>
while(TRUE);
void main(void) {
delay_ms(2000);
load_program();
application();
#int_global
void isr(void) {
#fuses NOWDT
void main(void) {
int i = 0;
while(true){
hi, i compiled your code but i tried to load the program but it does the same, maybe its something about my wiring. Does the ftdi the dtr and cts has to be connected ?
For loading the program i tried siow and TeraTerm 4.73. i configure the baudd 9600, data 8 bit, parity none, stop 1 bit, flow control xon/xoff. |
