e3mini development board
johnglen
PostPosted: Sat Feb 27, 2016 11:42 am     Reply with quote
Bought the Embedded C Programming book and e3mini bundle. Having a problem loading the program onto the e3mini
When I try to load the program, I get a "Timeout while downloading" - the program doesn't load to the e3mini.
I have reloaded the e3mini driver, and it shows up correctly in Device Manager. Also - after it stops downloading, then the Serial I/O Monitor shows me the test program running. The test program functions - I can press the C1 / C2 buttons and the the pot input show a response.
Any suggestions on why I can't download the s/w to the e3mini board?
johnglen
PostPosted: Sat Feb 27, 2016 11:46 am     Reply with quote
Further to my last - the book (Exercise 1-1, Step 6) indicates that I should select "PROGRAM CHIP" and then "E3 BOOTLOAD"
On my version of the PICC Compiler, when I select PROGRAM on the Compile Menu at the top of the screen, I don't get "E3 BOOTLOAD". I see:
"E3 USB Loader"
"ICD"
"Bootloader"
"RapidUSB Loader"
PostPosted: Sat Feb 27, 2016 1:07 pm     Reply with quote
hmm I'd be asking CCS directly, though you might try searching for 'e3mini' here.
From a quick look at their ad it appears that it has a bootloader already installed so I assume you download YOUR program via the USB port.
With that I'd try the 'e3 usb loader'. Hopefully there's better descriptions as to what is what, what does what, etc. if not, as I already said, contact CCS ask for help.
edit:
maybe look here ??
http://www.ccsinfo.com/e3mini-board.php
watch/listen to the videos ??
Jay
wiztizGT
PostPosted: Thu Nov 10, 2016 8:08 am     Reply with quote
I am having the same issue. Were you able to resolve the problem?
CCS
Windows 10 USB 3.0 Bug
PostPosted: Thu Nov 10, 2016 1:47 pm     Reply with quote
There is a bug in the newest Microsoft USB drivers. When Windows upgrades the OS it installs their drivers by default. Go to the website of the USB device manufacturer and download and install their driver. For example
a lot of people with this problem have Intel chips. The Intel web site has a utility that will update all your drivers with Intel versions.
An alternative for some people is to go into BIOS and disable XHCI for the USB 3.0 ports. Not all BIOS versions have this option. This is only a problem on USB 3.0 ports using the generic Microsoft driver.
This problem only affects CDC devices so other devices will seem to work on the USB 3.0 port with the bad driver.
Custom Computer Services, Inc.
262-522-6500
PO Box 2452
Brookfield, WI 53008
wiztizGT
PostPosted: Sat Nov 12, 2016 9:43 am     Reply with quote
Thanks! I have an Asus motherboard with ASmedia USB ports with ASmedia drivers. It seems to work fine in those USB ports.
wiztizGT
PostPosted: Sat Nov 12, 2016 7:05 pm     Reply with quote
So it seemed to work well on an ASmedia port for a while then the serial port communication started getting flaky and then it started throwing errors on download. I disabled XHCI in the BIOS and now it seems to be working well on all ports. I will post again if it starts acting up.
wiztizGT
e3mini died???
PostPosted: Sat Nov 19, 2016 8:55 pm     Reply with quote
Everything seemed to be fine until earlier today. I was loading the program and nothing came out on the serial port. Next thing I know I have the Blue Screen of death and it appears as if my entire USB controller died. I got everything running again except for the E3. The computer does nothing when I plug it in, and the compiler won't recognize it.
Any ideas on how to recover the e3?
PostPosted: Sun Nov 20, 2016 12:03 am     Reply with quote
See this thread and the links in it. I don't know if this will help but it might:
http://www.ccsinfo.com/forum/viewtopic.php?t=53371
wiztizGT
PostPosted: Sun Nov 20, 2016 8:46 am     Reply with quote
Thanks for the suggestion PCM programmer.
I actually went through that post while I was trying to get everything working again.
I have a hunch the board might be shot. I will take it to work tomorrow and probe the voltages.
wiztizGT
Fix
PostPosted: Tue Nov 29, 2016 7:09 pm     Reply with quote
I contacted tech support. They suggested that I hold both buttons down when I plugged the board into the computer.
It worked! I was able to load a program and it seems to be running normally again.
j_andrew
Re: e3mini development board
PostPosted: Sun Dec 25, 2016 9:44 pm     Reply with quote
Did you ever get an answer to your problem? I too just bought the book and the e3mini board and am getting the timeout error msg and production test sequence output on the monitor.
jurie
e3 time out errors problems
PostPosted: Tue Sep 05, 2017 12:02 pm     Reply with quote
Yellow led is blinking.
c1 and c2 holding when connecting usb.
Yellow led blinking by progaming timeerror.
My pc is a apple with vmware windows 10.
Mplab, icd3, icd64, 18f45k22 board works great on windows 10.
Hardware Overview:
Modelnaam: MacBook Pro
Modelaanduiding: MacBookPro13,3
Processornaam: Intel Core i7
Processorsnelheid: 2,7 GHz
Aantal processors: 1
Totale aantal cores: 4
L2-cache (per core): 256 KB
L3-cache: 8 MB
Geheugen: 16 GB
Opstart-ROM-versie: MBP133.0226.B25
SMC-versie (systeem): 2.38f7
Serienummer (systeem): C02T5036GTFM
Hardware-UUID: 5A8F99EB-5435-5ACD-BE79-30ABF3BD10CB
USB 3.0-bus: usb-c to usb
Besturingsbestand hostcontroller: AppleUSBXHCISPT
PCI-apparaatcode: 0xa12f
PCI-revisiecode: 0x0031
PCI-fabrikantcode: 0x8086
iBridge:
Productcode: 0x8600
Fabrikantcode: 0x05ac (Apple Inc.)
Versie: 1.01
Snelheid: Maximaal 480 Mb/sec
Fabrikant: Apple Inc.
Locatiecode: 0x14200000 / 40
Beschikbare stroom (mA): 500
Vereiste stroom (mA): 0
Extra stroom in werking (mA): 0
Ingebouwd: Ja
bdeb
Work-around
PostPosted: Sun Nov 26, 2017 11:18 am     Reply with quote
I'm having the same problems.
Since I have loads of test- and production thingies connected via USB, I simply do not dare to tinker with the root drivers in my computers.
Tried connecting E3mini via old (non-USB3) hub - works like a charm!
Hope this helps:
/Björn
