[SOLVED] Query all states of I/O pins...
ELCouz
PostPosted: Fri Dec 11, 2015 5:02 pm     Reply with quote
Is a better way to know pins status than input_state(PIN_A1)...input_state(PIN_A2)...etc
I want to make a small debug code that write all the current states of I/O pins on UART.
thanks!
Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy!
PostPosted: Fri Dec 11, 2015 7:53 pm     Reply with quote
My first try would be to dump a listing of a small program to see how CCS does it per pin then decide if you could go 'port by port' with a similar strategy.
Currently trying how to repair a busted 40' truss and put the rockshaft onto my #1 tractor at the same time....so PIC time is very very little...
sigh
PostPosted: Fri Dec 11, 2015 8:01 pm     Reply with quote
CCS doesn't have an input_state_x() function. You can make one for
each port as shown below. Or you can skip the function and just read
directly from each Portx register.
// This function reads Port B without changing the TRIS.
int8 input_state_b(void)
#byte PortB = getenv("SFR:PORTB")
return(PortB);
PostPosted: Sat Dec 12, 2015 2:22 am     Reply with quote
Add (of course), that if you have fast_io enabled, then the CCS input_b function, will give the input state of the whole port.....
PostPosted: Sat Dec 12, 2015 5:50 am     Reply with quote
hmm my mind is elsewhere..... I was thinking he needed to know which pins were set for inputs vs outputs.
Jay
ELCouz
PostPosted: Sat Dec 12, 2015 8:22 am     Reply with quote
Thanks guys!
What about partial query of a port?
Let's say I have some defines like this:
#define LED1 PIN_A0
#define LED2 PIN_A6
#define LED3 PIN_B2
#define LED4 PIN_C3
//and I want to query the status of those pins.
for (i=1;i<=4;++i)
   printf("%u\r\n",input_state(LEDS+i));
// how its possible to cycle through LEDS1 to LEDS4 defines?
I tried google-ing "increment define loop" or "increment variable name" of course it only showed how to i++ a variable value on CCS.
Thanks again guys!
Regards,
Laurent
PostPosted: Sat Dec 12, 2015 11:07 am     Reply with quote
you're making it far to complicated,go back to KISS principle....
just create a function that contains...
printf("%u\r\n",input_state(LED1));
printf("%u\r\n",input_state(LED2));
printf("%u\r\n",input_state(LED3));
printf("%u\r\n",input_state(LED4));
far simpler to implement,
easier to understand,
quick to edit to add a pin or two...
probably FASTER than any 'higher level' coding as well....
Jay
PostPosted: Sat Dec 12, 2015 11:23 am     Reply with quote
and also worth understanding that the 'single pin' version is solved at compile time, and will only use one or two instructions. One involving using a variable, will have to split the variable up into port and pin number, then do indexed I/O to access the port, then use a variable to access the pin. Literally dozens of instructions.....
ELCouz
PostPosted: Sat Dec 12, 2015 12:02 pm     Reply with quote
Jay
It was just a quick example with leds to understand... but I have more than 30 readings to take and they are not sequential (spanned across multiple ports)!
I just wanted to see if there was a cleaner way than copy pasting 30 lines of repeatable code Smile
Thanks for the clarification guys!
Regards,
Laurent
PostPosted: Sat Dec 12, 2015 3:25 pm     Reply with quote
As a comment though, think again.
If you are reading various bits from multiple ports, just read all the ports directly, using code like PCM_programmer has given, and store/print these. Even the biggest chips only have a handful of ports....
ELCouz
PostPosted: Sat Dec 12, 2015 3:30 pm     Reply with quote
I misread the PCM programmer comment in code
I was afraid it will change the state of the pins (like input)...
Turns out its just fine!
Sorry my bad! Thanks all of you guys Smile
Case closed Very Happy
Regards,
Laurent
