dsPIC30F5015 in debug mode
stoyanoff
PostPosted: Wed Dec 09, 2015 4:13 am     Reply with quote
Greetings! I'm using MPLab v8.91, CCS v5.025 and dsPIC30F5015. When I'm using the motor control unit and I'm experiencing a small problem - the debugger doesn't show the current state of PORTE. For example if I set the PCDs to 500 (pwm 2500) and I have this code:
if(PORTE!=0)
   delay_us(1);
When I set a breakpoint to the delay it triggers but in the view window PORTE is 0! I test on a pcb and I have proper pwm on the outputs! Why I don't see the changes in the debug mode ? I tested when the debugger is freezing all the peripherals and when it doesn't - no change!
Is this a bug or I'm doing something wrong ?
Thanks!
PostPosted: Wed Dec 09, 2015 4:49 am     Reply with quote
Show us your definition of 'PORTE'.
RF_Developer
PostPosted: Wed Dec 09, 2015 5:06 am     Reply with quote
Also, the debugger is not a hardware debugger, it's a software monitor. The peripherals are not "frozen" at a breakpoint, they stay running.
The values for peripherals, including timers/counters, shown while debugging are a snap shot of their values at the time the debugger code read them, which is quite a long time after the breakpoint happened. This means the value you see may not be consistent with the value at the breakpoint.
stoyanoff
PostPosted: Sat Dec 12, 2015 12:08 pm     Reply with quote
#word PORTE = getenv("SFR:PORTE")
This is bad! How can I be sure everything is configurated correctly. I can see the output pulse, but this is not the whole thing. I need to have correct update time, correct errors check and so on...
PostPosted: Sat Dec 12, 2015 12:25 pm     Reply with quote
This is the 'snare' of the ICD. In the past you used to get genuine hardware ICE units, which actually could snapshot the memory, and ports at specific points. Unfortunately the ICD can't do this.
The way you can record things is to do it yourself. In your code, at the point where you read the port to test something, write the value read, into an array. You can then stop, and look at the array, and see what the code actually 'saw' at this instant....
stoyanoff
PostPosted: Sun Dec 13, 2015 10:37 am     Reply with quote
You mean I have to read the value of the register before the breakpoint occurs?!
PostPosted: Sun Dec 13, 2015 11:46 am     Reply with quote
You read the port at the point in the code where you want to know what the code is seeing.
You can break at any point you want after this, and look at the value that was read.
