Stream not working
Jody
Stream not working
PostPosted: Mon Dec 07, 2015 7:06 am     Reply with quote
I have two uarts and two stream outputs...
when I want to send something over the Port2 output nothing happened.
When I disable (the #use rs232 line removed) there is data at the output port.
The same happened when I do this for port1...
What am I doing wrong with the stream assignment or use??
Test code:
main.c
#include <main.h>
   setup_adc_ports(sAN15);
   setup_timer_4(T4_DISABLED,0,1);
      printf(PORT1"Port1\n");
      printf(PORT2,"Port2\n");
main.h
#include <18F87J50.h>
#device adc=16
#use   delay(oscillator=40MHz, clock=48MHz)
#use rs232(uart1,baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PORT1)
#use rs232(uart2,baud=9600,parity=N,xmit=PIN_G1,rcv=PIN_G2,bits=8,stream=PORT2)
Regards,
Jody
PostPosted: Mon Dec 07, 2015 7:58 am     Reply with quote
Syntax, syntax, syntax......
The printf that talks to streams is _fprintf_.
#include <main.h>
      fprintf(PORT1,"Port1\n"); //also ',' missing here
      fprintf(PORT2,"Port2\n");
printf has the ability to work with named output functions as the first parameter, so the compiler does not complain - just doesn't work. It routes to the default port.
Jody
PostPosted: Mon Dec 07, 2015 8:08 am     Reply with quote
Aaaah THANKS!!!!!!
And still no I know what to do I can't find it in the manual that you has to use the frpintf if you use different streams..
But we got a forum!!!!!!
REALLY thanks!!!
Regards,
Jody
PostPosted: Mon Dec 07, 2015 8:13 am     Reply with quote
Manual entry for printf:
Syntax:
       printf (string)
         or
       printf (cstring, values...)
         or
       printf (fname, cstring, values...)
       fprintf (stream, cstring, values...)
Parameters:
       String is a constant string or an array of characters null terminated.
       Values is a list of variables separated by commas, fname is a function
       name to be used for outputting (default is putc is none is specified.
       Stream is a stream identifier (a constant byte). Note that format
       specifies do not work in ram band strings.
Which one uses 'stream'......
Jody
PostPosted: Mon Dec 07, 2015 9:10 am     Reply with quote
:oops: :oops: :oops: :oops:
Your right!!!
I just saw it.....
Sorry, I am really ashamed...
Regards,
Jody
PostPosted: Mon Dec 07, 2015 11:34 am     Reply with quote
Very Happy
Unfortunately though, I feel the manual should actually show it in the samples. However the examples do.
The manuals for CCS are not as good as they were when the compiler first started, and some things are designed to encourage head scratching....
Have fun.
