V5051 enum (typecast) problems?
Torello
PostPosted: Thu Dec 03, 2015 3:39 am     Reply with quote
Compiling same source with v5051 instead of v5048 raises warnings:
"Assignment to enum is not of the correct type". Ok, I am assigning an int8 variable to a Enum variable. Never got any warning for that. But now, as code snippet below shows, the warning are there, but not very consistent.
-note: Function Com_FlashDataTx(int16) returns int8
Any thoughts?
Enum ExitCodeType {zi_Ok=0, zi_AcqErr=1, zi_AcqTO=2, zi_PwrLo=3, zi_RstCpu=4, zi_Done=5,
         zi_InfiniteSleep=6, zi_UserStore=7, zi_CmdTO=8, zi_ReJoin=9, zi_OORnge=10,
         Zi_Fault=11, zi_GpsDM=12};
   ExitCodeType ExitCode;
ExitCode = com_FlashDataTx(w1);     //-> raises warning
ExitCode = com_FlashDataTx(0);       //-> no warning
ExitCode = com_FlashDataTx(65000); //->no warning
ExitCode = 1;                                    //->no warning
ExitCode = j;                                     //->raises warning (int8 j;)
ExitCode = (ExitCodeType)j;               //->raises warning
Regards, Edwin. PCWHD v5.114
PostPosted: Thu Dec 03, 2015 3:46 am     Reply with quote
It's a warning.
A poster here explicitly asked for this to be added. It does draw attention to the fact that you are assigning to an enum, and not using it's names to do so.
Just disable this warning, or ignore it.
Torello
PostPosted: Thu Dec 03, 2015 3:48 am     Reply with quote
Quick (dirty?) solution:
- declare ExitCode not as EXitCodeType but as int8
Thus:
int8 ExitCode
Torello
PostPosted: Thu Dec 03, 2015 3:50 am     Reply with quote
Hi Ttelmah,
I can understand this, but the warning is not consistent.
Al least all 5 of the given assignments should then give this warning.
Assignment 6 should be OK, if an enum typecast is allowed in C
PostPosted: Thu Dec 03, 2015 4:02 am     Reply with quote
The problem may be that you actually have not declared an ExitCodeType properly. You have declared an enum type, but are then using this as if it is a type (it isn't). I'm surprised the compiler doesn't complain about this.
enum  ExitCodeType {zi_Ok=0, zi_AcqErr=1, zi_AcqTO=2, zi_PwrLo=3, zi_RstCpu=4, zi_Done=5,
//The enumeration type at this point is defined as 'enum ExitCodeType'
//should technically be used as:
   enum ExitCodeType ExitCode;
ExitCode = (enum ExitCodeType)j;               //->raises warning
I suspect you will then find the warnings consistent....
To generate a type, it should instead be done with a Typedef:
typedef enum {zi_Ok=0, zi_AcqErr=1, zi_AcqTO=2, zi_PwrLo=3, zi_RstCpu=4, zi_Done=5,
         Zi_Fault=11, zi_GpsDM=12} ExitCodeType;
So the reason the warnings are inconsistent, is the compiler is confused by the declarations.
