Jody
| Parsing string to function.. what am i doing wrong? |
Posted: Wed Dec 02, 2015 4:27 pm |
Want to parse a string to a function..
The function is in another file and it looks like that that is the problem...
I have include all mine files... anyone a idea??
Main.c:
#include <main.h>
#include <commands.c>
#include <stdlib.h>
#include <string.h>
#include <stddef.h>
char slave_1[3] = "323";
char slave_2[5] = "green";
char slave_3[3] = "on";
setup_adc_ports(sAN15);
setup_timer_4(T4_DISABLED,0,1);
setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
commands(&slave_1, &slave_2, &slave_3);
Commands.c:
| Code: | #include <string.h>
#include <stdlib.h>
char string_rs485[MAXINPUTBUF];
/* The following typedef's should be adjusted for the particular platform.
* CRC-8 x^8 + x^2 + x + 1
* prototypes */
int generate_8bit_crc(char* data, int16 length, int pattern)
int *current_data;
int crc_byte;
int16 byte_counter;
int bit_counter;
current_data = data;
crc_byte = *current_data++;
for(byte_counter=0; byte_counter < (length-1); byte_counter++)
for(bit_counter=0; bit_counter < 8; bit_counter++)
if(!bit_test(crc_byte,7))
crc_byte <<= 1;
bit_test(*current_data, 7 - bit_counter) ?
bit_set(crc_byte,0) : bit_clear(crc_byte,0);
continue;
crc_byte <<= 1;
crc_byte ^= pattern;
current_data++;
crc_byte <<= 1;
continue;
crc_byte <<= 1;
return crc_byte;
|Addr | commando | status | CRC |
| 001 | groen | off | 034 |
void commands(char *slave_address, char *slave_commando, char *slave_status)
char space[1], slash_n[2], crc_string[3];
int16 crc_calculated, lengte;
strcpy(space, " ");
strcpy(slash_n, "\n ");
strcat(string_rs485, *slave_address);
strcat(string_rs485, space);
strcat(string_rs485, slave_commando);
strcat(string_rs485, slave_status);
crc_calculated = generate_8bit_crc(string_rs485, lengte, 0x107);
ITOA(crc_calculated, 10, crc_string );
strcat(string_rs485, crc_calculated);
strcat(string_rs485, slash_n);
Main.h:
#include <18F87J50.h>
#device adc=16
#device PASS_STRINGS=IN_RAM
#define MAXINPUTBUF 20
Regards,
Jody |
jeremiah
Posted: Wed Dec 02, 2015 5:54 pm |
I haven't looked through the rest of your code, but right off the bat there is some C programming 101 stuff:
The string "323" is 4 characters long and "green" is 6 characters long.
Possible solutions:
char slave_1[4] = "323";
char slave_2[6] = "green";
or
char slave_1[] = "323";
char slave_2[] = "green";
char slave_3[] = "on";
Posted: Wed Dec 02, 2015 5:58 pm |
In addition to that,
The first line below has a bug. A pointer is passed by name, not
by *name. Remove the * on the first line:
| Quote: | strcat(string_rs485, *slave_address);
strcat(string_rs485, space); |
Also, this line is wrong. Pointers to arrays are passed by name, and
not with &name. Remove all the & from the line below:
| Quote: | | commands(&slave_1, &slave_2, &slave_3); |
Jody
Posted: Thu Dec 03, 2015 4:09 am |
Yes!!
That did it...
Now reading it it all make sense.
I was fiddling half a day with it!
Thanks for pointing me in the right direction!!!
Regards,
Jody |
