Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
La Crosse TX20 anemometer
Post new topic   Reply to topic    CCS Forum Index -> Code Library
picprogrammer
PostPosted: Sun Sep 20, 2015 11:34 am     Reply with quote
Here my code by easy made because John Geek made a nice description. I did not implemented the checksum
// La Crosse TX20
// The datagram is 41 bits long and contains six data sections. Each bit is almost exactly 1.2msec
// Source:
// https://www.john.geek.nz/2011/07/la-crosse-tx20-anemometer-communication-protocol/
#include <18F2680.h>
#device adc=16
#FUSES WDT512                   //Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES PUT                      //Power Up Timer
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC                //Timer1 configured for higher power operation
#FUSES BBSIZ1K                  //1K words Boot Block size
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES STVREN                   //Stack overflow will rest
#use delay(int=8000000)
#use rs232(baud=38400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
#define  tx20   pin_B7
int1 TX20_bit[50],
     tx20_low,
     read_tx20;
int8 tx20_bitcounter;
 *   0.5uS*8 = 4uS increase overflow *FFFF-300 = 1.2ms
#int_TIMER3
void TIMER3_isr()
static int1 a;
  if (tx20_bitcounter < 43)
    read_tx20 = true;
    if (a =!a)output_high(pin_B6);
    else output_low(pin_B6);
  set_timer3(0xFFFF-297);
 *  Description : TX20 decoder
int8 bittcopy(int8 start,int8 aantal,int8 invert) //from, aantal, inverted
signed int8 k;
int8 a=0,answer=0;
  for (k=start;k<=start+aantal-1;++k)
    if (invert)
      if (!TX20_bit[k]) bit_set(answer,a);
      if (TX20_bit[k]) bit_set(answer,a);
    a++;
  return(answer);
 *  Main
int8 k,rc;
   rc = RESTART_CAUSE();
   if (rc == WDT_TIMEOUT) printf("WDT\n\r");
     else printf("rc=%u\n\r",rc);
  setup_wdt(WDT_ON);
  setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);      //32.7 ms overflow
  setup_timer_2(T2_DIV_BY_16,0xFF,8);         // routine elke 0.2uS *div16 *255*16= = 16.32mS mS
  setup_timer_3(T3_INTERNAL|T3_DIV_BY_8);     // 0.5uS*8 = 4uS increase overfow *FFFF = 262ms
  disable_interrupts(INT_TIMER1);
  disable_interrupts(INT_TIMER2);
  enable_interrupts(INT_TIMER3);
  disable_interrupts(INT_EXT);
  disable_interrupts(INT_RDA);
  setup_oscillator(OSC_8MHZ|OSC_TIMER1|OSC_31250|OSC_PLL_OFF);
  printf(__DATE__);
  printf("\n\r" );
  printf(__TIME__);
  printf("La Crosse TX20 1.0\n\r");
    restart_wdt();
    if (read_tx20)
      read_tx20 = false;
      TX20_bit[tx20_bitcounter] = input(tx20);
      tx20_bitcounter++;
    if (input(tx20) && tx20_low)
      tx20_low = false;
      if (tx20_bitcounter > 41)
        tx20_bitcounter=0;
        set_timer3(0xFFFF-150);
    if (!input(tx20) )
      tx20_low = true;
    if (tx20_bitcounter == 42)
      tx20_bitcounter++;
      int8 wind1,wind2,dir1,dir2;
      k= bittcopy(0,5,1); //from, aantal, inverted
      dir1 = bittcopy(5,4,1); //from, aantal, inverted
      wind1 = bittcopy(9,12,1); //from, aantal, inverted
      dir2 = bittcopy(25,4,0); //from, aantal, inverted
      wind2 = bittcopy(29,12,0); //from, aantal, inverted
      if( dir1 == dir2 && wind1 == wind2 && k==4)
        printf("Direction= %u  \n\r",dir1);
        printf("speed    = %u  \n\r",wind1);
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
