help with asm code
kmp84
help with asm code
PostPosted: Mon Sep 14, 2015 7:28 am     Reply with quote
Hello developers,
Can anybody help me with this asm code?
//transmit
SendHostByte:
    clrwdt
    btfss   UxPIR, UxTXIF      ; Write only if TXREG is ready
    bra     $-2
    movwf   UxTXREG           ; Start sending
//receiv
ReadHostByte:
    btfsc   UxRCSTA, OERR       ; Reset on overun
    reset
WaitForHostByte:
    clrwdt
    btfss   UxPIR, UxRCIF       ; Wait for data from RS232
    bra     WaitForHostByte
    movf    UxRCREG, W          ; Save the data
    movwf   RXDATA
    return
I want to modify above code to support rs485 halfduplex direction control pin.
PostPosted: Mon Sep 14, 2015 8:04 am     Reply with quote
Why bother ? CCS does have complete, working C code for RS485 ! It's one of their great examples in the 'examples' folder...
However if you really, want to modify that assembler, try the Microchip Assembler forum or if you need to cheat, simply compile the CCS rs485 example and dump the listing.It's all there.
Jay
kmp84
PostPosted: Mon Sep 14, 2015 8:23 am     Reply with quote
Thanks Mr."temtronic"! It is a good idea.
kmp84
PostPosted: Wed Sep 16, 2015 2:44 am     Reply with quote
Hello All,
I have no success with this asm code. I'm trying to modify Microchip's AN1310 bootloader code to work over half duplex rs485 network with direction control on PIN_D2.
RF_Developer
PostPosted: Wed Sep 16, 2015 2:57 am     Reply with quote
This is is much better question - its about what you are trying to do, not just what isn't working.
I've got that working. Not a big problem. I don't think I used D2, but that's easily changed. I'm not sure I can share it, however. I'll see what I can do.
Hint: I didn't do it byte by byte. I left the link in receive except when sending something.
PostPosted: Wed Sep 16, 2015 4:54 am     Reply with quote
Now that we know what you're up to.... why not just use the CCS bootloader ? I'm sure someone here has already got it running on RS485. Maybe search this forum or the code library for working solutions.
Jay
