Damien Guest
| Driver LCD based on Toshiba T6963c |
Posted: Mon Jan 14, 2002 12:12 am |
Does anyone have a driver for the Graphiqe LCD toshiba T6963 C
driver based
I want to find exemple to write; circle, dot line etc ..
Thank for all
___________________________
Original Post ID: 1993 |
Todd C. Micallef Guest
| Re: Driver LCD based on Toshiba T6963c |
Posted: Mon Jan 14, 2002 7:42 am |
:=Does anyone have a driver for the Graphiqe LCD toshiba T6963 C
:=driver based
:=I want to find exemple to write; circle, dot line etc ..
:=Thank for all
Try the following link...
Also, a great place to go is the Pic /Ubicom developers website at...
<a href="http://www.devrs.com/pic/" TARGET="_blank">http://www.devrs.com/pic/</a>
Original Post ID: 1997 |
johnpcunningham Guest
Posted: Fri Jan 25, 2002 2:04 pm |
YEs, I have writen my own and it works well
Original Post ID: 2222 |
Analyzer
Posted: Wed Nov 26, 2003 6:31 pm |
Sir,
Would you share your T6963C library with us please? I can not understand Pbp.
Analyzer. |
Analyzer
Posted: Thu Nov 27, 2003 8:29 am |
Thank you for your quick reply.I didnt pay attention to date The c2c and hi-tect is not close enough to ansi c compiler and also ccs so i decided to write my own code.I found a pdf of steve lawther so i started to work.If somebody has an instant ccs c solution for this controller, it would be veery nice
Analyzer |
john zar Guest
| code for t6963c with CCS compiler |
Posted: Wed Sep 29, 2004 9:22 am |
| I have problems with my graphic lcd based in t6963c. Someone have the code necesary to drive this controller |
