Dynamixel servos can be controlled with pic18F4550
*estudiante
PostPosted: Mon Aug 10, 2015 8:38 pm     Reply with quote
good morning everyone
I have a problem. I am a student, and I'm doing a project for semester, a robotic arm.
the problem is the following :
I would use Dynamixel servomotors especially the AX-12A, I want to control by means of pic18F4550 and using a program in CCS.
but I find information about it
anyone can help me please, an example, someone who has already tried
please help
thanks for your help
dyeatman
PostPosted: Mon Aug 10, 2015 9:00 pm     Reply with quote
You haven't even tried to search at all have you?
There is lots of info available for the AX-12...
Try searching here and on Google and to earn your
grade rather than us doing it for you.
To get you started here is the manual for the servo.
http://support.robotis.com/en/product/dynamixel/ax_series/dxl_ax_actuator.htm
Here is a tutorial:
http://forums.trossenrobotics.com/tutorials/how-to-diy-128/controlling-ax-12-servos-3275/
Google and Forum Search are some of your best tools!!!!
*estudiante
thanks for your prompt response
PostPosted: Tue Aug 11, 2015 5:51 am     Reply with quote
Thanks friend, I will continue looking for information. Your contribution to been good.
Anything I tell my doubts here
PostPosted: Tue Aug 11, 2015 8:51 am     Reply with quote
It is controlled using standard serial at 5v. So it really is just a matter of sending it the bytes you need. #USE RS232 can drive it directly.
You just wire the TX and RX line on the UART together, and connect this to the data line on the device. Remember though that used like this you will receive every byte you send, which makes parsing the replies harder work. Alternatively a simple TTL buffer can be used to switch off the receive when sending, and implement buffer control on the PIC, as if you were using half duplex RS485.
