Code Conversion
melissa creek
Code Conversion
PostPosted: Tue Feb 18, 2003 2:34 pm     Reply with quote
I have a program which works brilliantly on a 16F84 but am having trouble converting it to a 16F873. On the 84 I use 0-3 on port A and 0-3 on port B for a keypad. The only difference that I can see between the 84 and the 873 is port A is a 6-bit wide port.
Can anyone suggest why I an getting no outputs on the ports on the 873?
___________________________
Original Post ID: 11841
Eric Minbiole
Re: Code Conversion
PostPosted: Tue Feb 18, 2003 2:50 pm     Reply with quote
:=Can anyone suggest why I an getting no outputs on the ports on the 873?
Many of the pins on the 87x default to analog inputs on power up, so you have to manually set them to be digital I/O. Try adding:
SETUP_ADC_PORTS(NO_ANALOGS);
Original Post ID: 11843
Re: Code Conversion
PostPosted: Tue Feb 18, 2003 2:54 pm     Reply with quote
:=Hi,
:=I have a program which works brilliantly on a 16F84 but am having trouble converting it to a 16F873. On the 84 I use 0-3 on port A and 0-3 on port B for a keypad. The only difference that I can see between the 84 and the 873 is port A is a 6-bit wide port.
I don't think your schematic is correct. Here's a copy
of it, from your previous post.
In the 16F873 data sheet, it shows the pinout for Port A
is pins 2-7. You've got them as 13-18.
<PRE>
+5--20-|Vdd |
+5---1-|Mclr |
Gnd---8-|Vss |
Gnd--19-|Vss |
4MHz--10-|Xtal |
4MHz---9-|Xtal |
| 16F873 |
| A0|-15--11-|D4 |
| A1|-16--12-|D5 |
| A2|-17--13-|D6 |
| A3|-18--14-|D7 |
| | | |-3--20K pot
| A4|-14---6-|EN |
| A5|-13---4-|RS |
| | +5-2-| |
| | Gnd-1-| |
| | Gnd-5-| |
| | | DISPLAY |
</PRE>
Also, you will need the pull-up resistor to +5v on RA4.
Original Post ID: 11844
Eric Minbiole
Oops...
PostPosted: Tue Feb 18, 2003 3:38 pm     Reply with quote
Just found your previous post and that you already have the port configured as digital I/O.
Original Post ID: 11849
