Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
SSD1306 4 Wire SPI OLED Library
sshahryiar
PostPosted: Tue Apr 28, 2015 9:53 am     Reply with quote
SSD1306.h
#define D0 pin_B0
#define D1    pin_B1
#define RST pin_B2
#define DC  pin_B3
#define SCL D0
#define SDA D1
#define DAT TRUE
#define CMD FALSE
#define Set_Lower_Column_Start_Address_CMD 0x00
#define Set_Higher_Column_Start_Address_CMD 0x10
#define Set_Memory_Addressing_Mode_CMD 0x20
#define Set_Column_Address_CMD 0x21
#define Set_Page_Address_CMD 0x22
#define Set_Display_Start_Line_CMD 0x40
#define Set_Contrast_Control_CMD 0x81
#define Set_Charge_Pump_CMD 0x8D
#define Set_Segment_Remap_CMD 0xA0
#define Set_Entire_Display_ON_CMD 0xA4
#define Set_Normal_or_Inverse_Display_CMD 0xA6
#define Set_Multiplex_Ratio_CMD 0xA8
#define Set_Display_ON_or_OFF_CMD 0xAE
#define Set_Page_Start_Address_CMD 0xB0
#define Set_COM_Output_Scan_Direction_CMD 0xC0
#define Set_Display_Offset_CMD 0xD3
#define Set_Display_Clock_CMD 0xD5
#define Set_Pre_charge_Period_CMD 0xD9
#define Set_Common_HW_Config_CMD 0xDA
#define Set_VCOMH_Level_CMD 0xDB
#define Set_NOP_CMD 0xE3
#define Horizontal_Addressing_Mode 0x00
#define Vertical_Addressing_Mode 0x01
#define Page_Addressing_Mode 0x02
#define Disable_Charge_Pump 0x00
#define Enable_Charge_Pump 0x04
#define Column_Address_0_Mapped_to_SEG0 0x00
#define Column_Address_0_Mapped_to_SEG127 0x01
#define Normal_Display 0x00
#define Entire_Display_ON 0x01
#define Non_Inverted_Display 0x00
#define Inverted_Display 0x01
#define Display_OFF 0x00
#define Display_ON 0x01
#define Scan_from_COM0_to_63 0x00
#define Scan_from_COM63_to_0 0x08
#use FAST_IO(B)
void OLED_init();
void OLED_write(unsigned char value, short type);
void OLED_gotoxy(unsigned char x_pos, unsigned char y_pos);
void OLED_fill(unsigned char bmp_data);
void OLED_clear_screen();
void OLED_set_start_column(unsigned char n);
void OLED_set_addressing_mode(unsigned char n);
void OLED_set_column_address(unsigned char r, unsigned char t);
void OLED_set_page_address(unsigned char r, unsigned char t);
void OLED_set_start_line(unsigned char n);
void OLED_set_contrast(unsigned char n);
void OLED_set_charge_pump(unsigned char n);
void OLED_set_segment_remap(unsigned char n);
void OLED_set_entire_display_on(unsigned char n);
void OLED_set_normal_or_inverse_display(unsigned char n);
void OLED_set_multiplex_ratio(unsigned char n);
void OLED_set_display_on_off(unsigned char n);
void OLED_set_start_page(unsigned char n);
void OLED_set_common_output_scan_direction(unsigned char n);
void OLED_set_display_offset(unsigned char n);
void OLED_set_display_clock(unsigned char n);
void OLED_set_precharge_period(unsigned char n);
void OLED_set_common_config(unsigned char n);
void OLED_set_VCOMH(unsigned char n);
void OLED_set_NOP();
void OLED_cursor(unsigned char x_pos, unsigned char y_pos);
void OLED_print_char(unsigned char x_pos, unsigned char y_pos, unsigned char ch);
void OLED_print_string(unsigned char x_pos, unsigned char y_pos, unsigned char *ch);
void OLED_draw_bitmap(unsigned char xb, unsigned char yb, unsigned char xe, unsigned char ye, unsigned char *bmp);
void OLED_print_chr(unsigned char x_pos, unsigned char y_pos, signed char value);
void OLED_print_int(unsigned char x_pos, unsigned char y_pos, signed long value);
void OLED_print_decimal(unsigned char x_pos, unsigned char y_pos, unsigned long value, unsigned char points);
void OLED_print_float(unsigned char x_pos, unsigned char y_pos, float value, unsigned char points);
SSD1306.c
#include "SSD1306.h"
#include "fonts.c"
void OLED_init()
   set_TRIS_B(0xF0);
   port_B_pullups(FALSE);
   output_high(D0);
   output_low(RST);
   delay_ms(60);
   output_high(RST);
   OLED_set_display_on_off(0x00);
   OLED_set_display_clock(0x80);
   OLED_set_multiplex_ratio(0x3F);
   OLED_set_display_offset(0x00);
   OLED_set_start_line(0x00);
   OLED_set_charge_pump(Enable_Charge_Pump);
   OLED_set_addressing_mode(Page_Addressing_Mode);
   OLED_set_segment_remap(Column_Address_0_Mapped_to_SEG127);
       OLED_set_common_output_scan_direction(Scan_from_COM63_to_0);
   OLED_set_common_config(0x10);
   OLED_set_contrast(0xCF);
   OLED_set_precharge_period(0xF1);
   OLED_set_VCOMH(0x40);
   OLED_set_entire_display_on(Normal_Display);
   OLED_set_normal_or_inverse_display(Non_Inverted_Display);
   OLED_set_display_on_off(Display_ON);
   OLED_fill(0x00);
   OLED_gotoxy(0,0);
   unsigned char s = 8;
    switch(type)
        case 1:
            output_high(DC);
        default:
            output_low(DC);
    output_low(D0);
   while(s > 0)
      if((value & 0x80) != 0)
         output_high(D1); ;
         output_low(D1);
        output_high(D0);
        output_low(D0);
      value <<= 1;
      s -= 1;
   OLED_write((Set_Page_Start_Address_CMD + y_pos), CMD);
   OLED_write(((x_pos & 0x0F) | Set_Lower_Column_Start_Address_CMD), CMD);
   OLED_write((((x_pos & 0xF0) >> 0x04) | Set_Higher_Column_Start_Address_CMD), CMD);
   unsigned char x_pos = 0;
   unsigned char page = 0;
   for(page = 0; page <= 7; page++)
      OLED_write((Set_Page_Start_Address_CMD + page), CMD);
      OLED_write(Set_Lower_Column_Start_Address_CMD, CMD);
      OLED_write(Set_Higher_Column_Start_Address_CMD, CMD);
      for(x_pos = 0; x_pos <= 127; x_pos++)
         OLED_write(bmp_data, DAT);
   OLED_fill(0x00);
   OLED_write(Set_Lower_Column_Start_Address_CMD + (n % 16), CMD);
   OLED_write(Set_Higher_Column_Start_Address_CMD + (n / 16), CMD);
   OLED_write(Set_Memory_Addressing_Mode_CMD, CMD);
   OLED_write(n, CMD);
   OLED_write(Set_Column_Address_CMD, CMD);
   OLED_write(r, CMD);
   OLED_write(t, CMD);
   OLED_write(Set_Page_Address_CMD, CMD);
   OLED_write(r, CMD);
   OLED_write(t, CMD);
   OLED_write((Set_Display_Start_Line_CMD | n), CMD);
   OLED_write(Set_Contrast_Control_CMD, CMD);
   OLED_write(n, CMD);
   OLED_write(Set_Charge_Pump_CMD, CMD);
   OLED_write((Set_Higher_Column_Start_Address_CMD | n), CMD);
   OLED_write((Set_Segment_Remap_CMD | n), CMD);
   OLED_write((Set_Entire_Display_ON_CMD | n), CMD);
   OLED_write((Set_Normal_or_Inverse_Display_CMD | n), CMD);
   OLED_write(Set_Multiplex_Ratio_CMD, CMD);
   OLED_write(n, CMD);
   OLED_write((Set_Display_ON_or_OFF_CMD + n) , CMD);
   OLED_write((Set_Page_Start_Address_CMD | n), CMD);
   OLED_write((Set_COM_Output_Scan_Direction_CMD | n), CMD);
   OLED_write(Set_Display_Offset_CMD, CMD);
   OLED_write(n, CMD);
   OLED_write(Set_Display_Clock_CMD, CMD);
   OLED_write(n, CMD);
   OLED_write(Set_Pre_charge_Period_CMD, CMD);
   OLED_write(n, CMD);
   OLED_write(Set_Common_HW_Config_CMD, CMD);
   OLED_write((0x02 | n), CMD);
   OLED_write(Set_VCOMH_Level_CMD, CMD);
   OLED_write(n, CMD);
void OLED_set_NOP()
   OLED_write(Set_NOP_CMD, CMD);
   unsigned char i = 0;
   if(y_pos != 0)
      if(x_pos == 1)
         OLED_gotoxy(0x00, (y_pos + 0x02));
         OLED_gotoxy((0x50 + ((x_pos - 0x02) * 0x06)), (y_pos + 0x02));
       for(i = 0; i < 6; i++)
           OLED_write(0xFF, DAT);
    unsigned char chr = 0;
   chr = (ch - 32);
   if(x_pos > 122)
      x_pos = 0;
      y_pos++;
   OLED_gotoxy(x_pos, y_pos);
      OLED_write(font_regular[chr][i], DAT);
    unsigned char j = 0;
   while(ch[j] != '\0')
      chr = (ch[j] - 32);
      if(x_pos > 126)
         x_pos = 0;
         y_pos++;
      j++;
      x_pos += 6;
   unsigned long i = 0;
   unsigned char y_pos = 0;
   for(y_pos = yb; y_pos <= ye; y_pos++)
      OLED_gotoxy(xb, y_pos);
      for(x_pos = xb; x_pos < xe; x_pos++)
         OLED_write((bmp[i]), DAT);
         i++;
   unsigned char ch = 0;
   if(value < 0)
      OLED_print_char(x_pos, y_pos, '-');
      value = -value;
      OLED_print_char(x_pos, y_pos,' ');
   ch = (value / 100);
   OLED_print_char((x_pos + 6), y_pos , (48 + ch));
   ch = ((value % 100) / 10);
   OLED_print_char((x_pos + 12), y_pos , (48 + ch));
   ch = (value % 10);
   OLED_print_char((x_pos + 18), y_pos , (48 + ch));
   if(value < 0)
      value = -value;
   if(value > 9999)
      ch = (value / 10000);
      ch = ((value % 10000)/ 1000);
      ch = ((value % 1000) / 100);
      OLED_print_char((x_pos + 24), y_pos , (48 + ch));
      ch = (value % 10);
      OLED_print_char((x_pos + 30), y_pos , (48 + ch));
   else if((value > 999) && (value <= 9999))
      ch = (value % 10);
   else if((value > 99) && (value <= 999))
      ch = (value % 10);
   else if((value > 9) && (value <= 99))
      ch = (value % 10);
      ch = (value % 10);
   OLED_print_char(x_pos, y_pos, '.');
   ch = (value / 1000);
   if(points > 1)
      if(points > 2)
         if(points > 3)
            ch = (value % 10);
   signed long tmp = 0;
   OLED_print_int(x_pos, y_pos, value);
   tmp = value;
   tmp = abs((value - tmp) * 10000);
   if((abs(value) >= 9999) && (abs(value) < 99999))
      OLED_print_decimal((x_pos + 36), y_pos, tmp, points);
   else if((abs(value) >= 999) && (abs(value) < 9999))
      OLED_print_decimal((x_pos + 30), y_pos, tmp, points);
   else if((abs(value) >= 99) && (abs(value) < 999))
      OLED_print_decimal((x_pos + 24), y_pos, tmp, points);
   else if((abs(value) >= 9) && (abs(value) < 99))
      OLED_print_decimal((x_pos + 18), y_pos, tmp, points);
   else if((abs(value) >= 0.00009) && (abs(value) < 9))
      OLED_print_decimal((x_pos + 12), y_pos, tmp, points);
fonts.c
const unsigned char font_regular[92][6] =
     0x00, 0x00, 0x00, 0x00, 0x00, 0x00,   // sp
     0x00, 0x00, 0x00, 0x2f, 0x00, 0x00,   // !
     0x00, 0x00, 0x07, 0x00, 0x07, 0x00,   // "
     0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14,   // #
     0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12,   // $
     0x00, 0x62, 0x64, 0x08, 0x13, 0x23,   // %
     0x00, 0x36, 0x49, 0x55, 0x22, 0x50,   // &
     0x00, 0x00, 0x05, 0x03, 0x00, 0x00,   // '
     0x00, 0x00, 0x1c, 0x22, 0x41, 0x00,   // (
     0x00, 0x00, 0x41, 0x22, 0x1c, 0x00,   // )
     0x00, 0x14, 0x08, 0x3E, 0x08, 0x14,   // *
     0x00, 0x08, 0x08, 0x3E, 0x08, 0x08,   // +
     0x00, 0x00, 0x00, 0xA0, 0x60, 0x00,   // ,
     0x00, 0x08, 0x08, 0x08, 0x08, 0x08,   // -
     0x00, 0x00, 0x60, 0x60, 0x00, 0x00,   // .
     0x00, 0x20, 0x10, 0x08, 0x04, 0x02,   // /
     0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E,   // 0
     0x00, 0x00, 0x42, 0x7F, 0x40, 0x00,   // 1
     0x00, 0x42, 0x61, 0x51, 0x49, 0x46,   // 2
     0x00, 0x21, 0x41, 0x45, 0x4B, 0x31,   // 3
     0x00, 0x18, 0x14, 0x12, 0x7F, 0x10,   // 4
     0x00, 0x27, 0x45, 0x45, 0x45, 0x39,   // 5
     0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30,   // 6
     0x00, 0x01, 0x71, 0x09, 0x05, 0x03,   // 7
     0x00, 0x36, 0x49, 0x49, 0x49, 0x36,   // 8
     0x00, 0x06, 0x49, 0x49, 0x29, 0x1E,   // 9
     0x00, 0x00, 0x36, 0x36, 0x00, 0x00,   // :
     0x00, 0x00, 0x56, 0x36, 0x00, 0x00,   // ;
     0x00, 0x08, 0x14, 0x22, 0x41, 0x00,   // <
     0x00, 0x14, 0x14, 0x14, 0x14, 0x14,   // =
     0x00, 0x00, 0x41, 0x22, 0x14, 0x08,   // >
     0x00, 0x02, 0x01, 0x51, 0x09, 0x06,   // ?
     0x00, 0x32, 0x49, 0x59, 0x51, 0x3E,   // @
     0x00, 0x7C, 0x12, 0x11, 0x12, 0x7C,   // A
     0x00, 0x7F, 0x49, 0x49, 0x49, 0x36,   // B
     0x00, 0x3E, 0x41, 0x41, 0x41, 0x22,   // C
     0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C,   // D
     0x00, 0x7F, 0x49, 0x49, 0x49, 0x41,   // E
     0x00, 0x7F, 0x09, 0x09, 0x09, 0x01,   // F
     0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A,   // G
     0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F,   // H
     0x00, 0x00, 0x41, 0x7F, 0x41, 0x00,   // I
     0x00, 0x20, 0x40, 0x41, 0x3F, 0x01,   // J
     0x00, 0x7F, 0x08, 0x14, 0x22, 0x41,   // K
     0x00, 0x7F, 0x40, 0x40, 0x40, 0x40,   // L
     0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F,   // M
     0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F,   // N
     0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E,   // O
     0x00, 0x7F, 0x09, 0x09, 0x09, 0x06,   // P
     0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E,   // Q
     0x00, 0x7F, 0x09, 0x19, 0x29, 0x46,   // R
     0x00, 0x46, 0x49, 0x49, 0x49, 0x31,   // S
     0x00, 0x01, 0x01, 0x7F, 0x01, 0x01,   // T
     0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F,   // U
     0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F,   // V
     0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F,   // W
     0x00, 0x63, 0x14, 0x08, 0x14, 0x63,   // X
     0x00, 0x07, 0x08, 0x70, 0x08, 0x07,   // Y
     0x00, 0x61, 0x51, 0x49, 0x45, 0x43,   // Z
     0x00, 0x00, 0x7F, 0x41, 0x41, 0x00,   // [ 91
     0x00, 0x02, 0x04 , 0x08, 0x10, 0x20,    // \92
     0x00, 0x00, 0x41, 0x41, 0x7F, 0x00,   // ]
     0x00, 0x04, 0x02, 0x01, 0x02, 0x04,   // ^
     0x00, 0x40, 0x40, 0x40, 0x40, 0x40,   // _
     0x00, 0x00, 0x01, 0x02, 0x04, 0x00,   // '
     0x00, 0x20, 0x54, 0x54, 0x54, 0x78,   // a
     0x00, 0x7F, 0x48, 0x44, 0x44, 0x38,   // b
     0x00, 0x38, 0x44, 0x44, 0x44, 0x20,   // c
     0x00, 0x38, 0x44, 0x44, 0x48, 0x7F,   // d
     0x00, 0x38, 0x54, 0x54, 0x54, 0x18,   // e
     0x00, 0x08, 0x7E, 0x09, 0x01, 0x02,   // f
     0x00, 0x18, 0xA4, 0xA4, 0xA4, 0x7C,   // g
     0x00, 0x7F, 0x08, 0x04, 0x04, 0x78,   // h
     0x00, 0x00, 0x44, 0x7D, 0x40, 0x00,   // i
     0x00, 0x40, 0x80, 0x84, 0x7D, 0x00,   // j
     0x00, 0x7F, 0x10, 0x28, 0x44, 0x00,   // k
     0x00, 0x00, 0x41, 0x7F, 0x40, 0x00,   // l
     0x00, 0x7C, 0x04, 0x18, 0x04, 0x78,   // m
     0x00, 0x7C, 0x08, 0x04, 0x04, 0x78,   // n
     0x00, 0x38, 0x44, 0x44, 0x44, 0x38,   // o
     0x00, 0xFC, 0x24, 0x24, 0x24, 0x18,   // p
     0x00, 0x18, 0x24, 0x24, 0x18, 0xFC,   // q
     0x00, 0x7C, 0x08, 0x04, 0x04, 0x08,   // r
     0x00, 0x48, 0x54, 0x54, 0x54, 0x20,   // s
     0x00, 0x04, 0x3F, 0x44, 0x40, 0x20,   // t
     0x00, 0x3C, 0x40, 0x40, 0x20, 0x7C,   // u
     0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C,   // v
     0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C,   // w
     0x00, 0x44, 0x28, 0x10, 0x28, 0x44,   // x
     0x00, 0x1C, 0xA0, 0xA0, 0xA0, 0x7C,   // y
     0x00, 0x44, 0x64, 0x54, 0x4C, 0x44,   // z
     0x14, 0x14, 0x14, 0x14, 0x14, 0x14    // horizontal lines
Example:
#include <16F876A.h>
#device *= 16
#fuses NOWDT, HS, PROTECT, CPD, PUT, BROWNOUT
#use delay (clock = 10MHz)
#include "SSD1306.c"
void setup();
   signed long i = -9;
   float f = 0;
   setup();
      f += 1.1;
      i++;
      if(i > 1000)
         i = -9;
         f = 0;
      OLED_print_float(1, 4, f, 1);
      OLED_print_int(1, 5, i);
      delay_ms(600);
void setup()
    char text[] = {"MicroArena"};
    disable_interrupts(global);
    setup_ADC(ADC_off);
    setup_ADC_ports(no_analogs);
    setup_CCP1(CCP_off);
    setup_CCP2(CCP_off);
    setup_SPI(SPI_disabled | SPI_SS_disabled);
    setup_timer_0(T0_internal);
    setup_timer_1(T1_disabled);
    setup_timer_2(T2_disabled, 255, 1);
    set_timer0(0);
    set_timer1(0);
    set_timer2(0);
    OLED_init();
    OLED_print_string(34, 2, text);
https://www.youtube.com/watch?v=w4L1xaYNdDw
https://www.facebook.com/MicroArena
SShahryiar
PostPosted: Fri May 01, 2015 8:49 am     Reply with quote
output_highuy��0);
nonsense line DOES NOT compile .........
also the use of defined CMD and DAT might be more
readable as just '1' and '0'
amanver
bitmap
PostPosted: Sun Jul 05, 2015 5:46 am     Reply with quote
what is the parameter of draw_bitmap func?
gkrusi
PostPosted: Fri Aug 07, 2015 5:51 am     Reply with quote
Thank you for this code!
I only removed #use FAST_IO(B) and port B definitions from the code and added chip select managment in OLED_write function.
Very Happy
