16f887 not work
eng/ IBRAHIM
16f887 not work
PostPosted: Sun Jul 12, 2015 2:37 pm     Reply with quote
i use this program by 16f877 and it play good
but when change to 16f887 not work.
int32 isr_ccp_delta,current_ccp,current_ccp_delta,frequency;
#int_ccp1
void ccp1_isr(void)
static int32 old_ccp = 0;
current_ccp = CCP_1;
isr_ccp_delta = current_ccp - old_ccp;
old_ccp = current_ccp;
delay_us(20);
set_timer1(0);
setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);
setup_ccp1(CCP_CAPTURE_RE);
clear_interrupt(INT_CCP1);
enable_interrupts(INT_CCP1);
   disable_interrupts(GLOBAL);
   current_ccp_delta = isr_ccp_delta;
   frequency = (2000000 / current_ccp_delta);
   output_d(frequency);
dyeatman
PostPosted: Sun Jul 12, 2015 2:42 pm     Reply with quote
You have been here long enough to know we need to see the setup
section of the program (CPU include, Fuses, Delay etc.) and the compiler version!
Also, when you say it doesn't work, what does that mean? What does it do?
Google and Forum Search are some of your best tools
PostPosted: Sun Jul 12, 2015 3:41 pm     Reply with quote
One item....
this....
isn't going to sent a 32 bit data to an 8 bit port properly.....
Jay
eng/ IBRAHIM
PostPosted: Sun Jul 12, 2015 6:20 pm     Reply with quote
the output still zero.at any frequency.
but when use 16f877 the output is reading input frequency
version 4.014
#include <16F887.h>
 #device PIC16F887
#list
#device adc=8
 #FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
 #FUSES NOMCLR                   //Master Clear pin used for I/O
 #FUSES NOIESO                   //Internal External Switch Over mode disabled
 #FUSES NOFCMEN                  //Fail-safe clock monitor disabled
 #FUSES BORV40                   //Brownout reset at 4.0V
 #use delay(clock=8000000)
eng/ IBRAHIM
PostPosted: Mon Jul 13, 2015 2:13 pm     Reply with quote
when change some lines as below.
the output is reading frequency input correct.
but when freq is not in range 40Hz to 250Hz . the output is incorrect
what is error
input freq rang is 20 to 1000Hz
int16 isr_ccp_delta,current_ccp,frequency;
#int_CCP2
void  CCP2_isr(void)
current_ccp = CCP_2;
output_high(PIN_e0);
delay_us(20);
   setup_ccp2(CCP_CAPTURE_RE);                        // Configure CCP1 to capture rise
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_1 );         // Start timer 1
   enable_interrupts(INT_CCP2);                       // Setup interrupt on rise edge
   frequency = (2000000 / isr_ccp_delta);
   delay_ms(5);
PostPosted: Mon Jul 13, 2015 2:54 pm     Reply with quote
You are running out of counts.
You need to use int32 values, and increment the high byte of the current_ccp in a timer1 interrupt,
eng/ IBRAHIM
PostPosted: Mon Jul 13, 2015 5:12 pm     Reply with quote
OK run good
now at start freq is zero or no signal output is zero. then freq is vary and output is reading the freq
but when freq return zero or no signal . output not zero and still at last value of freq
how make output is zero if freq return zero??
guy
PostPosted: Sat Jul 18, 2015 9:06 am     Reply with quote
Add a flag in the interrupt, and in the main loop wait for the flag.
That makes the output change only when there is an interrupt.
Then, while waiting for this flag check TIMER_1 if time between edges is more than 20Hz / 50ms. If so, set the output value to 0.
