Testicky
Joined: 22 Nov 2003 Posts: 12 Location: South Africa / Taiwan
| uPD7225 routines |
Posted: Mon Nov 24, 2003 12:29 pm |
Does any one has a driver or routines written in CCS for the uPD7225 LCD driver IC? ( or know where to find one )
I can't found anything around, and this is supposed to be a popular LCD driver.
Thanks a lot in advance.
Jacques[/b] _________________ Testicky |
Posted: Mon Nov 24, 2003 12:40 pm |
Can you get the National MM5453 ?
If so, I have a driver for that one. |
Testicky
| MM5453 |
Posted: Mon Nov 24, 2003 1:01 pm |
Yes, this would also be more than acceptable for my project. I actually need only 30 segments for this project. It seems quick and easy to cascade them anyway.
Thanks a lot.
Jacques _________________ Testicky |
Posted: Mon Nov 24, 2003 1:40 pm |
// lcd5453.c --
// Routines to display numbers on the 4 1/2 digit LCD
// that is driven by the National MM5453 LCD driver chip.
// Display a number from 0 to 9999 on the LCD.
void display_number_on_lcd(int16 value)
bin2seg(value, gca_lcd_segment_data);
send_lcd_data(gca_lcd_segment_data);
// Display "----" on the LCD.
void display_dashes_on_lcd(void)
gca_lcd_segment_data[3] = DASH_SEGMENT_CODE;
gca_lcd_segment_data[2] = DASH_SEGMENT_CODE;
gca_lcd_segment_data[1] = DASH_SEGMENT_CODE;
gca_lcd_segment_data[0] = DASH_SEGMENT_CODE;
// Display "OFF" on the LCD.
void display_OFF_on_lcd(void)
gca_lcd_segment_data[3] = O_SEGMENT_CODE;
gca_lcd_segment_data[2] = F_SEGMENT_CODE;
gca_lcd_segment_data[1] = F_SEGMENT_CODE;
gca_lcd_segment_data[0] = BLANK_SEGMENT_CODE;
// Clear LCD shift register.
void init_lcd(void)
send_zero_bits_to_lcd_driver(40);
// Convert a 16-bit value, from 0 to 9999
// to the 4 bytes of segment data necessary
// to display the value on the LCD, in decimal.
// This routine uses subtraction instead of
// division, in order to save ROM space.
void bin2seg(int16 value, char *gca_lcd_segment_data)
char digit;
char leading_zeros;
// Do a range check.
if(value > 9999)
value = 9999;
leading_zeros = 0;
// Do the 1000's digit.
digit = 0;
while(value >= 1000)
value -= 1000;
digit++;
gca_lcd_segment_data[3] = gca_numeric_segment_codes[digit];
// Check if we need to suppress a leading zero for the 2nd digit.
if(digit == 0)
leading_zeros++;
gca_lcd_segment_data[3] = BLANK_SEGMENT_CODE;
// Do the 100's digit.
digit = 0;
while(value >= 100)
value -= 100;
digit++;
gca_lcd_segment_data[2] = gca_numeric_segment_codes[digit];
if(digit == 0)
leading_zeros++;
if(leading_zeros == 2)
gca_lcd_segment_data[2] = BLANK_SEGMENT_CODE;
// Do the 10's digit.
digit = 0;
while(value >= 10)
value -= 10;
digit++;
gca_lcd_segment_data[1] = gca_numeric_segment_codes[digit];
// Check if we need to suppress a leading zero for the 3rd digit.
if(digit == 0)
leading_zeros++;
if(leading_zeros == 3)
gca_lcd_segment_data[1] = BLANK_SEGMENT_CODE;
// Do the 1's digit.
gca_lcd_segment_data[0] = gca_numeric_segment_codes[value];
// This function translates segment data so that
// it fits the actual board layout. Ie., the circuit
// board connects between the MM5453 lcd driver chip
// and the LCD may have been wired to produce the
// best layout, but are not wired in the proper order.
// This routine fixes that.
// The data array, which consists of 5 bytes, holds
// the 33 bits of data which is shifted out to the
// MM5453 chip. The data is shifted out lsb-first.
// Ie., bit 0 of byte 0 goes first, and bit 0 of byte 4
// goes out last. (That's 4 x 8, +1 = 33 bits).
// We need 5 bytes in the output array because we have
// 33 bits that have to be shifted out.
// The data, before it's remapped, is ordered with
// 7 segments per byte (using bits 0-6), with byte 0
// of the input array corresponding to the LSB digit
// on the LCD. Bit 7 of each byte is 0.
void remap_lcd_data(char *segment_data)
// Zero the output array.
gca_output_data[0] = 0;
gca_output_data[1] = 0;
gca_output_data[2] = 0;
gca_output_data[3] = 0;
gca_output_data[4] = 0;
// This is the mapping for the Rev 2 board.
if(bit_test(segment_data[0], 0)) // Segment 1G
bit_set(gca_output_data[0], 6);
if(bit_test(segment_data[0], 1)) // 1F
bit_set(gca_output_data[0], 4);
if(bit_test(segment_data[0], 2)) // 1E
bit_set(gca_output_data[0], 7);
if(bit_test(segment_data[0], 3)) // 1D
bit_set(gca_output_data[0], 1);
if(bit_test(segment_data[0], 4)) // 1C
bit_set(gca_output_data[0], 5);
if(bit_test(segment_data[0], 5)) // 1B
bit_set(gca_output_data[0], 3);
if(bit_test(segment_data[0], 6)) // 1A
bit_set(gca_output_data[0], 2);
if(bit_test(segment_data[1], 0)) // Segment 2G
bit_set(gca_output_data[1], 4);
if(bit_test(segment_data[1], 1)) // 2F
bit_set(gca_output_data[1], 2);
if(bit_test(segment_data[1], 2)) // 2E
bit_set(gca_output_data[1], 5);
if(bit_test(segment_data[1], 3)) // 2D
bit_set(gca_output_data[1], 3);
if(bit_test(segment_data[1], 4)) // 2C
bit_set(gca_output_data[1], 1);
if(bit_test(segment_data[1], 5)) // 2B
bit_set(gca_output_data[0], 0);
if(bit_test(segment_data[1], 6)) // 2A
bit_set(gca_output_data[1], 0);
if(bit_test(segment_data[2], 0)) // Segment 3G
bit_set(gca_output_data[2], 4);
if(bit_test(segment_data[2], 1)) // 3F
bit_set(gca_output_data[2], 2);
if(bit_test(segment_data[2], 2)) // 3E
bit_set(gca_output_data[2], 3);
if(bit_test(segment_data[2], 3)) // 3D
bit_set(gca_output_data[2], 1);
if(bit_test(segment_data[2], 4)) // 3C
bit_set(gca_output_data[1], 7);
if(bit_test(segment_data[2], 5)) // 3B
bit_set(gca_output_data[1], 6);
if(bit_test(segment_data[2], 6)) // 3A
bit_set(gca_output_data[2], 0);
if(bit_test(segment_data[3], 0)) // Segment 4G
bit_set(gca_output_data[3], 4);
if(bit_test(segment_data[3], 1)) // 4F
bit_set(gca_output_data[3], 2);
if(bit_test(segment_data[3], 2)) // 4E
bit_set(gca_output_data[3], 1);
if(bit_test(segment_data[3], 3)) // 4D
bit_set(gca_output_data[2], 7);
if(bit_test(segment_data[3], 4)) // 4C
bit_set(gca_output_data[2], 5);
if(bit_test(segment_data[3], 5)) // 4B
bit_set(gca_output_data[2], 6);
if(bit_test(segment_data[3], 6)) // 4A
bit_set(gca_output_data[3], 0);
// These are the 3 decimal points and colon.
bit_clear(gca_output_data[3], 3); // 4DP
bit_clear(gca_output_data[3], 5); // 3DP
bit_clear(gca_output_data[3], 7); // 2DP
bit_clear(gca_output_data[4], 0); // COLON
bit_clear(gca_output_data[3], 6); // NC
void send_lcd_data(char *lcd_segment_data)
char value;
char digit;
char segment;
// Rearrange the segment data so that it fits
// the way the PCB board is actually wired
// (between the LCD and the LCD driver chip).
remap_lcd_data(lcd_segment_data);
// Send the start bit.
output_high(SDATA_PIN_A0);
lcd_clock_pulse();
// Send 32 bits in the first 4 bytes of the output array.
for(digit = 0; digit < NUM_LCD_DIGITS; digit++)
value = gca_output_data[digit];
for(segment = 0; segment < 8; segment++)
if(value & 0x01)
output_low(SDATA_PIN_A0);
lcd_clock_pulse();
value >>= 1;
// Send the 33rd bit (the final one).
if(gca_output_data[4] & 0x01)
lcd_clock_pulse();
// Send out 2 more clock pulses after that, with data low, to
// finish up the sequence. See MM5453 data sheet for details.
lcd_clock_pulse();
lcd_clock_pulse();
void send_zero_bits_to_lcd_driver(char count)
char i;
output_low(SDATA_PIN_A0); // Set data low
for(i = 0; i < count; i++)
lcd_clock_pulse();
void lcd_clock_pulse(void)
output_high(SCLK_PIN_A3); // Positive clock pulse
output_low(SCLK_PIN_A3);
| Code: | // lcd5453.h
// 16F628 pins
#define SDATA_PIN_A0 PIN_A0
#define SCLK_PIN_A3 PIN_A3
#define NUM_LCD_DIGITS 4
#define NUM_LCD_SEGMENTS_PER_DIGIT 7
// This table translates numbers 0-9 into their segment codes.
// These codes are sent to the LCD to display the corresponding
// number, 0-9. In each code byte, a "1" bit indicates a segment
// which is lit up (ie. displayed). Example: The number zero
// uses segments A-F, which is coded as 0x3F. Six segments are
// lit up to display it.
// Bit numbers assigned to segments:
// 6
// 1 | | 5
// | 0 |
// 2 | | 4
// 3
char const gca_numeric_segment_codes[10] =
{0x7E, 0x30, 0x6D, 0x79, 0x33, 0x5B, 0x5F, 0x70, 0x7F, 0x7B};
// 0 1 2 3 4 5 6 7 8 9
// Dash code, used to display "----"
#define DASH_SEGMENT_CODE 0x01
// Blank
#define BLANK_SEGMENT_CODE 0x00
// Various letters
#define A_SEGMENT_CODE 0xF7
#define u_SEGMENT_CODE 0x1c
#define t_SEGMENT_CODE 0x0F
#define o_SEGMENT_CODE 0x1d
#define F_SEGMENT_CODE 0x47
#define O_SEGMENT_CODE 0x7E
// GLOBALS
char gca_lcd_segment_data[NUM_LCD_DIGITS];
char gca_output_data[NUM_LCD_DIGITS +1];
// FUNCTION PROTOTYPES
void init_lcd(void);
void clear_lcd(void);
void remap_lcd_data(char *segment_data);
void display_number_on_lcd(int16 value);
void display_dashes_on_lcd(void);
void display_OFF_on_lcd(void);
void send_lcd_data(char *lcd_segment_data);
void bin2seg(int16 value, char *gca_lcd_segment_data);
void send_zero_bits_to_lcd_driver(char count);
void lcd_clock_pulse(void);
// End of File |
// Example of how to use the routines:
| Code: | main()
int16 rpm;
// Init the LCD output pins.
output_low(SDATA_PIN_A0); // Output -- SDATA to LCD driver chip
output_low(SCLK_PIN_A3); // Output -- SCLK to LCD driver chip
// To display a number on the LCD, do this:
rpm = 5000; // Display 5000
display_number_on_lcd(rpm);
// To display pre-defined text on the LCD, call the appropriate routine.
display_OFF_on_lcd();
Last edited by PCM programmer on Mon Nov 24, 2003 2:17 pm; edited 1 time in total |
Testicky
| THANK YOU VERY MUCH |
Posted: Mon Nov 24, 2003 2:04 pm |
Your code is so nicely done and commented.
I will get this going in the morning.
Thank you again for your help.
