rikotech8
Joined: 10 Dec 2011 Posts: 376 Location: Sofiq,Bulgariq
| Why #use rs232 but not #use uart? |
Posted: Mon Jun 15, 2015 12:47 pm |
Why #use rs232 instead of #use uart? _________________ A person who never made a mistake never tried anything new. |
Posted: Mon Jun 15, 2015 1:41 pm |
Probably because historically, when the compiler was first written,
"rs-232" was the most commonly used protocol (by hobbyists and others).
So CCS used the name that most people would easily recognize. |
Posted: Mon Jun 15, 2015 2:56 pm |
also.... 'UART' typically implies a special peripheral either discrete or masked onto the PIC die whereas CCS allows you to create a 'software 'UART' though it's NOT a true UART it will allow you to send/receive serial data aka RS-232.
The use of the term 'RS232' has misled a lot of people over the years, I still think of it as +-12 Volt signalling using 1488/1489 chips...sigh I must be showing my age !
Jay |
Posted: Thu Jun 18, 2015 8:29 am |
I think 'history' is the key.
When CCS started, the sole purpose of this, was to provide the TTY interface setup for getc/putc. Doing this without a UART (on chips that didn't have one), or with a UART (on chips that did).
It has 'growed and growed', with handling for RS485 direction control etc..
I've often posted that it should be something like '#use async serial', but then it began supporting synchronous modes, so even this wouldn't cover all the options.
The title is just a 'wrapper' and unfortunately is wrong for anyone who understands what 'RS232' involves, but any replacement is also wrong (no UART in many cases, async and synchronous, etc. etc....).
We 'live with it'. |
asmboy
Posted: Sun Jun 21, 2015 5:40 pm |
| Quote: |
#USE EIA_SERIAL ... ...
Talking roots here but newer than Baudot
Posted: Tue Jun 23, 2015 5:25 am |
I always thought...
#USE SIO(...)
..would be more appropriate. RS232 to me usually has 1488 drivers and 1489 receiver chips involved !
SIO ,'Serial Input Output' is a 'generic' term without a preconceived idea as to the hardware or software, only that data uses 1 wire instead of 8.
It would fit better with #USE SPI, #USE I2C, etc.
Jay |
tinley
Posted: Tue Jun 23, 2015 6:08 am |
Could be
use 'firmware asynchronous receiver transmitter'? |
Posted: Tue Jun 23, 2015 6:53 am |
Except as I already pointed out, it does now support synchronous in some cases.
It is a case where the capabilities exceed the name.... |
ezflyr
Posted: Tue Jun 23, 2015 9:05 am |
| temtronic wrote: |
Hi Jay,
Nothing says 'old geezer' like a reference to 1488/1489 RS232 driver IC's, ha, ha !!
John |
RF_Developer
Posted: Tue Jun 23, 2015 9:13 am |
| ezflyr wrote: |
Nothing says 'old geezer' like a reference to 1488/1489 RS232 driver IC's, |
Really? To me RS232 brings to mind images of Teletypes and discrete transistors....
Less of the "old geezers", if you don't mind ;-) We're like great whisky: well-matured and full-bodied. We've also been there, done that over and over, and got the wooly pullovers to prove it! |
Posted: Tue Jun 23, 2015 10:14 am |
Word to the wise, NEVER use hipowered 'degreaser' on old ASR33s to get rid of the 'gunk'. It'll destroy the 'plastic' pieces like gears in about 9 days !! BTDT.
First profitable PIC project was a 20ma loop to RS232 convertor, yes using the 1488/89 chips.
sigh, the good old dayze....
Jay |
