PIC18F2525 uart
Prefekt
PIC18F2525 uart
PostPosted: Tue Jun 02, 2015 12:39 pm     Reply with quote
I tried a new pic for me, the 18F2525 with a 20MHZ crystal.
#include <18F2525.h>
//fuses
#fuses HS,NOWDT,NOPROTECT,NOLVP,NODEBUG
#use rs232(baud=115200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
printf is ok, works. But I can't receive any char's!
This is not working
while(!kbhit())
    ch = getch();
    printf("ch");
and the #INT_RDA is also not working
#INT_RDA
void rs232_handler(void)
   chr=getc();
   printf("hallo");
Is it better to use a 10MHz crystal?
PostPosted: Tue Jun 02, 2015 1:20 pm     Reply with quote
you should post your entire code as 'snippets' don't tell the WHOLE story.
for instance we don't KNOW if you're enabled the interrupt for INT_RDA.
Jay
Prefekt
PostPosted: Tue Jun 02, 2015 2:10 pm     Reply with quote
code below is working with a PIC18F2550 but not with the pic18f2525
// Include libraries
#include <modul192.h>
// Global definitions
char chr='A';
int16 bitcounter = 0;
char InputData[C_TOTAL_LED_HEX];
char OutputData[C_TOTAL_LED_HEX];
char SCTData[C_SCT_COUNT][C_LED_COUNT_ON_SCT];
// Sub Functions
void SetSCTDataBin(int8 val, int sctindex, int ledindex)
  int8 i;
  for (i = 0; i < 8; i++)
    if (val & 0x80)  // test the MSB (Most significant bit (bit7))
      SCTData[sctindex][ledindex] = '1';
      SCTData[sctindex][ledindex] = '0';
    ledindex++;
    val <<= 1;  // Shift left y by 1 bit
void SplitInputData()
   int16 dataindex=0; //Input data index
   int sctindex=0;  //STC driver index
   int ledindex=0;  //LED index on serveral stc driver
   for (dataindex=0; dataindex<C_TOTAL_LED_HEX;dataindex++)
      SetSCTDataBin(InputData[dataindex], sctindex, ledindex);
      ledindex+=8;
      if((dataindex>0) && ((dataindex+1) % (C_LED_COUNT_ON_SCT_HEX) == 0))
         //next stc driver
         sctindex++;
         ledindex=0;
//Clock SCT driver
void SCT_Clock(void)
   output_high(SCT_CLK);
   delay_us(1);
   output_low(SCT_CLK);
//Move STCData to STC output register
void SCT_MoveDataToRegister(void)
   int ledindex=0;
   for (ledindex=0; ledindex<C_LED_COUNT_ON_SCT; ledindex++)
      if(SCTData[0][ledindex]=='1') { output_high(SCT_SDI_1); }
      else { output_low(SCT_SDI_1); }
      if(SCTData[1][ledindex]=='1') { output_high(SCT_SDI_2); }
      else { output_low(SCT_SDI_2); }
      if(SCTData[2][ledindex]=='1') { output_high(SCT_SDI_3); }
      else { output_low(SCT_SDI_3); }
      if(SCTData[3][ledindex]=='1') { output_high(SCT_SDI_4); }
      else { output_low(SCT_SDI_4); }
      if(SCTData[4][ledindex]=='1') { output_high(SCT_SDI_5); }
      else { output_low(SCT_SDI_5); }
      if(SCTData[5][ledindex]=='1') { output_high(SCT_SDI_6); }
      else { output_low(SCT_SDI_6); }
      if(SCTData[6][ledindex]=='1') { output_high(SCT_SDI_7); }
      else { output_low(SCT_SDI_7); }
      if(SCTData[7][ledindex]=='1') { output_high(SCT_SDI_8); }
      else { output_low(SCT_SDI_8); }
      if(SCTData[8][ledindex]=='1') { output_high(SCT_SDI_9); }
      else { output_low(SCT_SDI_9); }
      if(SCTData[9][ledindex]=='1') { output_high(SCT_SDI_10); }
      else { output_low(SCT_SDI_10); }
      if(SCTData[10][ledindex]=='1') { output_high(SCT_SDI_11); }
      else { output_low(SCT_SDI_11); }
      if(SCTData[11][ledindex]=='1') { output_high(SCT_SDI_12); }
      else { output_low(SCT_SDI_12); }
      //Clock stc driver
      SCT_Clock();
//Data latch STC
void SCT_LatchData(void)
   output_high(SCT_LA);
   delay_ms(1);
   output_low(SCT_LA);
//Initialize STC driver
void SCT_Init()
      //disable STC output
      output_high(SCT_OE);
      output_low(SCT_LA);
//Send data via rs232
void SendData()
   int i;
   for (i=0;i<C_TOTAL_LED_HEX;i++)
      putc(OutputData[i]);
   putc('#');
// Interrupts
#INT_RDA
   chr=getc();
   printf("hallo"); //only for testing
   if(chr != '#')
      //Catch Input Data
      //printf("%c", chr);
      InputData[bitcounter]=chr;
      bitcounter++;
      disable_interrupts(GLOBAL);
      disable_interrupts(INT_RDA);
      bitcounter=0;
      //Send OutputData
      SendData();
      //Copy InputData to OutputData
      memcpy(OutputData, InputData, sizeof(OutputData));
      //Split InputData
      SplitInputData();
      //Send InputData to STC
      SCT_MoveDataToRegister();
      //Latch STC
      SCT_LatchData();
      enable_interrupts(INT_RDA);
// Main
   char ch;
   //Init STC driver
   SCT_Init();
   //Data init
   for (int i=0; i<C_TOTAL_LED_HEX; i++)
      OutputData[i] = 0x00;
      InputData[i] = 0x00;
   //for debug only
   //char c[]={0x01,0x80,0x01,0x80,0x01,0x80,0x01,0x80,0x01,0x80,0xff,0xff,0xff,0xff,0x01,0x80,0x01,0x80,0x01,0x80,0x01,0x80,0x01,0x80};
   //memcpy(InputData, c, sizeof(c));
   //Split InputData
   SplitInputData();
   //Latch STC
   SCT_LatchData();
   //Enable interrupts
   output_low(SCT_OE);
/*   printf("Hallo");
   while(!kbhit())
         ch = getch();
         printf("ch");
      //Get global OutputEnabled
      if(input(GLOBAL_OE)==1)
         //printf("1");
         output_low(SCT_OE);
         //printf("0");
heeader file
//fuses
// i/o pins
#define SCT_SDI_1    PIN_A0
#define SCT_SDI_2    PIN_A1
#define SCT_SDI_3    PIN_A2
#define SCT_SDI_4    PIN_A3
#define SCT_SDI_5    PIN_A4
#define SCT_SDI_6    PIN_A5
#define SCT_SDI_7    PIN_B0
#define SCT_SDI_8    PIN_B1
#define SCT_SDI_9    PIN_B2
#define SCT_SDI_10   PIN_B3
#define SCT_SDI_11   PIN_B4
#define SCT_SDI_12   PIN_B5
#define SCT_OE       PIN_C1
#define SCT_CLK      PIN_C2
#define SCT_LA       PIN_C0
#define GLOBAL_OE    PIN_C4
//serial interface
//constants
#define C_LED_COUNT_ON_SCT 16
#define C_LED_COUNT_ON_SCT_HEX 2
#define C_SCT_COUNT 12
#define C_TOTAL_LED_HEX 24
asmboy
PostPosted: Tue Jun 02, 2015 3:27 pm     Reply with quote
while(!kbhit())
ch = getch();
printf("ch");
will NEVER work if you have an INT_RDA set up........
AND could very well contend with it too,
as you are standing on the receive UART function WAITING in foreground!
what a mess of bad serial I/O Sad
also get the PRINTF() out of the INT_RDA handler
as well as all the junk code for manipulation.
everything from here
if(chr != '#')
on down should be moved to MAIN() and polled .....
AND
whatever might be in VAR ch
all you willever print is CH..CH..CH etc Very Happy Very Happy Very Happy
Prefekt
PostPosted: Tue Jun 02, 2015 11:58 pm     Reply with quote
This thinks are only for testing the serial interface.
My problem is that I cant' read any data from serial interface with PIC18F2525. With PIC18F2550 it works.
I try the ccs sample and the pic doesen't receive characters. There are special configuration settings for the PIC18F2525?
PostPosted: Wed Jun 03, 2015 1:21 am     Reply with quote
1) A test program should be simple. What you want to show involves a dozen lines at most.... Currently you have so many things 'not involved' in the actual problem being used, that finding what is wrong is difficult...
2) Always with a problem like this, _post the compiler version_. This matters.
2) The actual logic you post for your 'read test' is wrong. Think about it. You want to wait 'while' there is not a key hit, and then when there is a key hit try to read the character. Currently you try to read the character if there is not one there, but if there is a character, never try to read it. If a character is seen on boot, the display will never be called....
#device ADC=10
#use delay(crystal=20000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PORT1,errors)
int1 have_char=FALSE;
int8 ch;
#INT_RDA
void rs_rx(void)
   ch=getch();
   have_char=TRUE;
//interrupt version
   while (TRUE)
      if (have_char)
         have_char=false;
         printf("ch"); //and print a message
//non interrupt version
void main2()
   int8 ch;
      while(!kbhit())
        ; //wait if there is no key
      ch = getch(); //now get the key
Two complete versions here. 'main' using interrupts, and 'main2' not using interrupts. Compile whichever you want to test.
Your existing test, could only print a character, if the chip doesn't see one when it boots. Now I'd suspect the 2525, is waking faster than the 2550 (the PLL in the clock on this takes a long time to wake), so the 2525, wakes up before the RS232 inverter has stabilised, so always sees a character, so never responds to the faulty test code.....
The compiler version matters a lot on these chips, because there was a change after the revision B silicon to the meaning of two bits in the baudcon register. An old compiler might well not set these correctly, which could result in the serial receive line actually being inverted.
Prefekt
PostPosted: Wed Jun 03, 2015 4:43 am     Reply with quote
thanks, i will test it.
compiler version is: 5.032
