DS3231 High Precision I2C RTC Driver
sshahryiar
PostPosted: Wed Apr 10, 2013 10:28 pm     Reply with quote
DS3231.h
#define DS3231_Address              0x68
#define DS3231_Read_addr            ((DS3231_Address << 1) | 0x01)
#define DS3231_Write_addr           ((DS3231_Address << 1) & 0xFE)
#define secondREG                   0x00
#define minuteREG                   0x01
#define hourREG                     0x02
#define dayREG                      0x03
#define dateREG                     0x04
#define monthREG                    0x05
#define yearREG                     0x06
#define alarm1secREG                0x07
#define alarm1minREG                0x08
#define alarm1hrREG                 0x09
#define alarm1dateREG               0x0A
#define alarm2minREG                0x0B
#define alarm2hrREG                 0x0C
#define alarm2dateREG               0x0D
#define controlREG                  0x0E
#define statusREG                   0x0F
#define ageoffsetREG                0x10
#define tempMSBREG                  0x11
#define tempLSBREG                  0x12
#define _24_hour_format             0
#define _12_hour_format             1
#define am                          0
#define pm                          1
unsigned char bcd_to_decimal(unsigned char d);
unsigned char decimal_to_bcd(unsigned char d);
unsigned char DS3231_Read(unsigned char address);
void DS3231_Write(unsigned char address, unsigned char value);
void DS3231_init();
void getTime(unsigned char &p3, unsigned char &p2, unsigned char &p1, short &p0, short hour_format);
void getDate(unsigned char &p4, unsigned char &p3, unsigned char &p2, unsigned char &p1);
void setTime(unsigned char hSet, unsigned char mSet, unsigned char sSet, short am_pm_state, short hour_format);
void setDate(unsigned char daySet, unsigned char dateSet, unsigned char monthSet, unsigned char yearSet);
float getTemp();
DS3231.c
#include "DS3231.h"
         return ((d & 0x0F) + (((d & 0xF0) >> 4) * 10));
         return (((d / 10) << 4) & 0xF0) | ((d % 10) & 0x0F);
         unsigned char value = 0;
         I2C_start();
         I2C_write(DS3231_Write_addr);
         I2C_write(address);
         I2C_start();
         I2C_write(DS3231_Read_addr);
         value = I2C_read(0);
         I2C_stop();
         return value;
         I2C_start();
         I2C_write(address);
         I2C_write(value);
         I2C_stop();
void DS3231_init()
         DS3231_Write(controlREG, 0x00);
         DS3231_Write(statusREG, 0x08);
         unsigned char tmp = 0;
         p1 = DS3231_Read(secondREG);
         p1 = bcd_to_decimal(p1);
         p2 = DS3231_Read(minuteREG);
         p2 = bcd_to_decimal(p2);
         switch(hour_format)
                  case 1:
                           tmp = DS3231_Read(hourREG);
                           tmp &= 0x20;
                           p0 = (short)(tmp >> 5);
                           p3 = (0x1F & DS3231_Read(hourREG));
                           p3 = bcd_to_decimal(p3);
                  default:
                           p3 = (0x3F & DS3231_Read(hourREG));
         p1 = DS3231_Read(yearREG);
         p2 = (0x1F & DS3231_Read(monthREG));
         p3 = (0x3F & DS3231_Read(dateREG));
         p4 = (0x07 & DS3231_Read(dayREG));
         p4 = bcd_to_decimal(p4);
         DS3231_Write(secondREG, (decimal_to_bcd(sSet)));
         DS3231_Write(minuteREG, (decimal_to_bcd(mSet)));
         switch(hour_format)
                  case 1:
                           switch(am_pm_state)
                                    case 1:
                                             tmp = 0x60;
                                    default:
                                             tmp = 0x40;
                           DS3231_Write(hourREG, ((tmp | (0x1F & (decimal_to_bcd(hSet))))));
                  default:
                           DS3231_Write(hourREG, (0x3F & (decimal_to_bcd(hSet))));
         DS3231_Write(dayREG, (decimal_to_bcd(daySet)));
         DS3231_Write(dateREG, (decimal_to_bcd(dateSet)));
         DS3231_Write(monthREG, (decimal_to_bcd(monthSet)));
         DS3231_Write(yearREG, (decimal_to_bcd(yearSet)));
float getTemp()
         register float t = 0.0;
         unsigned char lowByte = 0;
         signed char highByte = 0;
         lowByte = DS3231_Read(tempLSBREG);
         highByte = DS3231_Read(tempMSBREG);
         lowByte >>= 6;
         lowByte &= 0x03;
         t = ((float)lowByte);
         t *= 0.25;
         t += highByte;
         return t;
https://www.facebook.com/MicroArena
SShahryiar
zamzam23
PostPosted: Sat Jan 31, 2015 5:22 am     Reply with quote
thanks for the library.
can you send to us a example code for how we can use this library?
sshahryiar
Example Code
PostPosted: Sat Jan 31, 2015 7:00 am     Reply with quote
#include <16F877A.h>
#device *= 16
#fuses NOWDT, HS, PROTECT, CPD, NOWRT, BROWNOUT, NODEBUG, NOLVP, PUT
#use delay (clock = 10MHz)
#use I2C(Master, SDA = pin_C4, SCL = pin_C3)
#define rowA      pin_B6
#define rowB      pin_B5
#define rowC      pin_B4
#define rowD      pin_B3
#define col1      !input(pin_B2)
#define col2      !input(pin_B1)
#define col3      !input(pin_B0)
#define dly_1     2000
#define dly_2      300
#include "lcd.c"
#include "DS3231.c"
unsigned char s = 10;
unsigned char min = 10;
unsigned char hr = 10;
unsigned char dy = 1;
unsigned char dt = 31;
unsigned char mt = 12;
unsigned char yr = 99;
short hr_format = _12_hour_format;
short am_pm = 1;
void setup();
unsigned char getKbd();
unsigned char getParameter(unsigned char p , unsigned char max, unsigned char min, unsigned char x_pos, unsigned char y_pos);
unsigned char makeNumber(unsigned char _10thDigit, unsigned char _1stDigit);
void settings();
unsigned char setDay(unsigned char dayValue, unsigned char x_pos, unsigned char y_pos);
void showDay(unsigned char day_val, unsigned char x_pos, unsigned char y_pos);
void showParameters();
         setup();
         setTime(hr, min, s, am_pm, hr_format);
         setDate(dy, dt, mt, yr);
                  getTime(hr, min, s, am_pm, hr_format);
                  getDate(dy, dt, mt, yr);
                  if(getKbd() == 0x0A)
                           settings();
                  showParameters();
void setup()
         disable_interrupts(global);
         setup_ADC(ADC_off);
         setup_ADC_ports(no_analogs);
         setup_timer_0(0 | 0| 0);
         setup_timer_1(T1_disabled);
         setup_timer_2(T2_disabled, 255, 1);
         set_timer0(0);
         set_timer1(0);
         set_timer2(0);
         setup_SPI(SPI_disabled | SPI_SS_disabled);
         setup_PSP(PSP_disabled);
         setup_CCP1(CCP_off);
         setup_CCP2(CCP_off);
         set_tris_B(0x0F);
         port_B_pullups(TRUE);
         DS3231_init();
         lcd_putc("\f");
         output_low(rowA);
         output_high(rowB);
         output_high(rowC);
         output_high(rowD);
         if(col1)
                  return 0x01;
         else if(col2)
                  return 0x02;
         else if(col3)
                  return 0x03;
         output_low(rowB);
         output_high(rowA);
         output_high(rowC);
         output_high(rowD);
         if(col1)
                  return 0x04;
         else if(col2)
                  return 0x05;
         else if(col3)
                  return 0x06;
         output_low(rowC);
         output_high(rowA);
         output_high(rowB);
         output_high(rowD);
         if(col1)
                  return 0x07;
         else if(col2)
                  return 0x08;
         else if(col3)
                  return 0x09;
         output_low(rowD);
         output_high(rowA);
         output_high(rowB);
         output_high(rowC);
         if(col1)
                  return 0x0A;
         else if(col2)
                  return 0x00;
         else if(col3)
                  return 0x0B;
                  return 0x10;
         short char_pos = 1;
         unsigned char n = 0;
         unsigned char n1 = 0;
         unsigned char n2 = 0;
         lcd_gotoxy(x_pos, y_pos);
         printf(lcd_putc, "%02u", p);
         for(;;)
                  if(getKbd() != 0x10)
                           n = getKbd();
                           if((n >= 0) && (n <= 9))
                                    char_pos = ~char_pos;
                           delay_ms(dly_2);
                  if(!char_pos)
                                    n1 = n;
                                    printf(lcd_putc, "%u", n1);
                                    n2 = n;
                                    lcd_gotoxy((x_pos + 1), y_pos);
                                    printf(lcd_putc, "%u", n2);
                  if(getKbd() == 0x0B)
                           p = makeNumber(n1, n2);
                           if((p <= max) && (p >= min))
                                    return p;
                                    return 1;
         return ((_10thDigit * 10) + _1stDigit);
void settings()
         lcd_putc("\f");
         lcd_gotoxy(8, 2);
         lcd_putc("Setup");
         lcd_gotoxy(6, 3);
         lcd_putc("Parameters");
         delay_ms(dly_1);
         lcd_putc("\f");
         lcd_gotoxy(5, 1);
         lcd_putc("Hour Format");
         lcd_gotoxy(1, 2);
         lcd_putc("0. 24 Hour Format");
         lcd_gotoxy(1, 3);
         lcd_putc("1. 12 Hour Format");
         lcd_gotoxy(1, 4);
         lcd_putc("Selection: ");
         while(getKbd() > 1)
                  delay_ms(40);
                  hr_format = getKbd();
         lcd_gotoxy(12, 4);
         printf(lcd_putc, "%d", hr_format);
         delay_ms(dly_1);
         lcd_putc("\f");
         lcd_gotoxy(7, 1);
         lcd_putc("Set Time");
         switch(hr_format)
                  case 1:
                           lcd_gotoxy(4, 2);
                           lcd_putc("00:00:00  AM");
                           hr = getParameter(hr, 12, 1, 4, 2);
                           lcd_gotoxy(7, 2);
                           lcd_putc("00:00  AM");
                           min = getParameter(min, 59, 0, 7, 2);
                           lcd_gotoxy(10, 2);
                           lcd_putc("00  AM");
                           s = getParameter(s, 59, 0, 10, 2);
                  default:
                           lcd_gotoxy(7, 2);
                           lcd_putc("00:00:00");
                           hr = getParameter(hr, 23, 0, 7, 2);
                           lcd_gotoxy(10, 2);
                           lcd_putc("00:00");
                           min = getParameter(min, 59, 0, 10, 2);
                           lcd_gotoxy(13, 2);
                           lcd_putc("00");
                           s = getParameter(s, 59, 0, 13, 2);
         if(hr_format)
                  while(getKbd() > 1)
                           delay_ms(40);
                           am_pm = getKbd();
                  lcd_gotoxy(14, 2);
                  switch(am_pm)
                           case 1:
                                    lcd_putc("PM");
                           default:
                                    lcd_putc("AM");
         lcd_gotoxy(7, 3);
         lcd_putc("Set Date");
         lcd_gotoxy(6, 4);
         lcd_putc("31/12/99 - SUN");
         dt = getParameter(dt, 31, 1, 6, 4);
         lcd_gotoxy(9, 4);
         lcd_putc("12/99 -");
         mt = getParameter(mt, 12, 1, 9, 4);
         lcd_gotoxy(12, 4);
         lcd_putc("99 -");
         yr = getParameter(yr, 99, 0, 12, 4);
         lcd_gotoxy(17, 4);
         lcd_putc("SUN");
         dy = setDay(dy, 17, 4);
         delay_ms(dly_1);
         lcd_putc("\f");
         unsigned char p = 0;
         for(;;)
                  p = getKbd();
                  showDay(dayValue, x_pos, y_pos);
                  if((p >= 1) && (p <= 7))
                           dayValue = p;
                  if(p == 0x0A)
                           return dayValue;
         switch(day_val)
                  case 1:
                           lcd_putc("SUN ");
                  case 2:
                           lcd_putc("MON ");
                  case 3:
                           lcd_putc("TUE ");
                  case 4:
                           lcd_putc("WED ");
                  case 5:
                           lcd_putc("THR ");
                  case 6:
                           lcd_putc("FRI");
                  case 7:
                           lcd_putc("SAT");
         lcd_gotoxy(6, 1);
         lcd_putc("DS3231 RTC");
         lcd_gotoxy(1, 3);
         printf(lcd_putc, "Date: %02u/%02u/%02u ", dt, mt, yr);
         showDay(dy, 16, 3);
         lcd_gotoxy(1, 4);
         printf(lcd_putc, "Temp: %2.2g'C ", getTemp());
         lcd_gotoxy(1, 2);
         switch(hr_format)
                  case 1:
                           switch(am_pm)
                                    case 1:
                                             printf(lcd_putc, "Time: %02u:%02u:%02u PM ", hr, min, s);
                                    default:
                                             printf(lcd_putc, "Time: %02u:%02u:%02u AM ", hr, min, s);
                  default:
                           printf(lcd_putc, "Time: %02u:%02u:%02u     ", hr, min, s);
         delay_ms(600);
SShahryiar
shehwar
Just a simple question about this driver.
PostPosted: Fri May 29, 2015 7:33 am     Reply with quote
There are no i2c error checks whether slave responds with an ACK or not.
Aren't they necessary with this particular chip? and one more thing, datasheet for ds3231 (pg 11), 'statusReg' has a busy flag bit.
Shouldn't we check this flag before reading or writing to this chip?
sshahryiar
DS3231 RTC
PostPosted: Fri May 29, 2015 8:08 am     Reply with quote
Ported the same code for AVR without trouble.... Check this video out:
https://www.youtube.com/watch?v=VCnXEUmuZUo
Also check out the working of the example code given with this post:
https://www.facebook.com/MicroArena/photos/pb.113572212076237.-2207520000.1432908229./350564778376978/?type=3&theater
SShahryiar
shehwar
No doubts
PostPosted: Fri May 29, 2015 3:05 pm     Reply with quote
Bro, i have no doubts about your driver but i used it with my DS3231SN, it gave me 2 mins difference in time in just a day. Probably i would be doing something wrong, so im figuring out the solutions/workarounds. Can you tell me what i2c rate did u used? i used it with 400Kbps. Or can you suggest where problem can be?
newguy
PostPosted: Fri May 29, 2015 3:20 pm     Reply with quote
RTCs are only as accurate as the PCB they're mounted on is good.
shehwar
PCB Design
PostPosted: Fri May 29, 2015 3:27 pm     Reply with quote
As far as PCB is concerned, i have taken good care in designing with the consultation of datasheet. No signaling tracks are around the RTC and its close to i2c pins of 18f452. SCK and SCL pins are pull-up with 1K. Battery properly mounted and connections. Verified the hardware.
sshahryiar
RTC Issues
PostPosted: Fri May 29, 2015 6:39 pm     Reply with quote
Bro I used the default I2C data transfer rate of 20kHz.... @ Mr. Shehwar
SShahryiar
shehwar
Thank you for all the help.
PostPosted: Sun May 31, 2015 5:22 pm     Reply with quote
I'll try lowering the i2c transfer rate and post the results, may be this can help others aswell.
by the way, thanks.
shehwar
Thanks for everybody's help
PostPosted: Wed Jun 24, 2015 2:29 pm     Reply with quote
Driver runs perfectly with
"#use i2c(Master, SDA=pin_C4, SCL=pin_C3)"
i guess default i2c rate is working fine, raising the rates disturbs the internal operation of the IC.
sshahryiar
Welcome....
PostPosted: Wed Jun 24, 2015 9:01 pm     Reply with quote
Cool
SShahryiar
