Enable/disable interrupts
pudozh
PostPosted: Fri May 08, 2015 8:05 am     Reply with quote
Good day
i must perform enabling an interrupt ( and a timer) while executing an another interrupt:
code:
#include <16F1509.h>
#device ADC=10
#FUSES NOMCLR                   //no MCLR pin
#FUSES HS                       //External Oscillator
#byte CLC4GLS0=getenv("SFR:CLC4GLS0")
#byte CLC4GLS1=getenv("SFR:CLC4GLS1")
#byte CLC4GLS2=getenv("SFR:CLC4GLS2")
#byte CLC4GLS3=getenv("SFR:CLC4GLS3")
#byte CLC4SEL0=getenv("SFR:CLC4SEL0")
#byte CLC4SEL1=getenv("SFR:CLC4SEL1")
#byte CLC4POL=getenv("SFR:CLC4POL")
#byte CLC4CON=getenv("SFR:CLC4CON")
#byte PIR1=getenv("SFR:PIR1")
#byte PIE1=getenv("SFR:PIE1")
#byte T2CON=getenv("SFR:T2CON")
#byte TMR2=getenv("SFR:TMR2")
#byte PR2=getenv("SFR:PR2")
#bit  TMR2IE = PIE1.1
#bit  TMR2IF = PIR1.1
#use delay(crystal=20MHz)
int16 deep1;
void clcconf1(void);
#INT_TIMER2
void  TIMER2_isr(void)
 if (!(deep1--)) {
  output_high(PIN_C0); // enable led
  delay_us(2000);       // pulse width
  output_low(PIN_C0); // led off
  TMR2IF = 0;  //clear int flag
  TMR2IE = 0; // disable interrupt
  T2CON = 0; // stop timer2
  output_high(PIN_A1); //reset clc flip flop (FF)
  output_low(PIN_A1);
#INT_CLC4
void  CLC4_isr(void)
  deep1 = 150;
  PR2 = 139; //
  T2CON = 0b000110110; // timer2 on
 TMR2IE = 1;  //enable interrupt timer2
// to avoid error if use delay with interrupt routine
   set_tris_a(0b11111001); //Bit 1 = input Bit 0 = output
   set_tris_b(0b01111111); //Bit 1 = input Bit 0 = output
   set_tris_c(0b00100100); //Bit 1 = input Bit 0 = output
   clcconf1();
   output_high(PIN_A1); //reset clc4 flip flop
   output_low(PIN_A1);
   enable_interrupts(INT_CLC4);
      //code
When the CLC flip flop is fired the second interrupt work but after resetting the CLC is not possible to fire it again.
Any idea?
compiler is 5.008
pudozh
PostPosted: Fri May 08, 2015 8:13 am     Reply with quote
Good day
a mistake on CLC4 int routine:
T2CON = 0b000110110; // timer2 on wrong
T2CON = 0b00101110; // timer2 on correct
Regards
PostPosted: Fri May 08, 2015 8:48 am     Reply with quote
Just use CCS code....
You do not need to fiddle with the bits, and what you are doing wastes an instruction.
#INT_TIMER2
   if (!(deep1--))
      disable_interrupts(INT_TIMER2);
      setup_timer_2(FALSE);
      output_low(PIN_A1);
The compiler always automatically clears interrupts for you, unless you specifically tell it not to (NO_CLEAR). So doing this is pointless.
You can just use the compiler's disable _interrupts instruction, and tell the compiler to stop the time. The same applies in all your other routines. clear_interrupt etc...
However there is a big problem, from using the delay routine in the interrupt. The compiler _will_ be giving you a warning that interrupts are disabled to prevent re-entrancy in the delay routine in the main code. Think again. There are lots of ways to do this to avoid this.....
pudozh
PostPosted: Fri May 08, 2015 10:19 am     Reply with quote
Thanks for suggest :
I've changed the code but the working is the same.
CLC4 FF give interrupt, interrupt on timer2 starts but at the end of routine
pin a1 reset the clc flip flop and after no more clc interrupts.
#device ADC=10
#FUSES HS                       //Externrnal Oscillator
int16 deep1;
#INT_TIMER2
  if (!(deep1--)) {
      disable_interrupts(INT_TIMER2); //disable interrupt
      setup_timer_2(FALSE,1,1); // disable timer
      output_low(PIN_A1);
#INT_CLC4
void  CLC4_isr(void)
 deep1 = 150;
 setup_timer_2(T2_DIV_BY_16,139,3);      //448 us overflow, 1,3 ms interrupt
// questa istanza รจ usata due volte per le routine di delay sotto interrupt
   clcconf1();
   output_low(PIN_A1);
      //code
void clcconf1(void)
// File: pagina2_sim.inc
// Generated by CLC Designer, Version: 3.0.0.4
// Date: 05/03/2015 21.28
// Device:PIC16(L)F1508/9
   CLC4GLS0  = 0x02;
   CLC4GLS1  = 0x00;
   CLC4GLS2  = 0x80;
   CLC4GLS3  = 0x00;
   CLC4SEL0  = 0x00;
   CLC4SEL1  = 0x50;
   CLC4POL   = 0x02;
   CLC4CON   = 0xD4;
I don't know how the compiler polling multiple irq but something happens enabling / disabling irq
Suggest?
PostPosted: Fri May 08, 2015 11:11 am     Reply with quote
Also, your #use delay is too late in the code, it should be right
after the #fuses in this case. You can only have ONE #use delay.
Also, you cannot have a 2ms delay in an interrupt routine. During
that delay interrupts are disabled. Get in and get out as quickly as
possible! You will need to form your pulse another way.
