ADC for a AC signal question
irmanao
PostPosted: Wed Apr 08, 2015 10:39 am     Reply with quote
I have a ac signal from 0,1V to 3,1V that i want to process with a dspic. I would then like to do zero crossing (at 1,6V), my question is : are the 3,1V replaced by the value of 1023 (10bit) and the 0,1V by 0?
thanks
PostPosted: Wed Apr 08, 2015 10:56 am     Reply with quote
Depends on where you set the voltage references....
If you set Vref- to 0.1v, and Vref+ to 3.1v, then the ADC will read from 0.1v to 3.1v. That's what the reference inputs are for....
irmanao
PostPosted: Wed Apr 08, 2015 11:00 am     Reply with quote
I wasn't aware of that, thank you very much, i am new to programming.
Mike Walne
PostPosted: Wed Apr 08, 2015 11:03 am     Reply with quote
Depends on your ADC, ac signal and what you want to do with the data.
Assuming your ac signal is swinging from 0V1 to 3V1, the ADC lower ref is 0V1 and upper ref is 3V1, then you are probably correct.
Depending on the nature of your ac signal you may not need to use zero crossing.
Mike
EDIT I see Mr T. got in as I typed.
PostPosted: Wed Apr 08, 2015 11:10 am     Reply with quote
It's NOT an 'ac ' signal if it transitions from +0V1 to +3V1, rather just a DC signal...
perhaps a 'moot' point but PIC ADC subsystems will NOT tolerate a real AC signal !!
jay
irmanao
PostPosted: Wed Apr 08, 2015 11:22 am     Reply with quote
Yes i know the average is not 0 so it's not a ac signal
thanks
the signal is a sine wave (50 Ηz) and i need to trigger a pulse for two SCR's at the 1.6V point after a delay
PostPosted: Wed Apr 08, 2015 12:31 pm     Reply with quote
have a look at this PDF selector matrix
http://www.microchip.com/stellent/groups/sitecomm_sg/documents/devicedoc/en570055.pdf
see the column ZCD under the gold heading Intelligent Analog
ZCD= Zero Crossing Detector
the pics designated are OPTIMIZED for just what you want to do only SO MUCH better than you may have envisioned.
check data for parts
16f161x
and
18fxx40/42
PostPosted: Wed Apr 08, 2015 12:36 pm     Reply with quote
Also, seriously, 'step back'. The poster needs to start by doing some basic C programming before trying to work with AC.
1) Do a basic 'hello world' output.
2) Read an ADC, and then experiment with how the numbers relate to the voltages etc..
3) Learn how to loop, test, one stage at a time.
Trying to jump in the deep end, rather than starting with basics, is a sure way of wasting a lot of time.
PostPosted: Wed Apr 08, 2015 2:41 pm     Reply with quote
hmm....
NOW you're telling us it really IS an AC waveform, so you CANNOT feed that signal into the PICs ADC. well you can but risk destroying it !
The PICs ADC section is NOT designed for -ve voltages, ONLY +ve ones.
jay
asmallri
PostPosted: Wed Apr 08, 2015 6:01 pm     Reply with quote
temtronic wrote:
hmm....
jay
I interpreted this differently as an AC signal superimposed on a DC offset.
Regards, Andrew
PostPosted: Wed Apr 08, 2015 6:47 pm     Reply with quote
hmmmmmmmm... perhaps the original poster can show us an example of his input waveform.
A 50Hz sine wave usually tells me it's 'mains voltage' from across the pond.
Having a 'zero cross' at 1.6V when the signal goes from .1 to 3.1 does sound like superimposed AC on a DC level.
now I'm more confused....
a picture would be worth 1000 words ( or bytes !)
Jay
irmanao
PostPosted: Thu Apr 09, 2015 4:38 am     Reply with quote
It is superimposed on a DC offset
