DS1307 interface
Goto page 1, 2  Next
aaronik19
DS1307 interface
PostPosted: Sat Apr 04, 2015 3:13 pm     Reply with quote
Dear all,
I am trying to work with my RTC DS1307 module and it does not work. The main program is this:
#include <program.h>
#define LCD_RS_PIN      PIN_A3
#define LCD_RW_PIN      PIN_A2
#define LCD_ENABLE_PIN  PIN_A1
#define LCD_DATA4       PIN_D4
#define LCD_DATA5       PIN_D5
#define LCD_DATA6       PIN_D6
#define LCD_DATA7       PIN_D7
#include <lcd.c>
#include <ds1307.C>
int count1 = 0;
//timeclock variables
BYTE sec;
BYTE min;
BYTE hrs;
BYTE day;
BYTE month;
BYTE yr;
BYTE dow;
#INT_EXT
void  EXT_isr(void)
if (PIN_A4)
   output_toggle(PIN_E2);
   lcd_putc("\fReady...\n");
   enable_interrupts(INT_EXT);
   ds1307_init();
   ds1307_set_date_time(15,6,5,2,15,20,55);
  printf("done");
    ds1307_get_date(day,month,yr,dow);
    ds1307_get_time(hrs,min,sec);
    printf( "\f\%02d/\%02d/\%02d\r\n",day,month,yr);
    printf( "\%02d:\%02d:\%02d", hrs,min,sec);
and the driver is:
///                               DS1307.C                                   ///
///                     Driver for Real Time Clock                           ///
/// ds1307_init() - Enable oscillator without clearing the seconds register -///
///                 used when PIC loses power and DS1307 run from 3V BAT     ///
///               - Disable squarewave output                                ///
/// ds1307_set_date_time(day,mth,year,dow,hour,min,sec)  Set the date/time   ///
/// ds1307_get_date(day,mth,year,dow)               Get the date             ///
/// ds1307_get_time(hr,min,sec)                     Get the time             ///
#define RTC_SDA  PIN_D7
#define RTC_SCL  PIN_D6
#use i2c(master, sda=RTC_SDA, scl=RTC_SCL)
BYTE bin2bcd(BYTE binary_value);
BYTE bcd2bin(BYTE bcd_value);
void ds1307_init(void)
   BYTE seconds = 0;
   i2c_start();
   i2c_write(0xD0);      // WR to RTC
   i2c_write(0x00);      // REG 0
   i2c_start();
   i2c_write(0xD1);      // RD from RTC
   seconds = bcd2bin(i2c_read(0)); // Read current "seconds" in DS1307
   i2c_stop();
   seconds &= 0x7F;
   delay_us(3);
   i2c_start();
   i2c_write(bin2bcd(seconds));     // Start oscillator with current "seconds value
   i2c_start();
   i2c_write(0x07);      // Control Register
   i2c_write(0x80);     // Disable squarewave output pin
   i2c_stop();
void ds1307_set_date_time(BYTE day, BYTE mth, BYTE year, BYTE dow, BYTE hr, BYTE min, BYTE sec)
  sec &= 0x7F;
  hr &= 0x3F;
  i2c_start();
  i2c_write(0xD0);            // I2C write address
  i2c_write(0x00);            // Start at REG 0 - Seconds
  i2c_write(bin2bcd(sec));      // REG 0
  i2c_write(bin2bcd(min));      // REG 1
  i2c_write(bin2bcd(hr));      // REG 2
  i2c_write(bin2bcd(dow));      // REG 3
  i2c_write(bin2bcd(day));      // REG 4
  i2c_write(bin2bcd(mth));      // REG 5
  i2c_write(bin2bcd(year));      // REG 6
  i2c_write(0x80);            // REG 7 - Disable squarewave output pin
  i2c_stop();
void ds1307_get_date(BYTE &day, BYTE &mth, BYTE &year, BYTE &dow)
  i2c_start();
  i2c_write(0xD0);
  i2c_write(0x03);            // Start at REG 3 - Day of week
  i2c_start();
  i2c_write(0xD1);
  dow  = bcd2bin(i2c_read() & 0x7f);   // REG 3
  day  = bcd2bin(i2c_read() & 0x3f);   // REG 4
  mth  = bcd2bin(i2c_read() & 0x1f);   // REG 5
  year = bcd2bin(i2c_read(0));            // REG 6
  i2c_stop();
void ds1307_get_time(BYTE &hr, BYTE &min, BYTE &sec)
  i2c_start();
  i2c_write(0xD0);
  i2c_start();
  i2c_write(0xD1);
  sec = bcd2bin(i2c_read() & 0x7f);
  min = bcd2bin(i2c_read() & 0x7f);
  hr  = bcd2bin(i2c_read(0) & 0x3f);
  i2c_stop();
  BYTE temp;
  BYTE retval;
  temp = binary_value;
  retval = 0;
    // Get the tens digit by doing multiple subtraction
    // of 10 from the binary value.
    if(temp >= 10)
      temp -= 10;
      retval += 0x10;
    else // Get the ones digit by adding the remainder.
      retval += temp;
  return(retval);
// Input range - 00 to 99.
  BYTE temp;
  temp = bcd_value;
  // Shifting upper digit right by 1 is same as multiplying by 8.
  temp >>= 1;
  // Isolate the bits for the upper digit.
  temp &= 0x78;
  // Now return: (Tens * 8) + (Tens * 2) + Ones
  return(temp + (temp >> 2) + (bcd_value & 0x0f));
now since I already have the MAX517 on pins C4 and C3 (hardware I2C) I used a software I2C for the RTC as can be seen on the RTC driver. But the LCD remains "Ready..." and on the hyperterminal nothing is being displayed. The module I am using is shown here:
http://www.instructables.com/id/Arduino-Shower-Monitor-2/
the module has built in 3k3 on I2C bus that's why I used a seperate i2c ports.
huynhhai
PostPosted: Sat Apr 04, 2015 9:06 pm     Reply with quote
You should use direct code to display lcd & read RTC no using interrupt & do it step by step, display any your info on lcd ok, then read RTC to display LCD, don't forgot enable internal oscillate of RTC, can you check it
Regards,
PostPosted: Sat Apr 04, 2015 10:17 pm     Reply with quote
You are using the same pins for the LCD and the ds1307.
Don't do that.
aaronik19
PostPosted: Sun Apr 05, 2015 2:19 am     Reply with quote
Dear all, thanks for your replies. Actually i removed all the enable_interrupts including the global one and it worked perfectly even on the same max517 i2c bus line C3 and C4 pins. What could be the problem?
huynhhai
PostPosted: Sun Apr 05, 2015 11:58 am     Reply with quote
Maybe, your code at the programs interrupt no ok, therefore programs can not return to main programs ==> can not read RTC to display LCD
aaronik19
PostPosted: Sun Apr 05, 2015 12:06 pm     Reply with quote
Is there any pattern or sequence where i should list the enable interrupts e.g. at the beginning of the main routine or after the initialization of the drivers? Or it does not make any difference?
huynhhai
PostPosted: Sun Apr 05, 2015 1:17 pm     Reply with quote
try to put this code look like below
#include <lcd.c>
#include <ds1307.C>
#INT_EXT
void  EXT_isr(void)
if (PIN_A4)
you put interrupt code wrong position maybe interrupt no active, check it again
PostPosted: Sun Apr 05, 2015 1:29 pm     Reply with quote
This won't work:
if (PIN_A4)
To read a pin, you must use the input() function. Example:
if(input(PIN_A4))
aaronik19
PostPosted: Mon Apr 06, 2015 12:50 am     Reply with quote
Ooops...yes you are right! I will update the code and try again.
aaronik19
PostPosted: Mon Apr 06, 2015 3:16 am     Reply with quote
Dear All,
continue to working on the "strange" situation that I have on my code regaring the #INT statements! This is the code.
#include <MAX517.C>
#include <ds1307.C>
#include <lcd.c>
BYTE sec;
BYTE min;
BYTE hrs;
BYTE day;
BYTE month;
BYTE yr;
BYTE dow;
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);      //104 ms overflow
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_TBE);
   ds1307_init();
   delay_ms(400);
   delay_ms(400);
   while(true)
    lcd_gotoxy(0,0);
    printf(lcd_putc, "Date: \%02d/\%02d/\%02d\r\n",day,month,yr);
    lcd_gotoxy(0,1);
    printf(lcd_putc, "Time: \%02d:\%02d:\%02d", hrs,min,sec);
This code is working 100% but when I insert the following code just after the timeclock variables the program hangs:
#INT_TIMER1
void  TIMER1_isr(void)
#INT_EXT
void  EXT_isr(void)
#INT_RDA
void  RDA_isr(void)
#INT_TBE
void  TBE_isr(void)
I tried to put one statement at a time, and also change the place where i put this code, but it was in vain. Sorry but I need to use all the interrupts that's why I put them all.
aaronik19
PostPosted: Mon Apr 06, 2015 3:18 am     Reply with quote
sorry forgot to mention, I am using PIC18F4520 with crystal 20MHz
alan
PostPosted: Mon Apr 06, 2015 3:44 am     Reply with quote
Maybe there is a char in the RX reg and it keeps on firing the INT_RDA, try reading the RX reg and try.
When you tried adding them one at a time you did disable the interrupts that
didn't had any handler.
Just suggestions.
Regards
PostPosted: Mon Apr 06, 2015 4:21 am     Reply with quote
Of course it would.....
Alan has given the first potential part. An INT_RDA handler _must_ always read a character, or the code will hang forever if this triggers. However even if this doesn't trigger there is a second problem.
The second part is INT_TBE. This _must_ only be enabled, when you have characters to send. Look at how ex_stisr works. The interrupt is disabled in the handler, once the last character is sent. INT_TBE says 'I want a character to transmit'. Unless you transmit one, the interrupt _will_ trigger again instantly.
You can never enable INT_TBE, until you have data waiting to send. The handler needs to either load a character, or disable the interrupt, or it can never exit.
huynhhai
PostPosted: Tue Apr 07, 2015 12:54 am     Reply with quote
Are you forgot setup for priority interrupt? test one interrupt actived
aaronik19
PostPosted: Tue Apr 07, 2015 1:08 am     Reply with quote
thanks for everyone. Now everything is sorted regarding this issue.
Goto page 1, 2  Next
Page 1 of 2
