Mahdi
| dspic33fj input capture |
Posted: Tue Mar 31, 2015 8:38 am |
hi buddies
i want to measure duty cycle and freq of pwm signal with 1khz freq with input capture.
my code :
| Code: | #include <33FJ256MC710.h>
#use delay(internal=7.37m)
#include <lcd.c>
setup_timer3(TMR_INTERNAL | TMR_DIV_BY_8);
setup_capture(3, CAPTURE_FE | CAPTURE_TIMER3);
int16 p=0;
p = get_capture(3,TRUE);
lcd_gotoxy(1,1);
printf(lcd_putc,"%lu",p);
but i have random number on lcd
iam for first to use input capture
can any one help me?
(excuse for poor english)
thank you |
Posted: Tue Mar 31, 2015 9:18 am |
You have your input signal on pin70?. IC3.
Since you are using capture unit 3, this is where the input has to be.
You really should test for the capture event having happened:
if (interrupt_active(INT_IC3))
//This says an event has happened
//read the captured value, and clear the interrupt
clear_interrupts(INT_IC3);
Mahdi
Posted: Tue Mar 31, 2015 10:06 am |
| Ttelmah wrote: | You have your input signal on pin70?. IC3.
thank you for reply
yes.on pin 70.pin_d10
but yet lcd show random number
#include <lcd.c>
#INT_IC3
void ic3_isr(void)
enable_interrupts(INT_IC3);
setup_capture(3, CAPTURE_EE | INTERRUPT_EVERY_CAPTURE | CAPTURE_TIMER3);
int16 p=0;
clear_interrupt(INT_IC3);
a++;
lcd_gotoxy(1,1);
Posted: Tue Mar 31, 2015 10:43 am |
Remember this is a _capture_. You need:
int16 old=0;
//other init code etc...
//loop etc..
lcd_gotoxy(1,1);
printf(lcd_putc,"%lu",p-old);
old =p;
You have to calculate the change between the two capture events, to get the period. Look at ex_capture.c, where this is shown. |
