Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
PIC18F8722 SPI Port using Timer2
Coffee
PostPosted: Tue Feb 10, 2015 3:31 pm     Reply with quote
I'm posting this little test program because I couldn't find anything that dealt with my situation specifically. I found a couple of erratas that concerned me about using Timer2 for a SPI port clock. I also found a couple of postings that indicated there were some problems using Timer2 for the a SPI port clock on certain PIC controllers. With a little research I determined that those postings didn't really apply to my specific application.
Anyway, while this demo is trivial, it does work. It shows that Timer2 can be used with PIC18F8722 SPI1 using the PICC compiler as documented.
This has a SPI clock rate of 1.6 msecs which is as slow as I could get using a 20 MHz processor clock.
#include <main.h>
Quick test program for the PIC18F8722 controller SPI1 port.
SPI1 using hardware MASTER
Mode 0
Using Timer2 for spi_clk
CCS:  PCWH Compiler  Version 5.040
Hardware: CCS PIC18F8722 development board
// SPI modes borrowed from CCSinfo.com forum posts
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
   // initialize
   setup_timer_2(T2_DIV_BY_16,0xff,1);
   setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_T2);
   output_LOW(PIN_A1);  // my SPI_LOAD Pin
   // run test
      spi_write(0xA3); // something to write
      //SPI_LOAD assert
      output_high(PIN_A1);
      delay_ms(1);
      output_low(PIN_A1);
Many thanks to this forum for all the useful postings.
Thank you,
Bill
