HMC5883L Digital Compass Library
Goto page Previous  1, 2
Post new topic   Reply to topic    CCS Forum Index -> Code Library
nuwanw
PostPosted: Thu Feb 05, 2015 1:50 am     Reply with quote
Yes, but here in Australia. It's nearly 3 degrees behind, can I put -3 for declination value ?
Thank you in advance
nuwanw
PostPosted: Thu Feb 05, 2015 6:12 pm     Reply with quote
Hi sshahryiar,
Could you please let me know how to convert that 3 degrees to that value , here my issue is when I rotate the compass chip in a small amount , it displays huge angle, for an example, for 20 degree it indicates 60-80 degrees , however it gives the full scale from 0 to 360, I'm stucked and could you please give me a direction?
Thank you
nuwanw
Hi sshahryiar,
Could you please let me know how to convert that 3 degrees to that value. Here my issue is when I rotate the compass chip in a small amount, it displays huge angle, for an example, for 20 degree it indicates 60-80 degrees However it gives the full scale from 0 to 360. I'm stucked and could you please give me a direction?
Thank you
sshahryiar
Magnetic Declination
PostPosted: Fri Feb 06, 2015 10:00 pm     Reply with quote
Find the magnetic declination of your region using this link:
http://www.magnetic-declination.com
https://www.facebook.com/MicroArena
SShahryiar
nuwanw
PostPosted: Fri Feb 06, 2015 10:40 pm     Reply with quote
It's 3 degrees positive east, do I need to convert 3 degrees to radiant ?
sshahryiar
PostPosted: Fri Feb 06, 2015 10:50 pm     Reply with quote
yeah....
SShahryiar
nuwanw
PostPosted: Fri Feb 06, 2015 11:00 pm     Reply with quote
then the radiand value is +0.052359878, but it did not make a considerable difference, what may be the issue?
sshahryiar
Possible Issues
PostPosted: Fri Feb 06, 2015 11:30 pm     Reply with quote
Possible Issues:
1. Disturbance due to nearby metallic or electronic object(s)....
2. Tilting.... This is not a tilt compensated compass module likeHMC6352....
3. Interference from electrical sources generating considerable amount of magnetic disturbance....
4. Poor PCB design layout....
SShahryiar
nuwanw
PostPosted: Sat Feb 07, 2015 2:51 am     Reply with quote
Ok thanks
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
Page 2 of 2
