		| Author | Message |
		| nhruch
				| CCS C Compiler IDE Crashing Constantly in Windows |
				|  Posted: Thu Feb 05, 2015 6:45 pm |   |
				| I bought the PCWHD compiler and IDE and after a recent upgrade, the IDE crashes in Windows 7 about every 5 minutes. I can't keep it running long enough to do any changes to my code and it is an extreme pain in the [spam]. Is this a common problem? What information would someone need from me to help resolve this. It crashes and just says:
 C Compiler IDE has stopped working
 A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
 I've restarted and reinstalled the IDE, and rebooted the computer.
		| dyeatman
				|  Posted: Thu Feb 05, 2015 6:58 pm |   |
				| I run PCWHD latest versions on three different machines (two desktops and a laptop) all running Windows 7 with no problems at all. Sounds like a Windows security issue.  Did you install it as Administrator?
		| ELCouz
				|  Posted: Thu Feb 05, 2015 8:22 pm |   |
				|  	  | dyeatman wrote: |  	  | I run PCWHD latest versions on three different machines (two desktops and a laptop) all running Windows 7 with no problems at all. Sounds like a Windows security issue.  Did you install it as Administrator?
 I second that...PC issue...try on another one!
 Regards,
 Laurent
 Here's my first visual theme for the CCS C Compiler. Enjoy!
		| Ttelmah
				|  Posted: Fri Feb 06, 2015 1:44 am |   |
				| What processor?.
 Funnily enough, I have seen this a couple of times recently, but only with one specific processor. A 33FJ16MC102. Hasn't done it once with any other processor, and even on this one, only does it when I use one particular function. I changed my code to avoid this, and since it has been fine.
