How to correctly compare address of a structures
kWoody_uk
PostPosted: Mon Feb 02, 2015 11:52 am     Reply with quote
A bit basic, but could someone tell me the correct code to compare the addresses of a structure to a structure pointer?
I have tried the following and looked at the list code and it is being ignored:-
typedef struct {
    int8 a;
    int8 b;
} structType;
structType structGlobal;
// Function prototype
void sumFunc( structType * structLocal );
// Main C entry point
void main( void )
    structType structTest;
    // Initialising elements of the local struct
    structTest.a = 5;
    structTest.b = 8;
    // Initialising elements of the global struct
    structGlobal.a = 2;
    structGlobal.b = 4;
    sumFunc( &structTest );
    if ( &structLocal == &structGlobal ) {
        // Rest of code
Is this just not legal C code or should I not be using the '&' symbol here?
Thanks in advance,
Keith
PostPosted: Mon Feb 02, 2015 1:03 pm     Reply with quote
A few too many &'s involved....
You are already passing the function, the address of a structure. This is what a 'pointer' is. The compiler optimises this away, since it knows this address, and it is not the same as &StructGlobal.
structLocal is already an address. You take the address of this, which then refers to the temporary variable used to pass the address. Not what you want.
    if ( structLocal == &structGlobal ) {
        // Rest of code
One way to help avoid this type of mistake, is to always call 'pointers' with a name to remind you it is a poiinter. So something like _ptr. So:
void sumFunc( structType * structLocal_ptr )
    if ( structLocal_ptr == &structGlobal ) {
        // Rest of code
kWoody_uk
PostPosted: Tue Feb 03, 2015 3:12 am     Reply with quote
Thanks Ttelmah.
I'll take your advice regarding the naming of pointers too.
Best Regards,
Keith
