Reusable code
kWoody_uk
Reusable code
PostPosted: Thu Jan 29, 2015 6:42 am     Reply with quote
Hi guys,
I'm trying to communicate with 4 x Pics acting as SPI slaves to a Master Pic, i.e. 4 x CS lines from the master.
The master Pic (which is what this is concerning) is an 18F46K22.
I'm not that experienced with C code and would like to implement the following function in the master, to transfer SPI data:-
// Transmit and receive SPI Data
void servicePic1Spi( void )
    int rxData;
    int txData;
    // Preparing slave Pic device for Spi coms
    output_low( PIC1_CS );
    // Checking if there is any data to send to the slave
    if ( dataInPic1SpiTxBuf() ) {
        txData = getPic1TxBuf();
    } else {
        txData = 0x00;
    // Start a simultaneous send/receive of spi data
    rxData = xferSpi1( txData );
    // Ending spi comms
    output_high( PIC1_CS );
    // Rest of code to parse received data...
How could I reuse this code to make a common function for each of the 4 slave pics? At the moment I have unique versions of this function for each slave device.
I experimented using structure pointers, but the code generated is quite large. I guess this is due to the architecture of the Pics.
Any suggestions would be greatly appreciated.
Thanks in advance,
Keith
PostPosted: Thu Jan 29, 2015 7:05 am     Reply with quote
I'm sure others that are real C programmers will reply but I'd probably just send the slavePIC # to your function ?
becomes
void servicePic1Spi( char slave_cs )
... output_low( PIC1_CS )
could be
output_low( slave_cs)
slave_cs is a 'global variable'
You'd also have to have a separate 'buffer' for the slave's data( 1...4) so you know what data came from which PIC !
Hopefully you get my idea, as I'm self taught bodger of C !
Jay
kWoody_uk
PostPosted: Thu Jan 29, 2015 8:09 am     Reply with quote
Ahh.. so I could assign a PIN_XX to a variable? Looking at the device file for this PIC they are defines in a 16bit number range, so I guess it should work.
That's the simple bit done then (thanks Jay).
How would I turn:-
into something like:-
if ( dataInPicXSpiTxBuf() ) {
        txData = getPicXTxBuf();
that is make these common? Would I have to pass offsets of memory locations and read/write variables to these functions?
Sounds a bit daunting...
Keith
PostPosted: Thu Jan 29, 2015 8:17 am     Reply with quote
If you look back a few days, there was a thread entitled : "PIC18F26K22 + 2 PORT RS232 + INT". In this I posted a set of routines that handle multiple 'buffers' through common code using the buffer name as the thing to distinguish what is being referenced. Not directly 'right', but I have used the same technique to handle buffers mixed onto things like SPI. Might give you a hint.
kWoody_uk
PostPosted: Thu Jan 29, 2015 8:20 am     Reply with quote
Thanks Ttelmah,
I'll have a look and see if I can learn from your example.
I love seeing how other people do things, it's inspiring Smile .
Keith
kWoody_uk
PostPosted: Fri Jan 30, 2015 5:51 am     Reply with quote
Hi Ttelmah,
I've been looking at your example for inspiration and I have been stuck on one of the macros you are using.
#define tobuff(bname,c) { bname.buff[bname.in]=c; \
                          bname.in=incin(bname); \
                          if (bname.in==bname.out) bname.out=incout(bname); \
#define frombuff(bname) ( btemp##bname=bname.buff[bname.out], \
                          bname.out=incout(bname), \
                          btemp##bname )
I understand the first in the your code above and how it will expand. But the second I'm lost with. How will it expand? I think the main things confusing me are the commas between statements, and of course how it relates to legal C code when expanded.
Could you help me with this please, as I've looked all over the web and cannot find a similar example?
Thanks in advance,
Keith
PostPosted: Fri Jan 30, 2015 1:09 pm     Reply with quote
Yes, they are somewhat serious macros... Smile
The '\' makes lines be treated as if they continue without breaks from each other. So all the lines are expanded.
The {} brackets make a section of code into a single code block.
Expressions separated by a comma, are evaluated left to right, and the type and size of the result, is that of the rightmost statement.
So the whole block:
btemp##bname )
Evaluates one statement at a time, and returns btemp##bname
The ## is the string catenation operator without spaces. So if used with (say) B1TX, results in btempB1TX being used as the variable name.
They are 'obtruse C', but make a tidy way to handle named buffers.
kWoody_uk
PostPosted: Mon Feb 02, 2015 3:23 am     Reply with quote
Thanks for your explanation Ttelmah. As usual, real code differs somewhat from example code, so your help is a blessing.
Best Regards,
Keith
PostPosted: Mon Feb 02, 2015 3:40 am     Reply with quote
I had posted buffer code in the past, but 'avoided' this particular version, because while it works well, and is efficient, it is 'dark C' (there are a lot of things you 'can' do in C, which need a three page explanation attached...). Smile
