#INLINE fixes the warning , but why ???
PostPosted: Wed Jan 28, 2015 2:45 pm     Reply with quote
Program build with xtal oscillator of 10mhz 18f2525
timer 0,1,2 have simple flag based #int handlers
there is NO #INT handler for timer3...
there are NO delay_xx calls of any kind ( _MS _US _CYCLES - nothing !!)
.LST hdr
CCS PCH C Compiler, Version 5.036, 15300 28-Jan-15 15:12
Filename: D:\A_FW2\Q8.lst
ROM used: 20222 bytes (41%)
Largest free fragment is 28926
RAM used: 487 (12%) at main() level
518 (13%) worst case
Stack used: 6 locations (4 in main + 2 for interrupts)
Stack size: 31
void Wait25MS(unsigned int8 howmany){
     #bit TMR3IF=0xFA1.1
     set_timer3(0);
     tmr3if=0;
     while(howmany){
           if (TMR3IF){
                tmr3if=0;
                --howmany;
// even this junk substitute causes the same warning.....
     while(howmany) --howmany;
then this .ERR file
>>> Warning 203 "Q8.c" Line 1900(1,1): Condition always TRUE ( while(1) )
>>> Warning 216 "Q8.c" Line 2461(1,2): Interrupts disabled during call to prevent re-entrancy: (Wait25MS)
Memory usage: ROM=41% RAM=12% - 13%
0 Errors, 2 Warnings.
Build Successful.
BTW: line 2461 is the very last line of MAIN() and the program file itself...
what is there about calling a non interrupting delay function that causes this ??
BTW: i get the exact same warning in Ver 4.141 too
Makes no sense to me........
BUT making the function
#INLINE
fixes the re-entrant warning
and.
then it compiles with just the one silly warn about while(1);
huh ??
PostPosted: Wed Jan 28, 2015 3:21 pm     Reply with quote
I didn't get any warnings. Tested with vs. 5.036.
Executing: "C:\Program files\Picc\CCSC.exe" +FH "PCH_Test.c" +DF +LY -T -A +M -Z +Y=9 +EA -EW #__18F2525=TRUE
Memory usage: ROM=0% RAM=0% - 0%
0 Errors, 0 Warnings.
Build Successful.
Loaded C:\Program Files\PICC\Projects\PCH_Test\PCH_Test.cof.
BUILD SUCCEEDED: Wed Jan 28 13:18:58 2015
Note while(TRUE) removes the other warning.
Test program:
#include <18F2525.h>
#fuses HS,NOWDT
#use delay (clock=10M)
     #bit TMR3IF=0xFA1.1
     set_timer3(0);
     tmr3if=0;
     while(howmany){
           if (TMR3IF){
                tmr3if=0;
                --howmany;
while(TRUE);
PostPosted: Wed Jan 28, 2015 4:06 pm     Reply with quote
It would suggest wait25ms, is being called inside an interrupt somewhere. If you call the routine in the main code, and also inside an interrupt routine, you will get the interrupt_disabled warning. This is because code cannot be called from inside 'itself'. Search here.
Since it does not use any variables, declaring it as #inline, will allow it to be used in both places, since it then becomes two separate routines.
PostPosted: Wed Jan 28, 2015 4:38 pm     Reply with quote
Just Got it: Thanks PCM_P
this is an inherited code mess being altered for a brand new client
- AND i had done a blind quick S&R job on to get rid of delay_MS () salted throughout the program , using timer3 for 25 msec increments of delay
and did not catch a function calling a function calling the function in question in the nest-- ;-((
AND MR. T was correct - i overlooked the stack situation inside the #int
the upside is i can now restructure the #int handler to do the deed
in question in MAIN() with just a bit flag set.
T H A N K S to you both for the kind analysis
PostPosted: Thu Jan 29, 2015 1:50 am     Reply with quote
Inherited code.....
Trying to work out an epithet for this without being rude.
Anyway, you 'step forwards'. Smile
drh
PostPosted: Thu Jan 29, 2015 9:09 am     Reply with quote
It's always fun trying to figure out what another person intended their undocumented code to do, then figure out why is doesn't do that. Then correct or re-write to make the customer happy. Even more fun getting paid to do that.
David
PostPosted: Thu Jan 29, 2015 9:24 am     Reply with quote
Inherited code.....
has anybody else run into 'comments' in alien code only to find that they say more about the authors degree ( or lack ) of skill than-
about the code it purports to describe ??
It is especially difficult when the circuitry allegedly under control
is deficient too. Good code can't fix a bad circuit, and making 'hacks' to an existing circuit board at the same time as reworking the code itself is extra fun to be had , with "inheritance" ...........
PostPosted: Thu Jan 29, 2015 10:07 am     Reply with quote
some times it's easier,faster, cheaper.... to just 'start from scratch' especially these days with hi speed PCs, CCS C compiler and 'instant' programming unlike the good old dayze of diode based boot 'proms', papertape readers, real 'core'.....
sigh
I miss them!
jay
PostPosted: Thu Jan 29, 2015 10:13 am     Reply with quote
The really fun one, is where you have what may be quite competent documentation, but it is in another language. Unfortunately a lot of technical terms are not translated by either programs or translators, unless you have one who 'knows' the specific stuff about a technical process. Trying to find a polyglot who is a specialist in a mix of fields like chemistry, electronics, industrial measurement, & optics, can be very hard indeed. Some of the automated translations are positively 'hysterical', on technical phrases....
