12F683, GP2 won't toggle [SOLVED]
PostPosted: Sun Jan 18, 2015 6:20 pm     Reply with quote
OK what silly thing have I missed trying to get GP2 to blink?
This is driving me nuts. PCM4.110. All other pins are good to go.
Using Picstartplus as Pickit3 doesn't like the 683 (something about mclr, internal clock) that's a 'side issue'. Have tried 2 PICs.
// 12F683test
#include <12f683.h>
#fuses INTRC_IO,NOWDT,PUT,NOPROTECT,NOMCLR
#use delay(clock=4000000)                   // 4MHz xtal
#define led0 pin_a0
#define led1 pin_a1
#define led2 pin_a2
#define led4 pin_a4
#define led5 pin_a5
void main(){
   setup_oscillator(OSC_4MHZ);            //internal 4 MHz osc   12f683
   setup_comparator(NC_NC_NC_NC);         //no comparators
   setup_adc_ports(no_analogs);         //no adc inputs
   setup_adc(adc_off);                  //no adc
   setup_timer_1(T1_disabled);            //no timer
   setup_ccp1(ccp_off);               //no ccp
   disable_interrupts(global);            //no interrupts
   delay_ms(500);                     // startup delay of .5 seconds
   do {
   output_toggle(led0);
   output_toggle(led1);
   output_toggle(led2);
   output_toggle(led4);
   output_toggle(led5);
   delay_ms(450);
   }while (TRUE);
}//end of main=================================================================
maybe I'm getting too old for this ??
thanks
Jay
Jerson
PostPosted: Sun Jan 18, 2015 6:55 pm     Reply with quote
Can you try by turning on the internal weak pull-ups? Possibly the R-M-W problem.
PostPosted: Sun Jan 18, 2015 9:42 pm     Reply with quote
See Ttelmah's post:
http://www.ccsinfo.com/forum/viewtopic.php?t=53002
PostPosted: Mon Jan 19, 2015 6:50 am     Reply with quote
finally it blinks! the Macro seems to have done it !! Though the amount of time spent is crazy compared to using an 18 pin PIC, sure hope the client wants more than 100 units.
Both my original white case PS+ and the flashed black case PS+ work fine, might tackle the PK3 nonsense later...
thanks
see you can teach an old dog new tricks!
Jay
PostPosted: Mon Jan 19, 2015 9:35 am     Reply with quote
As you will see in my reply your thread about programming, it is a _chip_ limitation. Nothing the PIcKit3 can do about it.
It can be programmed in any programmer that has control over the Vdd line.
