HDC1000 Reading sensor
Goto page 1, 2  Next
respected
PostPosted: Thu Jan 08, 2015 3:38 pm     Reply with quote
This is my arduino code and it works
#include <Wire.h>
long value1;
long value2;
long totalvalue;
float temperature;
void setup(){
  Serial.begin(9600);
  Wire.begin();
  Wire.beginTransmission(0x40);
  Wire.write(0x10);
  Wire.write(0x00); //
  Wire.endTransmission();
void loop(){
  temp_measure();
  Serial.print("\n\r");
  Serial.print(temperature);
  delay(500);
float temp_measure(){
  Wire.write(0x00);
 delay(10);
  Wire.requestFrom(0x40,2);
   value1 = Wire.read(); //
   value2 = Wire.read(); //
 totalvalue =((value1<<8)|value2);
 temperature= (totalvalue*0.0025177001953125)-40;
This is PIC code. It doesn't work. It comes data0= 0xff or 0xf7 or different value. But this is not true. It has to be temperature value. Can anyone help me please? Where is mistake?
#include <18F46J50.h>
#fuses HSPLL,PLL3,CPUDIV2,NOWDT,NODEBUG
#use delay(clock=24MHz,crystal=12MHz)
#use i2c(master,sda=pin_b5, scl=pin_b4, slow)
#use rs232(baud=115200,parity=N,xmit=PIN_A2,           bits=8,stream=USART2)
long totaltemp;
float temperature;
 char strstore[20];
void hdc_setup (void)
    i2c_start();
    i2c_write(0x40);
    i2c_write(0x80);
    i2c_write(0x02);
    i2c_write(0x10);
    i2c_write(0x00);
    i2c_stop();
   delay_ms(20);
void read_hdc(void)
   int8 data[2]={0,0};
   int i;
    i2c_start();
    i2c_write(0x80);
    i2c_write(0x00);
    i2c_write(0x81);
    for(i=0;i<2;i++)
    data[i]=i2c_read();
   i2c_stop();
   totaltemp=make16(data[0],data[1]);
   temperature=(totaltemp*0.0025177)-40;
          sprintf(strstore,"Temp= %f",temperature);
          fputs(strstore,USART2);
          delay_ms(250);
   hdc_setup();
   while (TRUE)
         read_hdc();
   } //while
   }//main
PostPosted: Thu Jan 08, 2015 3:57 pm     Reply with quote
i2c_start();
i2c_write(0x40);
i2c_write(0x80);
i2c_write(0x02);
i2c_write(0x10);
i2c_write(0x00);
i2c_stop();
delay_ms(20);
Arduino uses 7-bit format for the slave address. CCS uses 8-bit format.
You need to fix the CCS code. If you already did this with the 0x80, then
delete the 0x40 line.
void read_hdc(void)
int8 data[2]={0,0};
int i;
i2c_start();
i2c_write(0x80);
i2c_write(0x00);
i2c_write(0x81);
for(i=0;i<2;i++)
data[i]=i2c_read();
i2c_stop();
The last read needs a NACK. You don't need a for() loop for two reads.
respected
PostPosted: Thu Jan 08, 2015 4:45 pm     Reply with quote
I deleted 0x40 and i wrote
    i2c_start();
    i2c_write(0x80);
    i2c_write(0x00);
    i2c_write(0x81);
    data[0]=i2c_read();
    data[1]=i2c_read();
   i2c_stop();
but same result
PostPosted: Thu Jan 08, 2015 5:03 pm     Reply with quote
You need a NACK on the last read, as shown in bold below:
data[0]=i2c_read();
data[1]=i2c_read(0);
respected
PostPosted: Thu Jan 08, 2015 5:17 pm     Reply with quote
Thanks PCM programmer.
I think I have another problem. Result is irregular.
anyone says it is ok. But i didn't do.
http://www.element14.com/community/community/design-challenges/in-the-air-design-challenge/blog/2015/01/02/in-the-air-design-challenge--pollen-allergen-sensing-post-6-hdc1000-sensor#comment-48995
PostPosted: Fri Jan 09, 2015 12:54 pm     Reply with quote
Post a sample of your irregular results.
respected
PostPosted: Fri Jan 09, 2015 2:49 pm     Reply with quote
22:55:14.856> data0= 255
22:55:14.856> data1= 255
22:55:14.856> temp= 124.99
22:55:15.792> data0= 255
22:55:15.792> data1= 255
22:55:15.792> temp= 124.99
22:55:16.544> data0= 31
22:55:16.544> data1= 31
22:55:16.544> temp= -19.94
22:55:17.292> data0= 0
22:55:17.292> data1= 0
22:55:17.292> temp= -40.00
22:55:18.230> data0= 253
22:55:18.230> data1= 123
22:55:18.230> temp= 123.37
22:55:19.169> data0= 239
22:55:19.169> data1= 95
22:55:19.169> temp= 114.28
22:55:20.045> data0= 63
22:55:20.045> data1= 127
22:55:20.045> temp= 0.92
Serial port terminal screen
PostPosted: Fri Jan 09, 2015 3:07 pm     Reply with quote
You need to post the program you used to display those results.
That device has a specific setup . Also the last 2 bits are NOT part of the 'math' probably need to have the 14 bits right shifted then the math according to the datasheet.
Jay
respected
PostPosted: Fri Jan 09, 2015 3:11 pm     Reply with quote
long totaltemp;
float temperature;
 char strstore1[20];
char strstore2[20];
char strstore3[20];
    i2c_start();
   // i2c_write(0x40);
    i2c_write(0x80);
    i2c_write(0x02);
    i2c_write(0x10);
    i2c_write(0x00);
    i2c_stop();
   delay_ms(20);
void read_hdc(void)
   int8 data[4]={0,0,0,0};
    i2c_start();
    i2c_write(0x80);
    i2c_write(0x00);
    i2c_write(0x81);
    data[0]=i2c_read();
   i2c_stop();
          sprintf(strstore1,"data0= %u",data[0]);
          sprintf(strstore2,"data1= %u",data[1]);
          sprintf(strstore3,"temp= %f",temperature);
          fputs(strstore1,USART2);
          fputs(strstore2,USART2);
          fputs(strstore3,USART2);
          delay_ms(750);
   hdc_setup();
   while (TRUE)
         read_hdc();
   } //while
   }//main
PostPosted: Fri Jan 09, 2015 5:11 pm     Reply with quote
The HDC1000 has two address pins, ADR0 and ADR1. What connections
do you have to these two pins ?
What is the Vdd voltage on your PIC, on the HDC1000, and on the i2c
pullup resistors ?
What is the value of the i2c pullup resistors ?
What happens if you write a program to read a fixed value from the
hdc1000, such as the manufacturer ID word at address 0xFE ?
The data sheet says the ID word is 0x5449 (on page 14). Do you
always get that word, or do you sometimes get 0xFFFF ?
respected
PostPosted: Sat Jan 10, 2015 4:12 pm     Reply with quote
I tried with TI Sensor Evaluation Module. and I read codes with logic analyser
for 0x5449 i read
0x80+ack 0xfe+ack 0x81+ack 0x54+ack 0x49+nak
and i wrote pic mcu code
    i2c_start();
    i2c_write(0x80);
    i2c_write(0xFE);
    i2c_write(0x81);
    data[0]=i2c_read();
    i2c_stop();
i read code with logic analyser
1. 0x80+ack 0xfe+ack 0x81+ack 0x54+ack 0x48+nak
2. 0x80+ack 0x7f+ack 0x40+ack 0x95+ack 0x11+nak
3. 0x80+ack 0xfe+ack 0x81+ack 0x25+ack 0x82+nak
PostPosted: Sat Jan 10, 2015 9:59 pm     Reply with quote
I think there is something fundamentally wrong, such as you are
connecting capacitors to SDA and SCL, or the pullups are the wrong
value, or the power supply is bad.
Post a link to a schematic of your PIC to HDC1000 circuit.
How to post an image on the CCS forum:
Use http://www.postimage.com or http://www.imageshack.com
or some other free image hosting service.
Upload your schematic to that website. Preferably a .JPG file or some
other commonly used image format.
Then post a link to your image here in the forum.
respected
PostPosted: Sun Jan 11, 2015 11:03 am     Reply with quote
https://imageshack.com/i/f0tyuVnUj
I broke sensor and cpu board. Unfortunately pullup resistors was mcu side.
I added pullup (4K7) and It works now.
I sent code
   i2c_start();
    i2c_write(0x80);
    i2c_write(0xFE);
    i2c_write(0x81);
    data[0]=i2c_read();
    i2c_stop();
answer by sensor
data[0]=84 (0x54)
data[1]=73 (0x49)
Thanks for helping for everyone( especially PCM Programmer)
ADR0 and ADR1 default value is 0(GND)
I added 4K7 pullup registor for DRDYn. Special registers are ok. all of data are true. But temperature data and humidity data are coming 0xff.
I will try to continue.
HDC1000 data sheet says
Data ready, active low, open-drain; requires a pull-up resistor to VDD. If not used tie to GND or no connect.
    i2c_start();
    i2c_write(0x80);
    i2c_write(0x00);
    delay_ms(13);// I saw in the logic analyser signal
    i2c_write(0x81);
    data[0]=i2c_read();
    i2c_stop();
Everyting is OK.
respected
PostPosted: Sun Jan 11, 2015 3:07 pm     Reply with quote
This is full code.
#use i2c(master,sda=pin_b5, scl=pin_b4, slow=100000)
long totaltemp;
float temperature;
char strstore1[20];
char strstore2[20];
char strstore3[20];
    i2c_start();
    i2c_write(0x80);
    i2c_write(0x02);
    i2c_write(0x10);
    i2c_write(0x00);
    i2c_stop();
   delay_ms(20);
void read_hdc(void)
    i2c_start();
    i2c_write(0x80);
    i2c_write(0x00);
    delay_ms(13);
    i2c_write(0x81);
    data[0]=i2c_read();
    i2c_stop();
          sprintf(strstore2,"data1= %u\r\n",data[1]);
   hdc_setup();
   while (TRUE)
       read_hdc();
   } //while
   }//main
PostPosted: Sun Jan 11, 2015 7:43 pm     Reply with quote
nice to hear you got it 'up and running'.
Yes, I2C does need pullups ! too bad TI put them next to their micro and not the temp/hum sensor. It would have saved you some time BUT you learned a LOT of valuable 'hands on' experience.
jay
Goto page 1, 2  Next
Page 1 of 2
