Debug monitor
kmp84
Debug monitor
PostPosted: Mon Dec 15, 2014 6:48 am     Reply with quote
I'm using ccs c compiler ver.5.019 with ICD U64. Also using "Monitor" option in debug window. Sometime data were destroyed :
<-- Sending 2 bytes: 0x50 0x00ñjjUË‹V-ë$&H±ytes: 0x50 0x00
<-- Sending 2 bytes: 0x50 0x00 ,
Setting are :
#USE RS232(DEBUGGER,rcv=PIN_B5,xmit=PIN_B5,stream=STREAM_MONITOR)
Maybe problem is speed ? How to setup Speed ? What is the speed in above declaration?
Thanks,
PostPosted: Mon Dec 15, 2014 11:51 am     Reply with quote
The software UART for the Debug Monitor runs at 2400 baud. The CCS
IDE expects it to run at this speed. I don't know if the IDE has a menu
which allows this to be changed.
Are you running interrupts in your program ? Because this is a software
UART, interrupts could cause the problem that you are seeing. The
bit timing would be disrupted, causing you to get garbage part of the time.
Try adding the parameter shown in bold below:
#USE RS232(DEBUGGER,rcv=PIN_B5,xmit=PIN_B5, DISABLE_INTS, stream=STREAM_MONITOR)
kmp84
PostPosted: Tue Dec 16, 2014 3:50 am     Reply with quote
Thanks for explanation "PCM programmer", This Baud is to slowly for debugging in some fast serial and usb application for me, but I'll mail CCS support for this problem.Smile
Thanks,
