16f1847 with ds1307 help
kurusaray_18
PostPosted: Mon Dec 15, 2014 8:03 am     Reply with quote
Hello.
CCS when the 16f1847 with DS1307 and DS1307 employee co driver I need.
I would appreciate if you can help.
PostPosted: Mon Dec 15, 2014 11:32 am     Reply with quote
CCS has a ds1338 driver here, which should also work with the ds1307:
c:\program files\picc\drivers\ds1338.c
PostPosted: Mon Dec 15, 2014 11:35 am     Reply with quote
There is also a DS1307 driver in the code library.
PostPosted: Mon Dec 15, 2014 11:40 am     Reply with quote
The reason I gave him that one is because he has some cryptic comment
about CCS employee, so I thought maybe he only wanted one from CCS.
kurusaray_18
16f1847
PostPosted: Mon Dec 15, 2014 12:25 pm     Reply with quote
I tried. DS1307 in its library. but
I not work with 16f1847.
An example on the use 16f1847 with DS1307 Is there?
PostPosted: Mon Dec 15, 2014 12:49 pm     Reply with quote
Post a description of the connections between the DS1307 and the PIC.
Also post a description of all connections to the DS1307 pins.
PostPosted: Mon Dec 15, 2014 1:04 pm     Reply with quote
I know the driver works for all sorts of PICs !
1) do you have a battery conected to the DS1307 ? Pin 3 I think ...
It MUST be there for it to work.
2) Do you have the correct pullup resistors on the I2C lines? 3K3 or 4K7 will work.
3) Have you run PCM P's 'I2C scanner' program found in the code library here? It will find ANY I2C device....
4) Have you got the '1Hz LED' type program running on your PIC/board? This should be done first to confirm hardware/pgmr/software does work.
Jay
kurusaray_18
16f1847
PostPosted: Mon Dec 15, 2014 1:29 pm     Reply with quote
I understand. I have 3 numbers I pulled to the ground. I was wearing a 10k pullup resistor.
Changing experience them again.
PostPosted: Mon Dec 15, 2014 2:38 pm     Reply with quote
Very Happy
That's a case of him using a translation program. He is using (employing....) a DS1307.
Shows how this sort of program can lead one off in odd directions.....
I used to be quite good at reading 'Chinglish' manuals.
asmallri
PostPosted: Mon Dec 15, 2014 8:13 pm     Reply with quote
Not quite - the battery input on the DS1307 cannot be allowed to float (be unconnected). If there is no battery present (for example when you are testing) then either a pull-up or pull-down resistor can be used and the DS1307 will work correctly.
Regards, Andrew
PostPosted: Tue Dec 16, 2014 5:43 am     Reply with quote
hmm ...
interesting about the battery input to the DS1307! Though without a 'backup battery' on the pin you lose the feature of keeping the RTC alive when PIC power fails,so if you use it without battery, you might as well code a SW RTC into the PIC !
learning something new everyday, remembering 1/2 of it !!
Jay
