Simonk ESC & PWM
Ruby
Simonk ESC & PWM
PostPosted: Fri Nov 14, 2014 10:49 am     Reply with quote
Hi everybody. I need help with pwm. I am using 16f877a. If I am not wrong I need 50hz for esc.
PostPosted: Fri Nov 14, 2014 11:36 am     Reply with quote
Look in the code library for _servo_ code.
ESC's use the same data format as servos (they are driven by radio controls commonly).
Ruby
PostPosted: Fri Nov 14, 2014 11:39 am     Reply with quote
Thanks for reply. What you mean with look in library?
PostPosted: Fri Nov 14, 2014 11:46 am     Reply with quote
Haven't you actually _looked_ at the layout of this forum?.
It has three sections:
'General CCS Discussion'
'Code Library'
'CCS ICD/Mach X/Load-n-go'
The 'code library' contains hundred (thousands?), of sections of code to help. There are at least three examples there, of code to drive various numbers of servos.
Ruby
PostPosted: Fri Nov 14, 2014 11:49 am     Reply with quote
Ok but if I can't find there what I am looking for how can I move the post?
PostPosted: Fri Nov 14, 2014 12:09 pm     Reply with quote
near top of this screen is a button called 'search',click on it and use RS servo or ESC servo', selct 'and' wait a bit...you'll get 300+ hits. It's up to you to scan,read,select which has the code that is applicable.
Presumably ESC means Electronic Speed Control... and yes, refresh rate will be 50Hz UNLESS it's the newer 'digital' RC servos.
hth
jay
Ruby
PostPosted: Fri Nov 14, 2014 12:17 pm     Reply with quote
I bought this
http://m.ebay.com/itm/161432910116
PostPosted: Fri Nov 14, 2014 12:50 pm     Reply with quote
Have you started to write the code you need?
PostPosted: Fri Nov 14, 2014 1:10 pm     Reply with quote
These will accept the 400Hz digital servo signals, (as well as the old 50Hz standard).
Ruby
PostPosted: Fri Nov 14, 2014 1:14 pm     Reply with quote
How do you know? I couldn't find any datasheet of them? 400 better right?
PostPosted: Fri Nov 14, 2014 1:26 pm     Reply with quote
The 'Simonk' in the description, is the firmware in the ESC's. He wrote an improved version to give faster refresh for things like multi-copters, where being able to change the speed more quickly helped give the fine control required.
It'll still accept the slower refresh, if needed.
Whether it is 'better', depends on what you are doing. For things that need very rapidly adjusted speeds, yes, better. However it means that the code feeding it must be very careful to not give incorrect values, since these result in high current spikes, and rough output.
Realistically, you'd get much better response, by switching to one of the more modern PIC's with hardware PWM's that can go to this sort of frequency (some of the motor control ones). Simpler, and easier to update the speeds accurately.
