ercarlitosg
| PIC16F628A no interrupts when serial data received |
Posted: Mon Nov 10, 2014 9:52 am |
Hello to all.
I am new to electronics, I have came from developing software for computers, but now I am developing software for PICS, and I'm a lot of noob this.
I have a 16F628A and also I am using Proteus ISIS to simulate the pic.
I want to interrupt the program when a serial message has been received.
I found the int_rda, so I used it but I don't receive anything in the pic.
Here is my code if you could help me
| Code: | #include <16F628A.h>
#FUSES NOMCLR //Master Clear pin used for I/O
#use delay(internal=4MHz)
#use rs232 (UART1, baud=1200,bits=8,ERRORS)
char lastc = 0;
int recvi = 0;
char recv[16] = "";
#int_RDA
void RDA_isr()
lastc = getc();
puts(lastc);
recvi++;
if (recvi > 16) {
puts(recv);
recv = "";
recv[recvi] = lastc;
lastc = 0;
} else {
lastc = 0;
{ //TODO: User Code
Posted: Mon Nov 10, 2014 10:07 am |
You are not enabling the interrupt......
allows all enabled interrupts to work.
enable_interrupt(INT_RDA);
enables the receive interrupt.
You need both lines.
However there is a severe problem with the code in the interrupt.
A received character, is _not_ a string....
To send it you need to use putc, which sends a character.
But then there is the second problem. recv, can accept indexes from 0 to 15. At 16, you will have overwritten the next variable in memory....
Then there is the issue of time. It takes as long to send a character as it may take for one to arrive. When the counter gets to 16 (wrong), it'll try to send seventeen characters, and anything else in memory beyond this point that is not zero (a string _requires_ a 0 terminator) meanwhile anything arriving will be lost.
Then you try to 'clear' a character buffer by writing directly to the pointer. This is not how C works, strcpy is needed to do this.
The routine is fundamentally flawed. Move the print of anything but the character received, into the main code, not the interrupt. |
ercarlitosg
Posted: Mon Nov 10, 2014 12:21 pm |
| Ttelmah wrote: | You are not enabling the interrupt......
Sorry, I have said I'm very noob to C and I make some mistakes because of Java . I wil fix it soon and tell you how it's working.
Thank you a lot |
