Reading string via RS232 into PIC
aerodactyl
PostPosted: Tue Oct 21, 2014 10:40 am     Reply with quote
Hello world,
I have problem in understanding some things around the RS232.
In the past I read only single characters via RS232 into the PIC and sent out some strings without any problem.
for reading the characters I used
if (kbhit())
ASCII = getc();
Sending was done by "printf() function. All good so far.
Now I want to receive data via the RS232. Therefore the transmitter sends numbers e.g. "123" as a string to the PIC.
During debugging I saw that the kbhit() will read each single character, but only the first two. Third character got lost somewhere.
I saw in the compiler book that the RS232 can also handle a parameter called STREAM.
After studying half of the internet I gave up because I couldn't find any useful explanation for me.
The nomenclature seems to be
 #USE RS232 (....,...,....,STREAM = x)
and
reading the buffer
if (kbhit(x))
Please can somebody explain this a little bit?
My idea is to send the data to the PIC as 123$. When receiving the $ I know the data is complete and I can send the string (without $) into ATOI ()or ATOL() function to convert it into a int or long variable.
So my questions are:
_ is the STREAM parameter necessary for reading more tha a character via RS232?
_ does the kbhit(x) function looks only for strings then?
_ what happens if I want still receive also single characters for controlling some functions inside the PIC?
PIC: 16F1829
CCS:PCM Version 5.0.0.448
MPLAP 8.92 IDE
Test environment: HTerm Terminal program
Hope somebody can help me in this matter.
Best regards
Uwe
PostPosted: Tue Oct 21, 2014 12:27 pm     Reply with quote
No.
No. It tells you that the UART has received a character, and is ready
for you to read it with getc().
You can always do this.
Look at the CCS example file, ex_Sisr.c, in this directory:
c:\program files\picc\examples\ex_sisr.c
aerodactyl
PostPosted: Tue Oct 21, 2014 2:43 pm     Reply with quote
Got it work now Very Happy
My problem was the overrun error!
It seems it occurs because the terminal program send the character without any delay and the 2 character FIFO buffer overflows as the main loop is slower.
In reality this can not happen since the PC will send data with a minimum gap of 10 ms.
Still my question:
_ What is the meaning of this STREAM parameter for the RS232?
Best regards
Uwe
PostPosted: Tue Oct 21, 2014 3:14 pm     Reply with quote
"Streams" are just names for UARTs. If your PIC has two UART modules,
how do you tell the difference between them when you are writing code ?
You give each uart a different stream name, and then use that name as
a parameter when you call fgetc, fputc, or fprintf, etc.
aerodactyl
PostPosted: Tue Oct 21, 2014 3:26 pm     Reply with quote
Cool Cool
Easy to understand and logical. Thanks
PostPosted: Wed Oct 22, 2014 12:23 am     Reply with quote
and on the main loop being slower than characters are arriving, look at ex_sisr.c
This shows how to use the hardware interrupt, to put the received characters into a buffer.
Then instead of using kbhit you use 'bkbkit' to test for data being in the buffer, and bgetc to get the characters. This buffer (with the supplied code), should be a 'binary' size (8, 16 etc. characters), but then means that provided your main loop services 'at times' fast enough, to keep ahead of the characters arriving, you have several characters extra time to cope.
It can very easily be modified to handle streams, and I have in the past posted code that allows non binary sizes, and multiple buffers for several UARTs to be 'in use' at once if needed. However if only one of the serial streams is likely to be giving this problem, just buffer this one, with the supplied code.
PostPosted: Thu Oct 23, 2014 11:33 am     Reply with quote
a more common convention is to use ASC(13),
the carriage return instead of '$'
this has the benefit of being very displayable too,
which it will not be when using $.
aerodactyl
PostPosted: Thu Oct 23, 2014 3:08 pm     Reply with quote
Thanks to all Very Happy
Your input helped alot.
Best regards from Germany
Uwe
