ELCouz
[SOLVED] Input loop? |
Posted: Sun Oct 19, 2014 2:10 pm |
Dear CCS fanatics
Take a look at this code...
This is in the main loop
if (waitforbuttoninput)
if (!input(PIN_C2))
putc('.');
waitforbuttoninput=0;
Why when I set the waitforbuttoninput to true it read correctly and putchar . character over serial BUT never stop listening for input??
If I keep pressing the switch I still get dot characters but it should not since I've set the flag to 0...
Any idea??
Would a break statement inserted after waitforbuttoninput=0; help?
I know this is for exiting a while,switch and for loop...
EDIT (For clarifying):
Code to enable reading of the switch which works great (to receive from serial)
case 'Y' : waitforbuttoninput = 1; // read start button and flash
case 'y' : waitforbuttoninput = 0;
Using pcwhd 5.027 on a PIC18F4685 _________________ Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy!
Mike Walne
Posted: Sun Oct 19, 2014 3:00 pm |
Post SHORT but complete, compilable code which shows us exactly what your problem is.
(Save us from having to second guess.)
Mike |
ELCouz
Posted: Sun Oct 19, 2014 3:06 pm |
I don't know what more you can see but here it is...
Code: | #include <18F4685.h>
#FUSES HS,NOMCLR,NOLVP,NOPBADEN,BROWNOUT,BORV46,PUT
#use delay(clock=12M)
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7,errors)
int8 dummy;
int1 waitforbuttoninput;
#int_rda
void serial_isr()
dummy=getc();
enable_interrupts(INT_RDA);
switch (dummy)
if (!input(PIN_C2))
putc('.');
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy! |
ELCouz
Posted: Sun Oct 19, 2014 4:22 pm |
if ((!input(PIN_C2))&&(waitforbuttoninput))
putc('.');
Even this doesn't work the int1 waitforbuttoninput isn't set to 0 or the IF statement ignore the 0 value...
Shouldn't the pic check if waitforbuttoninput is set to 1 before reading the input? _________________ Regards,
Laurent
Posted: Sun Oct 19, 2014 5:01 pm |
Quote: | Shouldn't the pic check if waitforbuttoninput is set to 1 before reading the input? |
You press a key and 'dummy' gets set to 'Y'. Once it's set, it stays that
way forever (unless you press a different key). You never clear 'dummy'.
You crank through your while() loop, it sees the 'Y', it sets
'waitforbuttoninput' to 1. It's because you never clear 'dummy'. |
ELCouz
Posted: Sun Oct 19, 2014 5:28 pm |
PCM programmer wrote: | Quote: | Shouldn't the pic check if waitforbuttoninput is set to 1 before reading the input? |
You are right!
I've modified my working code too fast. Clearly skipped that...
case 'x' :output_low(pin_a0);
dummy = 0;
case '?' :printf("$!*"); //keep alive
savedcount = count;
dummy = 0;
case '@' :printf("$%s*",version); // version info
dummy = 0;
You could see its been there before but managed to forget to add this...
Thanks for pointing me out PCM Programmer! _________________ Regards,
Laurent
Posted: Mon Oct 20, 2014 12:40 am |
You can also see 'why' PCM_programmer asked for complete code. The problem was actually 'outside' the bit you were looking at....  |
