Krazzy7434
20x4 lcd not working.. |
Posted: Thu Oct 16, 2014 2:03 am |
Hello guys...
I was trying to interface a 20x4 lcd display with a pic18f4550....But it showing only dark square, not on the first line but here and there and disappears within 3 seconds...
Here is my code:
#include <18f4550.h>
#device ADC=10
#fuses HS, PLL5, CPUDIV1, NOWDT, NOPROTECT, BROWNOUT, NOLVP, PUT, NOMCLR
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,parity=N,bits=8,ERRORS)
#include<flex_lcd420.c>
float32 T , val;
lcd_init();
lcd_setcursor_vb(1,1);
printf(lcd_putc,"\f ");
setup_adc_ports(AN0_TO_AN1);
setup_adc(ADC_CLOCK_DIV_8);
for(;;)
set_adc_channel(0);
delay_ms(10);
T=read_adc();
val=T*(4.26/1023)*100;
delay_ms(600);
lcd_gotoxy(1,1);
delay_ms(10);
printf(lcd_putc,"Tem Read:%3.1f ",val);
delay_ms(10);
output_toggle(PIN_D1);
delay_ms(10);
output_toggle(PIN_E1);
delay_ms(10);
but when i replaced the circuit with 16x2 lcd its working perfectly...
It's not working for 20x4 lcd.....is my 20x4 lcd defective???
I'm using a 10 k pot for my lcd..
Plz help..
Thank You.... _________________ Krazzy7434 |
Posted: Thu Oct 16, 2014 5:02 am |
It'd help if you gave a part number for the 20*4, in case there is something 'odd' about this unit.
Bit puzzled at you toggling E1, when the default connections have this as the R/W pin for the LCD. |
Krazzy7434
Posted: Thu Oct 16, 2014 5:33 am |
Ttelmah wrote: | It'd help if you gave a part number for the 20*4, in case there is something 'odd' about this unit.
Hello Ttelmah..
I'm having a ODM 20416 1SLW lcd display....are you saying that i should toggle the EN pin and R/w pin....
plz help me
Thank You... _________________ Krazzy7434 |
Joined: 01 Jul 2010 Posts: 9500 Location: Greensville,Ontario
Posted: Thu Oct 16, 2014 7:33 am |
simple logic101...
Since a 2x16 works OK with your code and PIC then the 4x20 LCD must be defective.
I checked the datasheet for the display and it has the same pinout/connections aside from the LED backlighting (which will NOT affect displaying data).
I also am puzzled about the toggling LED code but I've assumed you modified the LCD driver as you did say a 2x16 LCD works fine.
You may want to post the LCD driver code....
hth
jay |
Posted: Thu Oct 16, 2014 7:34 am |
No, You should not be toggling the pin at all. The driver controls all the LCD pins, you don't want to touch them in your own code.
I must admit, I wouldn't touch any product that does not have a full data sheet available. There is no specification for what voltage is required on Vl (while many modern displays will show a picture OK with 0v, the circuits for this display all show a contrast voltage being input). There is also nothing actually saying that this is a 'standard' Hitachi compatible LCD.
Save yourself a lot of bother and get an LCD with better documentation. |
Krazzy7434
Posted: Thu Oct 16, 2014 8:39 am |
Ttelmah wrote: | No, You should not be toggling the pin at all. The driver controls all the LCD pins, you don't want to touch them in your own code.
hi Ttelmah...
i googled for its datasheet...but didnt find any with good details...
Is there any possibility for its working if my lcd is a HD44780 type...
also there is a label " E187451 94V-0 "...
I Hope it may be helpful...
THANK YOU... _________________ Krazzy7434 |
Posted: Thu Oct 16, 2014 12:50 pm |
Quote: | there is a label " E187451 94V-0 "... |
Those are manufacturing marks. They are not important to your problem.
and disappears within 3 seconds |
If the lcd doesn't initialize correctly, you will get black squares.
But the fact that they disappear shows some other problem. It could the
power supply for your board is bad, or the power and ground connections
to the lcd are intermittent. Or the contrast circuit.
I would check for a stable +5v power supply, and carefully check that
all connections between the PIC and the LCD are solid, good connections. |
Krazzy7434
Posted: Fri Oct 17, 2014 12:40 am |
Hi PCM programmer
I double checked every thing....i also tested the same ciruit with a 16X2 lcd display and it working...but not working with my 20x4 lcd.
can i confirm its defective..???
Posted: Fri Oct 17, 2014 12:52 am |
The first thing to try is a pot on the contrast pin.
Most modern text LCD's will display an image with this grounded. However as I already commented, the notes from this manufacturer show this having a small positive voltage applied (common on older LCD technologies). When the display first switches on, the chip is running at the wrong clock rate, and this will commonly show a block on the display, even if the contrast voltage is wrong, but once the chip is programmed, this will disappear, and if the voltage is outside the range that this LCD will display an image, then the display would go clear, with nothing visible, even if the display was in fact working perfectly. |
Krazzy7434
Posted: Fri Oct 17, 2014 11:12 am |
Ttelmah wrote: | The first thing to try is a pot on the contrast pin.
hi Ttelmah..
I have connected contrast pin to a 10k pot and i have also tried without using the data lines and controls...when the contrast pin is given a voltage of 3.87 the display is clear....when 0v is give 8 blacks square appears in the first line and second line.. when 5v is given dark square appears in the remaining boxes....
no image is seen at any time...
still any Hope....???
Posted: Fri Oct 17, 2014 11:49 am |
Black squares means the LCD is not initialized. The standard reason is
because the list of #define statements for the pins (at the start of the
flex driver file) does not match the actual wired connections to the LCD.
The #define statements below must be edited to exactly match the
wired connections between your PIC and the LCD.
Code: | // Flex_LCD420.c
// These pins are for my Microchip PicDem2-Plus board,
// which I used to test this driver.
// An external 20x4 LCD is connected to these pins.
// Change these pins to match your own board's connections.
#define LCD_DB4 PIN_D4
#define LCD_DB5 PIN_D5
#define LCD_DB6 PIN_D6
#define LCD_DB7 PIN_D7
#define LCD_RS PIN_E0
#define LCD_RW PIN_E1
#define LCD_E PIN_E2 |
On your LCD, the LCD_DB4 to LCD_DB7 data pins are on pins 11 to 14.
http://www.orioleindia.com/LCD%20MANUAL/20x4.pdf
Post your list of #define statements so we can see it. |
Krazzy7434
Posted: Fri Oct 17, 2014 1:34 pm |
Hello PCM programmer..
Actually black squares dont have any order,,,they just appear here and there....
Also i didnt understand your previous post...You mean,, i have to edit the driver....If so, why?? I have connected
Pin11(DB4)--------->PIN_D4
Pin12(DB5)--------->PIN_D5
Pin13(DB6)--------->PIN_D6
Pin14(DB7)--------->PIN_D7
Pin4(RS)------------>PIN_E0
Pin5(RW)------------>GND
Pin6(EN)------------>PIN_E2
Also dark square are not stable...they disappears slowly....
Plz make me corrected if i m wrong....
Thank You...... _________________ Krazzy7434 |
Posted: Fri Oct 17, 2014 1:56 pm |
You have R/W connected to ground. That means the following paragraph
in the driver file applies to you:
// If you want only a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line. Doing so will save one PIC
// pin, but at the cost of losing the ability to read from
// the LCD. It also makes the write time a little longer
// because a static delay must be used, instead of polling
// the LCD's busy bit. Normally a 6-pin interface is only
// used if you are running out of PIC pins, and you need
// to use as few as possible for the LCD.
#define USE_RW_PIN 1 |
You need to edit the driver file and comment out the following
line, as shown below. Put comment marks // in front of the line:
Quote: |
// #define USE_RW_PIN 1 |
Then re-compile and test. |
Krazzy7434
Posted: Fri Oct 17, 2014 2:08 pm |
Hello PCM Programmer...
I commented that line when i connected RW pin To GND...I think you have been refering with my old lcd driver from my previous threads...i have edited it when i thought connecting RW to ground is better ...
if u think my lcd is damaged ,,could u plz suggest me a good and a cheap 20X4 lcd display....
Posted: Fri Oct 17, 2014 3:36 pm |
I'm in the USA, so I would buy from crystalfontz.com or sparkfun.com
or digikey.com or mouser.com. If you're in a different country I don't
know where you would buy an lcd. |
