		| Author | Message |
		| VernonAMiller
				| Enhanced list file format? |
				|  Posted: Mon Oct 06, 2014 4:50 am |   |
				| Hello all:
 In the .LST output file, there are four different options for list format, but none of them seems to give the entire opcode (two-word instructions like MOVFF on the PIC18 are missing the second word), plus meaningful symbolic names.
 For example, here are some sample listing lines from another compiler:
  	  | Code: |  	  | 0x0270   0xF002C004     MOVFF       R4, R2
 0x0274   0xF003C005     MOVFF       R5, R3
 0x0278   0x4A04         INFSNZ      R4, 1
 0x027A   0x2A05         INCF        R5, 1
 This gives the hex address, hex opcode (both words for two-word instructions), assembler mnemonic, and a useful reference name (in this case these are GPRs).  This is a pretty standard type of machine-code listing in most compilers I have used.
 With CCS C, I have not found a way to get this level of detail.  The "Symbolic" and "With opcodes" settings each give me some of what I'm looking for, but I guess what I want is a blend of both.
 Is there a way to get this?
 Thanks!
 VAM
		| asmboy
				|  Posted: Mon Oct 06, 2014 7:54 am |   |
				| command line options -- quoting here:
 +LNxxx  //<< this is the no opt default
 Normal list file
 +LSxxx
 MPASM format list file
 +LOxxx
 Old MPASM list file
 +LYxxx
 Symbolic list file
 if none of these produce what you want - then you are out of options.
		| VernonAMiller
				|  Posted: Mon Oct 06, 2014 8:13 am |   |
				|  	  | asmboy wrote: |  	  | if none of these produce what you want - then you are out of options. |
 Thanks.  I guess I'm out of options then
  I'll submit an enhancement request.
 VAM
		| Ttelmah
				|  Posted: Mon Oct 06, 2014 9:08 am |   |
				| What compiler version????
 The full opcode is output on the current versions, so 'puzzled' about your lacking the second byte. It doesn't show it as a separate NOP though.
  	  | Code: |  	  | 0023A C002 F00F      08060 MOVFF  02,0F
 0023E C001 F00E      08061 MOVFF  01,0E
 00242 C002 F018      08062 MOVFF  02,18
 00246 C001 F017      08063 MOVFF  01,17
 If I want a part in full MPASM format, I just import it into MPLAB, and look at it's program memory, disassembly window. Right click, select 'export to file'.
  	  | Code: |  	  | 286   023A    C002          MOVFF 0x2, 0xf
 287   023C    F00F          NOP
 288   023E    C001          MOVFF 0x1, 0xe
 289   0240    F00E          NOP
 290   0242    C002          MOVFF 0x2, 0x18
 291   0244    F018          NOP
 292   0246    C001          MOVFF 0x1, 0x17
 293   0248    F017          NOP
 That also knows symbolic names for registers etc..
		| VernonAMiller
				|  Posted: Mon Oct 06, 2014 9:26 am |   |
				|  	  | Ttelmah wrote: |  	  | What compiler version????
 I'm using  5.025d (eval version).  And, yes, I can get the full two-word output (like you show) if I select "With opcodes" - but then I lose the symbolic info.
 I was hoping there was a hidden setting or other way to get both the full two-word output for two-word instructions, plus symbols.
 It's not a deal-breaker but it does make the output less convenient to use for debugging.
 Thanks,
 VAM
 PS.  Would you consider this to be a bug in the "Symbolic" setting?  (Like "Symbolic LST file option causes incorrect display of two-word instructions"?  Or is it really an enhancement request?
 | You cannot post new topics in this forum You cannot reply to topics in this forum
