mkuang
Posted: Tue Feb 05, 2008 3:51 pm |
| ELCouz wrote: | | Built-in. The SPLC780A1 is compatible with the factory standard HD44780 controller |
Thank you. I was looking at the datasheet for the controller and it doesn't make any sense if it is not built in...then you have 100+ pins to solder. |
maxrate
Joined: 01 Jan 2007 Posts: 43 Location: Mississauga, Ontario, Canada
| Flexible driver |
Posted: Mon Oct 13, 2008 4:26 pm |
| This code worked first try with my CrystalFontz display. Thank you to who ever modified the original CCS code, saved me a lot of time. |
Bill Legge
Joined: 07 Sep 2010 Posts: 24 Location: West Australia
| Flex420 |
Posted: Sat Sep 18, 2010 12:04 am |
Thanks for your work. I started on CCS C a few days ago and got your driver working first time.
May help someone else to know that my target was:
ETT/Futurlec ET-BASE PIC8722 board
With a 4X20 LCD connected in 'standard' ETT format to the PORTH socket
All works very well. Just watch where you store the downloaded driver so that the main.c program can find it.
If you have not had a look at the Futurlec boards - do so. They are good value for money and arrive in about 10 days. Documentation is poor but understandable.
Regards Bill Legge
In Australia _________________ Denmark in West Australia
'Where the forest meets the sea' |
sayse
Posted: Mon Sep 20, 2010 11:59 pm |
| wired57 wrote: | I was unable to make your driver function aswell, until I modified these Two functions, so that they followed the need to hold the R line high for 220uS min and then Low for another 220uS min, with a toltal cycle time of 500uS min. for both reading and writing. this is for a 4x20 based on a Samsung KS0066 Controler. let me know if this helps others too.
Thankyou, it was so helpful to me, I used 100us instead 220 but it didn´t work with the original values.
Another change I made is cancel this instruction in lcd_send_byte
// while(bit_test(lcd_read_byte(),7)) ;
Because the software hang on there since I don´t use the RW_PIN, I know the driver has this #IF statements but it hangs on anyway. Now it´s working properly. |
seifpic
| 7 Data Pins |
Posted: Tue Jun 05, 2012 10:15 am |
I really like this driver as it saves time and frustration over the default one, I have not received the LCD in the mail yet however I know that it has 7 data pins, rs, rw, and E pins, and in this driver there are only defines for DB4 - DB7, are the other DB pins unneeded? Thanks in advance (LMB204BDC is my LCD by the way).
EDIT: nevermind, it's in 4 bit mode right? In the mean time, has anyone tried this driver with the LMB204BDC?
http://www.topwaydisplay.com/Pub/Manual/LMB204BDC-Manual-Rev0.1.pdf |
Abyss
Posted: Thu Mar 20, 2014 6:49 am |
| Neckruin wrote: | Forget it... it works perfectly!
Thanks again PCM.
PD: Just for laughing... the problem was the contrast...  |
Dear Sir,
I hereby give you as many thanks as possible!!!!
I spent quite some hours trying to solve this, and I was afraid I needed to check the timings on my xlcd.c code...it was the contrast after all! Just a variable resistor and "Hello world"!!!!!
Really, thank you from the bottom of my heart!!  |
Gabriel
Posted: Thu Sep 25, 2014 8:26 pm |
Not that it needs saying, but this works perfectly!
Winstar 20*4
Thanks PCM!
G. _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Gabriel
Posted: Fri Oct 03, 2014 12:19 pm |
After some more fiddling with this driver i noticed that '\r' is not a valid command.
how do i write over the same line? like a constantly updating temp value?
do i have to use the lcd_gotoxy or is there a direct way from the lcd_putc function?
basically do this : Printf("Value: %u \r", Temp);
Posted: Fri Oct 03, 2014 1:36 pm |
Do you have a recent version of the CCS compiler ? CCS added a feature
to their lcd.c file called "LCD_EXTENDED_NEWLINE". If that is defined
they create two global variables for lcd_x and lcd_y. Then in the rest of
the driver, they update those to keep track of the current cursor position.
Then in the lcd_putc() routine, they add a case for \r:
| Code: | | case '\r' : lcd_gotoxy(1, g_LcdY+1); break; |
Basically, they're keeping track of what Y line you're on, so when you
send \r, the driver knows what Y coordinate to put into lcd_gotoxy().
You could add that feature to the 20x4 driver. Or if you don't have a
recent version to refer to, I could add the mods. |
Gabriel
Posted: Fri Oct 03, 2014 2:48 pm |
hi, Thanks for the explanation.
I have 4.135 for PCM and 5.012 for PCH...
The drivers i have do have the Extended Newline, but only for the 16x2.
I can try to mod the code but I dont think anybody should hold their breaths...
Lets see how i do tonight.
Thanks.
Gabriel
Posted: Fri Oct 03, 2014 3:10 pm |
Looking at the code:
| Code: | void lcd_putc(char c)
switch(c)
case '\f':
lcd_send_byte(0,1);
lcd_line = 1;
delay_ms(2);
case '\n':
lcd_gotoxy(1, ++lcd_line);
case '\b':
lcd_send_byte(0,0x10);
default:
lcd_send_byte(1,c);
case '\n': goes to the 1 position of the next "lcd_line"
Why not just add a case like this:
| Code: | case '\r':
lcd_gotoxy(1, lcd_line);
Basically going to the first position of the very same line?
I dont see "lcd_line" being updated anywhere else...so if called during a print it should hold the value of the line after the last '\n'
I'm probably missing something.... i dont think ccs and you missed that short cut... _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Posted: Fri Oct 03, 2014 4:24 pm |
I don't see lcd_line updated in the lcd_gotoxy() routine.
In order to do this, I will have get out a board, connect up the 20x4 lcd
and test it all out. I was sort of hoping I could avoid that. I am tired today. |
Gabriel
Posted: Fri Oct 03, 2014 7:52 pm |
.... kick back, im taking this one on myself in about 10 mins.
EDIT: So far.. its working!
Im going to sort some other things out and post back the finished code! _________________ CCS PCM 5.078 & CCS PCH 5.093 |
Gabriel
| Rejoice with '\r' |
Posted: Fri Oct 03, 2014 8:25 pm |
Hi All, This is the modified function as per the discussion above:
Seems to work just fine and now we can all rewrite lines at will with '\r'.
Ive included the line wrap from user "ratgod" as well, i thought it was practical too.
switch(c)
case '\f':
lcd_send_byte(0,1);
lcd_line = 1;
delay_ms(2);
case '\n':
case '\b':
case '\r':
default:
lcd_send_byte(1,c);
if (lcd_line>4)
lcd_line=1;
Gabriel
Posted: Tue Apr 14, 2015 11:32 pm |
Hi, Can you confirm that this driver using a 6 pin configuration (NO RW), will work with a 3.3V Pic and a 5V LCD?
I dont see any reason it should not, but id like to know if some one else has done this.
G _________________ CCS PCM 5.078 & CCS PCH 5.093 |
