musti463
Posted: Wed Aug 27, 2014 5:52 am |
I have new question. Why we will coupling DE and RE pins. If we tie this pins,so why manufacturers produces this pins? _________________ M.Emir SADE |
Joined: 01 Jul 2010 Posts: 9134 Location: Greensville,Ontario
Posted: Wed Aug 27, 2014 6:49 am |
By having individual control of both transmitter and receiver sections of the device,a designer can optimize his code that controls the RS-485 databus.
Similar to why cars have both gas and brake pedals. Technically NOT required but the driver has more 'options' on how to control the car.
hth
jay |
Posted: Wed Aug 27, 2014 1:57 pm |
If you connect RE and DE together, the transceiver chip is either sending
or receiving (half duplex) and it only takes 1 pin on your PIC to control
the send/receive mode.
If RE and DE are separately controlled by two pins on your PIC, you
could enable both at the same time, and then transmit a byte and
receive it back in your PIC, to test if the circuit is working OK.
Also, if you don't receive the same message that you sent, it could mean
that another device is trying to send at the same time. (This is called
a collision). So you could abort sending for a short time, and then try again. |
musti463
Posted: Fri Sep 05, 2014 7:11 am |
Hello again me, again problem
I am sending data from master to slave. So sometimes slave get message instantly. But sometimes delay and get message.
What is the reason for this delay and instability? _________________ M.Emir SADE |
ezflyr
Posted: Fri Sep 05, 2014 7:27 am |
Do you have any real hardware, or is this just a pure simulation? If it's a Proteus simulation, we don't want to waste anymore time on it. If it's real hardware, please post a picture of the hardware, and show us your latest code.
John |
musti463
Posted: Fri Sep 05, 2014 9:24 am |
I record video about my problem:
http://youtu.be/g6cMNWmP760
And so i cant understand, my circuit work correctly this video:
http://youtu.be/x7cwHIuxYow
Master Code:
Code: | #INCLUDE <16f877.h>
#FUSES XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#USE delay (clock=4000000)
#USE rs232(baud=250000,xmit=pin_c6,rcv=pin_c7,enable=pin_c5,bits=9,errors,stream=PIC)
#DEFINE use_portb_lcd TRUE
#INCLUDE <lcd.c>
#INCLUDE <input.c>
#INCLUDE <stdlib.h>
#DEFINE RS485_ID 0x07
#DEFINE RS485_DEST_ID 0x03
#INCLUDE <rs485.c>
int data,i;
int *pointer=&data;
void main ( )
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_CCP1(CCP_OFF);
setup_CCP2(CCP_OFF);
set_tris_b(0x00);
set_tris_c(0x80);
set_tris_d(0x00);
output_b(0x00);
output_d(0x00);
output_high(pin_c5);
rs485_init();
delay_ms(50);
delay_ms(50);
printf(lcd_putc,"\f");
i=0;
data=0;
for(i;i<100;i++)
if(rs485_send_message(RS485_DEST_ID,1,&data))
printf(lcd_putc,"\fGonderildi%u",i);
data++;
Slave Code:
#INCLUDE <lcd.c>
#INCLUDE <input.c>
#INCLUDE <stdlib.h>
#DEFINE RS485_ID 0x03
#INCLUDE <rs485.c>
int data[3];
int *pointer=&data[0];
setup_psp(PSP_DISABLED); // PSP birimi devre dışı
setup_spi(SPI_SS_DISABLED); // SPI birimi devre dışı
setup_timer_1(T1_DISABLED); // T1 zamanlayıcısı devre dışı
setup_timer_2(T2_DISABLED,0,1); // T2 zamanlayıcısı devre dışı
setup_adc_ports(NO_ANALOGS); // ANALOG giriş yok
setup_adc(ADC_OFF); // ADC birimi devre dışı
setup_CCP1(CCP_OFF); // CCP1 birimi devre dışı
setup_CCP2(CCP_OFF); // CCP2 birimi devre dışı
set_tris_b(0x00);
set_tris_c(0x80);
output_b(0x00);
output_low(pin_c5);
rs485_init();
delay_ms(50);
delay_ms(50);
printf(lcd_putc,"\fBilgi: ");
while (1)
rs485_get_message(pointer,false);
delay_ms(50);
printf(lcd_putc,"\fBilgi:%u",pointer[2]);
Circuit:
ezflyr
Posted: Fri Sep 05, 2014 10:00 am |
I think your problem description is faulty? It seems that in the 'non-working' example, the Slave is missing some transmissions from the Master, it's not a matter of 'delay'.....
What is the difference between your working code, and your non-working code?
BTW, your hardware looks good! Congratulations on taking this project into the 'real world'!!
John |
musti463
Posted: Fri Sep 05, 2014 10:03 am |
ezflyr wrote: | Hi,
John |
@ezflyr same codes. There is one code (sometimes working sometimes non-working code)
I couldn't understand _________________ M.Emir SADE |
SherpaDoug
Posted: Fri Sep 05, 2014 10:30 am |
Is it an actual delay or is the problem that most messages are being lost? It looks to me like when a new message is received it is only one number behind what is sent. _________________ The search for better is endless. Instead simply find very good and get the job done. |
musti463
Posted: Sat Sep 06, 2014 1:46 am |
I am still have this problem ! _________________ M.Emir SADE |
musti463
Posted: Mon Sep 08, 2014 7:13 am |
I did this code for RS485 wishing and sender protocol. Can you tell me your ideas?
Wisher:
Code: | char gelen_bilgiX[9]={};
char *gelen_bilgi=&gelen_bilgiX[0];
int emir=1;
for(int i=0;i<=5;i++)
if(rs485_send_message(RS485_ID_1,1,&emir))
output_low(pin_c5);
rs485_get_message(gelen_bilgi,false);
Sender:
Code: | char giden_bilgiX[9]={};
char *giden_bilgi=&giden_bilgiX[0];
int komut_s[1]={0};
int *komut=&komut_s[0];
float voltaj;
output_low(pin_c5);
while(true)
if(komut==0)
rs485_get_message(komut,false);
else if(komut==1)
set_adc_channel(0);
delay_us(20);
bilgi=read_adc();
voltaj=0.0048828125*bilgi;
sprintf(giden_bilgiX,"%f",voltaj);//float to string işlemi gerçekleştiriliyor
rs485_send_message(RS485_MASTER_ID,8,giden_bilgi);
ezflyr
Posted: Mon Sep 08, 2014 9:21 am |
Creating two threads for basically the same project/problem is very confusing. I though your problems were solved in the other thread? Do you have a new problem? If so, please explain what that problem is. We should not have to guess!!
without trying to analyze your code, one thing that you are doing stands out as very wrong. You should not be directly manipulating 'Pin_C5'. This is the 'enable' pin for your RS485 transceivers, and will be controlled automatically by the compiler as long as you are using the 'Enable' directive in your #use_rs232 declaration.
John |
