JerryR
| Int osc with PLL X4 on PIC18F2520 |
Posted: Fri Sep 05, 2014 8:16 am |
I have not been able to enable the PLL (OSCTUNE bit 6) using a variety of methods on a PIC18F2520. I would like the clock output to be 32MHz. How would one set flags appropriately to accomplish this. My current flag configuration is below without anything to enable the PLL. Please fill in the blank:
#include <18F2520.h>
#device ADC=10
#FUSES INTRC //Internal RC Osc, with CLKOUT
#FUSES NOBROWNOUT
#FUSES NOLVP
#use delay(clock=8000000)
It's probably a stupid mistake on my part . Thanks for the group's indulgence. I'm using compiler version 5.021 inside MPLAB 8.90. |
Joined: 01 Jul 2010 Posts: 9630 Location: Greensville,Ontario
Posted: Fri Sep 05, 2014 8:26 am |
this....
says use an 8 MHz clock...
you want a 32 MHz clock so....
#use delay(clock=32000000)
would be a good starting point...
although
I always printout the page in the datasheet that has the 'flow' of clock signals, highlight what I want, decide which configuration is best, then let the compiler decide. After that test using the '1Hz LED' program, dump the listing to see what the fuses are and go from there.
hth
jay |
JerryR
Posted: Fri Sep 05, 2014 10:02 am |
You know... it worked! I know I tried that before when it seemed to be the simplest way to configure the osc, but didn't notice somehow that osctune.6 was set. Now it sets the internal osc to 111 (8MHz) and enables the PLL (OSCTUNE.6=1).
Thanks a bunch!  |
