reusing #use (spi and i2c) - help!
evan
PostPosted: Fri Aug 29, 2014 11:22 am     Reply with quote
Hi all,
I've got a tricky problem. My hardware is constrained by lack of pins, so I combined i2c and spi peripheral devices, sharing clock and data lines (using the software driver libraries).
Electrically it works fine and I am able to configure the i2c devices first, then the #use SPI call, then the SPI device is accessed. All OK.
However, now I need my program to access one of the i2c devices occasionally, after the #spi call.
But apparently the #use i2c call can't be done more than once. I get
Option invalid   Bad Option: 116
How can I get the libraries to share? I realise this is a little non-standard but I know the library code is there and it does work perfectly.
Is the only way to code my own SPI routine? That would be a pain!
Evan
PostPosted: Fri Aug 29, 2014 1:14 pm     Reply with quote
Key to understand, is that #use, is a preprocessor directive, not code.
Setup the two #use statements, with different stream names, and use these with the i2c/spi functions.
However I'm very surprised you can mix the buses. Given that I2C, is an 'open collector' bus, while SPI requires hardware pull up/down.
Tell the two statements to both force software mode, and then manually float/drive the pins involved, before switching.
PostPosted: Fri Aug 29, 2014 7:13 pm     Reply with quote
This thread has many links on i2c and spi on the same pins:
http://www.ccsinfo.com/forum/viewtopic.php?t=41578
