championx
PIC24E and write_program_memory |
Posted: Fri Aug 29, 2014 12:46 pm |
Hi, im trying to use the function write_program_memory in a 24EP512GP806. But it seems that it doesnt make anything.
I have used this function on other pic16 and pic18, but never on this one.
Code: | for(address_erase=0;address_erase<0x557ff;address_erase+=(getenv("FLASH_ERASE_SIZE")/2))
write_program_memory(address_erase, data, 16);
This should "destroy" the pic program... but it doesnt do anything... the pic keeps running normally.
Is there anything that im missing? |
Posted: Fri Aug 29, 2014 1:07 pm |
Obvious first thing, fuses?.
Second compiler version?.
Then the memory organisation is very different. Each word, is programmed as 32bits, but only holds 24bits. So you have three bytes holding data, then missing byte, then the next three etc..
The page is 1024bytes long, holding 768 bytes of useable data. |
Posted: Fri Aug 29, 2014 7:44 pm |
The OP said in a PM that he solved the problem by upgrading from
compiler vs. 5.008 to 5.026. |
Posted: Fri Aug 29, 2014 11:43 pm |
As I said, 'compiler version'?.
5.008, is very much a 'beta' version, so not surprised.... |
asmallri
Joined: 12 Aug 2004 Posts: 1646 Location: Perth, Australia
Posted: Fri Aug 29, 2014 11:49 pm |
Ttelmah wrote: | Obvious first thing, fuses?.
The "...("FLASH_ERASE_SIZE")/2" does not look right at all for this class of PIC. _________________ Regards, Andrew
Posted: Sat Aug 30, 2014 12:35 am |
Agreed, but it would still give the 'crash' expected from this code.... |
