gfbankston
| PC reports usb malfunction |
Posted: Fri Aug 29, 2014 11:12 am |
Installed usb using the project wizard, full speed on an 45K50.
called usb_init_cs() before main, and calling usb_task() in the main loop.
Question: there is a NOTE about defining USB_CON_SENSE_PIN in my application. I am not sure what this is all about...is it another input pin I tie to the VUSB from the usb port?
Do I have to have it?
PC reports device malfunction when I plug in the cable , but does not elaborate...
TIA
Glen K4KV |
Posted: Fri Aug 29, 2014 4:07 pm |
This is the connection sense diagram that used to be in
ex_usb_bootloader.c in vs. 4.xxx, but CCS took it out in vs. 5.xxx
// If you are using a USB connection sense pin, define it here. If you are
// not using connection sense, comment out this line. Without connection
// sense you will not know if the device gets disconnected.
// (connection sense should look like this:
// 100k
// VBUS-----+----/\/\/\/\/\----- (I/O PIN ON PIC)
// +----/\/\/\/\/\-----GND
// 100k
// (where VBUS is pin1 of the USB connector)
///only ccs's 18F4550 development kit has this pin
#if __USB_PIC_PERIF__ && defined(__PCH__)
#define USB_CON_SENSE_PIN PIN_B2
#endif |
When you are trouble-shooting the USB connection between the 18F4550
and your PC, you can call usb_debug_task() in your while() loop.
It will display debug messages through the MAX232 connection (not USB)
to a terminal window (TeraTerm) on your PC. It will tell you if the PIC
is connected and enumerated, or not.
These CCS example files show how to use usb_debug_task():
| Quote: | c:\program files\picc\examples\ex_usb_hid_and_cdc.c
c:\program files\picc\examples\ex_usb_serial2.c
And several other CCS example files show the same thing. |
