		| Author | Message |
		| Kreg
				| Rotate LED |
				|  Posted: Wed Aug 27, 2014 2:55 am |   |
				| Hi all !
 I would like to ask a question.
 Actually, I have just bought a PICKIT3 with a 18F45K20
 I would like to 'flash and rotate' LED.
 Can you help me ? I am a beginner.
 All my LEDs are connected to the port D (there is 7 LED)
 I would like to introduce an array of the form
 const int LED_LookupTable[8]={0,1,2,3,4,5,6,7};
 Then, sending the led_data in sequence to portD will light each each LED in turn.
 Here is my code but it doesn't work :
  	  | Code: |  	  | /**  I  N  C  L  U  D  E  S  **************************************************/ #include  <18F45K20.h>
 #FUSES INTRC_IO,NOWDT,NOLVP
 #USE delay (CLOCK=1MHz)
 #WORD LATD=0xF8C
 #WORD PORTD=0xF83
 #BIT led=LATD.0
 #BIT led1=LATD.1
 #BIT led2=LATD.2
 #BIT led3=LATD.3
 #BIT led4=LATD.4
 #BIT led5=LATD.5
 #BIT led6=LATD.6
 #BIT led7=LATD.7
 void main(){
 int LED_Number=0;
 SET_TRIS_D(0b00000000);
 led7.LED_LookupTable[LED_Number];
 led7=1;
 LED_Number++;
 if(LED_Number==8){
 LED_Number=0;
 delay_ms(2000);
 And the error about led7=1;
  	  | Quote: |  	  | Expecting a structure/union |
 How can I fix that ?
		| Kreg
				|  Posted: Wed Aug 27, 2014 3:06 am |   |
 #WORD LATD=0xF8C
 #WORD PORTD=0xF83
 #BIT led=LATD.0
 #BIT led1=LATD.1
 #BIT led2=LATD.2
 #BIT led3=LATD.3
 #BIT led4=LATD.4
 #BIT led5=LATD.5
 #BIT led6=LATD.6
 #BIT led7=LATD.7
 void main(){
 LATD=0;
 int LED_Number=0;
 int i=0;
 while(1){
 for(i=0;i<8;i++){
 bit_set(LATD,i);
 i=0;
 LATD=0;
 This code works but I don't use the array unfortunately
		| PCM programmer
				|  Posted: Wed Aug 27, 2014 1:33 pm |   |
				| This code lights up LEDs on PortB, bits 0 to 3.    They are turned on sequentially.   Once turned on, the Leds stay on.   This program
 shows how to read from an array.  I used PortB because that's the
 way my hardware board is setup.
  	  | Code: |  	  | #include <18F452.h>
 #fuses XT, BROWNOUT, PUT, NOWDT, NOLVP
 #use delay(clock=4M)
 #byte PORTB = getenv("SFR:PORTB")
 int i;
 output_b(0x00);  // All Leds off initially, and PortB TRIS = all outputs
 for(i = 0; i < 4; i++)
 bit_set(PORTB, LED_LookupTable[i]);
 | You cannot post new topics in this forum You cannot reply to topics in this forum
