compiler error on #include "d:\Pics\c\16F88.h"
joel1
PostPosted: Wed Aug 20, 2014 10:07 pm     Reply with quote
get the following error
*** Error 18 "SerialTest-88-Internal8MHz.c" Line 11(10,29): File can not be opened
dyeatman
PostPosted: Thu Aug 21, 2014 4:39 am     Reply with quote
The error has nothing to do with the 16F88.h header file.
The problem is that the compiler cant find the referenced file.
Make sure "SerialTest-88-Internal8MHz.c" is in the same directory as your
program. If it is, you likely have the file name spelling wrong in your program.
I would not use dashes in file names. It causes too many problems.
Change to underscores or, better yet, get rid of them entirely and
make it all one word
Google and Forum Search are some of your best tools
PostPosted: Thu Aug 21, 2014 2:57 pm     Reply with quote
I have seen this rarely. I don't remember the details, except that the file
is there, but the compiler reports it can't find it. Everything appears to
be correct, such as the path to include files, etc.
I solved it by a complete removal of the compiler (examining the
directory and manually deleting files if necessary) , and then re-installing
the compiler.
Also, people have reported problems if they use a directory for the
compiler, other than the default one. You are doing this.
joel1
PostPosted: Thu Aug 21, 2014 8:57 pm     Reply with quote
i used #include <16F88.H>
that seems to work
thanks for the feedback
